Hot water baseboard heaters in 2 rooms same zone (top floor) are hot/giving off heat when the thermostat off. Other rooms are working. Nothing is working, what could the problem be?
We've tried replacing the thermostat, bleeding the lines, resetting the furnace.
  • 15 Answers
SOURCE: have an oil fired boiler
These boilers usually have multiple controls. The control that would take it out of the circuit at 210 degrees is a safety.
You should definitely have a professional take a look at this unit before you continue using it.
Posted on Sep 18, 2008
tborn6
  • 700 Answers
SOURCE: three of four zones, baseboard heat, warm house, why not fourth
Go to the last heater in the zone and look for a bleed off valve so you can get the air out of the system. you may have to bleed it off several times as the air works itself thru the system. usually there is a automatic air vent on the very highest point that the system has. Let me know if this helps and have a Merry Christmas
Posted on Dec 23, 2008
  • 92 Answers
SOURCE: One zone not working; another is partly working
i would check my water pressure on boiler sounds like lack of pressure or air in system they can be related. if you have bleeder on baseboard try to bleed.
Posted on Feb 24, 2009
  • 189 Answers
SOURCE: Electric baseboard heat not getting hot
Is your fuse box and main power source large enough to handle the full load if all are turned on at the same time? Are you uses two pole breakers? you might only be feeding with 110 volt. This would prevent them from getting very hot.
Posted on Mar 08, 2009
gary1121
  • 332 Answers
SOURCE: installing hot water baseboard heater
IF THEY COME WITH THE COVERS SET THEM AGAINST THE WALL WHERE TO BE INSTALLED, THERE ARE MOUNTING BRAKETS INSIDE THE WALL PLATE AND THE PIPE SHOULD SIT ON THE BRACKETS,, APROX 3-4 INCHES OFF FLOOR,
Posted on May 29, 2009
Hot water baseboard, third level heat not working
Raise water pressure to 12 and bleed out of the return pipe for that zone until you get all the air out!
Jan 09, 2014 | Honeywell Armstrong Gas Furnace Flame...
Tip
Underfloor Radiant Heating for Your New Sunroom
You want to add a brand new sunroom onto your existing house. The problem is that you are not sure how to heat it. Electric heating with baseboard heaters will spoil the look that you want from your new room. Hot water baseboard is going to present all types of problems getting hooked in to the existing system and piping it. And, if you have hot air heating system then you will have the problem of getting ductwork to the room. There is another way to heat this room easily and efficiently.
Radiant heating has been one of the most comfortable and efficient ways for heating for many years. The problem has been in the past to find a good heating source for small radiant floors that will be affordable, effective and efficient.
This problem has been solved now, with the availability of small new electric combination heater- circulator units. These units use small electric heating elements together with a small circulator pump to give you a all in one heating source and circulator pump.
Now you just have to lay your tubing in the floor of the room you are adding on to your house. Then you run that tubing into your existing basement or other room in your house. The tubing and the electric are attached to the heating unit. Then, wire a thermostat to the unit, and you are now ready to make heat. This really makes heating a new addition room very inexpensive and easy to do.
The greatest thing about using this type of heating system is that most average do-it-yourself types can do this. All that is needed is a basic knowledge of plumbing and electric.
If you are thinking of building that little add-on and are worried about how you will heat it, think about using radiant floor heat and a small electric heater-circulator to do your project.
on Dec 05, 2009 | Heating & Cooling
Hot water not going, wanting to know how to turn it back on?
You have a real good description of your thermostat--
I wonder why you suspect the thermostat to be causing your 'No Hot Water' problem?
First of all, I have to be sure I understand your real problem--
When you say you want to 'turn the Hot Water back on', (It is 'Not going')
Do you mean you want a boiler (maybe in the basement?) -- or maybe a zone valve in a Hot Water, Baseboard heating system-- to be heating your house/ room/ apartment?
I would suppose, if you have the thermostat set higher than the room temperature, that it should be giving a 'call' to the boiler (or Baseboard Hot Water Heater..) to ignite a fire, and heat the waer, and then heat your room, or house.
So-- Could the problem be in the Device heating the Hot Water?
Please tell us more about your heating system-- what type of fuel, -- What happens when you lower the Thermostat, and then raise it-- What used to happen, and what does NOT now happen, etc.
Tell us more clues-- maybe we can help remotely like this-
Mack B
Jan 26, 2011 | Emerson Fans 300 Heating & Cooling...
I have a Weil-McLain hot water boiler for baseboard heat. The system has one circulator pump. The system has 5 zones - 3 work fine and two are not working. All the zone valves and thermostats are...
Hello.Prob#1 valve has a bad END SWITCH,change the power head,thad brings the circ on when open.Prob#2 try manual overide lever.iS IT TIGHT OR SMOOTH?DOES IT JUMP/SNAP?motor very hot? all bad signs.Change that power head too.The transformers are OK because 1 trans can only run 3 valves max.
Sep 20, 2010 | Honeywell (CT62B1015) Baseboard Heater
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
I have a new Honeywell Round Non-Programmable Heat Only thermostat MFG # T8775A1009. I turned it down to 50 degrees. The room temp. is reading 70 degrees and heat is coming out of my baseboards. Why is...
Make sure the switches on the back of the thermostat is set for hot water heat. If you have more then 1 zone you may a stuck zone valve or a short in the wiring somewhere keeping the boiler on.
Apr 02, 2010 | Honeywell Programmable Thermostat Heater
Feb 20, 2009 | Honeywell Programmable Thermostat Heater
Jan 03, 2009 | Heating & Cooling
No heat in zone with Honeywell rth230B
It is not your thermostat, it is an airbound zone. The gurgly noise you heard was that water and air flowing through the radiator. The zone needs to be purged either at the boiler, or through vents on the radiator. Hope this helps
Nov 01, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
