I am getting a playback error on my Vizeo TV - Televison & Video
My vizeo tv 55" it keeps shutting off & on while i'm watching it. It's a 2013
Check if any error messages appear.
Message duration may be too brief to read, so you could try filming screen with a video camera or smart-phone, then play it back via a video editor.
Otherwise get somebody to check internally for dry solder joints / cracked board tracks / loose connectors.
As temperature varies, this can cause expansion and contraction, causing 'creeping' of connectors, or faults to open like a thermostat.
It could also be the protection circuitry activating if there is a fault such as overloading, short circuit, etc.
Sep 27, 2017 | Televison & Video
Vizeo tv no picture
If audio is OK, the fault would be with its back-light inverter. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 13, 2017 | Vizio E422VA 42-inch Widescreen LCD TV -...
Vizeo tv was moved worked at first but now it willnot
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Vizio 42 in. LCD TV
TV says "no signal"
my tv says no signal when the cable is plugged in and i have tried scannning it but it says no service found ... what can i do
Feb 16, 2009 | Vizio GV42L 42 in. LCD Television
New vizeo 32" LCD TV -- black and white?
check to make sure that both are tuned to the same chanell.
Lou Margolis
Allied Electronics
loumargo@verizon.net
Dec 15, 2008 | Vizio L32 32 in. LCD HDTV
Vizio tv not turning on
Are you getting any power (vizeo in ft of the set should be amber) If it is not you will need to replace the power board . If the set powers up with no picture then you will have to replace the main board.
Nov 15, 2008 | Vizio L32 32 in. LCD HDTV
Power to TV
That is a know problem with vizeo. You need to have the main board replaced. If you do not have a warrenty call vizeo with your model number and see if you can purchase a replacement board.
Jul 26, 2008 | Vizio L32 32 in. LCD HDTV
E03
my jvc gr-DVX MINIDV PAL KEEPS GETTING ERROR CODE EO3 PLEASE HELP
Dec 04, 2007 | JVC GR-DVL20EG Mini DV Digital Camcorder
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
