Question about Microwave Ovens
Open close door warning on microwave and won't start kitchenaid
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave works with door open
If the top is open, the upper door switch should be open and the high voltage section should not be energized. That's the way it's *supposed* to work. But that buzzing is worrysome! Does the turntable turn during this condition? Does the inside light come on? How about the fan? If not, then I would doubt that it's cooking. If so, some models will do this. It's not uncommon to notice that the fan and light will try to come on for a split second when you shut the door. This would not indicate a problem. It has to do with the timing of the door switches and a replay on the board. If it's still under full warranty, it wouldn't hurt to call a GE-authorized servicer.
Posted on Nov 07, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave Turnable turns on opening the door
Thanks for the photo of the label!
It shows the FCC ID number, which I used to find schematics at the FCC Web site.
The problem is a shorted primary interlock switch.
This is the door switch which has two black wires connected to one terminal and a black and a blue wire connected to the other
terminal.
See these files for help:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Jan 23, 2009
  • 574 Answers
SOURCE: Kitchenaid KCMS185JSS-3 microwave - no power
Well your gonna have to take it down a take apart the microwave more than likely. Probably have a shorted HV diode,magnetron, shorted winding in HV transformer.burnt or frayed HV wire insulation
Posted on Sep 03, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: The door press opener button of my kitchenaid
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, usually only the control panel needs to be removed.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Posted on Nov 29, 2009
  • 6771 Answers
SOURCE: MWG91155L Emerson microwave starts when the door is closed
One of the door switches is malfunctioning and must be replaced to resolve the issue.
Posted on Apr 08, 2012
KItchenAid microwave KHMS1850S: interlock switches replaced, but fuse keeps blowing
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/khms1850s.html
Jan 27, 2015 | KitchenAid Microwave Ovens
Kitchenaid microwave open door switch does not work
on my microwave, the door sticks some times & I put my fingers under door on latch side & push up, & I can hear it release & open. other than that there may be a broken part. follow the link below.
KitchenAid Microwave Door Won Open
Jan 23, 2015 | KitchenAid Microwave Ovens
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Door open button won't work on KitchenAid microwave model YKCMS135H
Page 3 of the exploded view here shows the door open parts 24510L and 250201 (or 23551B if your full model number is YKCMS135HSS).
What look like part numbers seem to be reference numbers.
For further help you will need to contact Kitchenaid Canada here.
Sep 05, 2012 | KitchenAid KCMS1555RSS Stainless Steel...
Door on Sharp R-K520S won't stay closed.
check the hooks and door release button and repair or replace, when this is broken, the switch is not close the microwave will not START.
SEE the diagram
God bless you
Jul 14, 2012 | Microwave Ovens
Kitchenaid Microwave Oven model Kcms1555rss stuck on same cooking time. There is a line with 3 other lines also on the screen
Hello :
It could be a bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
Warning : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Door indicator prevents microwave from starting
This is usually an indication of a bad door interlock. Take resistance readings with the power turned off on the primary and secondary interlocks. You will need to remove the control panel to access them. There should be a wiring diagram somewhere inside the control panel to assist you in determining if the interlock is normally OPEN, or normally CLOSED. As you open and close the door the interlock should change states. Additionally, double all your connectors to make sure they are plugged in correctly. I had a similar problem once and it turned out to be a loose connection on one of the interlocks. I hope this helps you.
Aug 04, 2007 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
37 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
