Question about Bose Awrcc2
Bose awrcc2 manual
I cannot get my radio to shut off using the power button on the remote. I put a new battery in the remote and it makes no difference. otherwise the remote seems to work
  • 6 Answers
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
Posted on Apr 06, 2008
SOURCE: can't remove battery of remote to bose radio/cd player (won't work)
On the back of the remote there is a small hole. You need to slide the small lock in the hole over and the battery compartment should pop open. This requires something small like a straightened paper clip. You may need to coax it a little with your finger by pushing out off the end of the remote. There is a picture of this on the back of my remote. I just removed my battery so i could replace it. The battery size is CR2032.
Posted on Oct 14, 2008
SOURCE: bose radio won't turn on
My Bose wave radio (w/cd ) was purchased in 1999, it was working fine untill it quit. Power is gone. What could be the cause and how could i fix it or can it still be fixed?
Posted on Nov 08, 2008
  • 22 Answers
SOURCE: Bose wave radio will not power on. used to work
I repaired mine recently. Check transistor Q4 for an e-b short. The replacement costs less than $1.
Posted on Jun 27, 2009
  • 50 Answers
SOURCE: Remote won't turn on the system. Has new
Unplug the speaker plug and the power plug. Let it sit for a minute. Plug the speakers in and then the power and try again. Hope this helps.I have seen this many times and this is usually the solution.
Posted on Jul 05, 2009
What caps might need replacement when a Bose AWRCC2 has ac hum?
It's not always, as everyone believes, that all capacitors are bad. In your particular case, the capacitors that would cause this, are the 2 large(in physical size and capacitance) directly off the bridge rectifier in the power supply.
Dec 07, 2014 | Bose Audio Players & Recorders
Bose Wave radio
this is a power problem.
leave the unit unplugged for one night and then try switching ON
Oct 01, 2008 | Bose Wave Radio
Remote will not work volume or power use the play mode button the clock steady sets
Remove the cover and clean the volume and the power button with water or suitable spray for electronic circuits cleaning
if they didnt work. Put connector on the buttons to connect when pressed. Your cigarettes package paper can be cut in the size if the button and be put into the button be used as connectir instead of the remote connector
tty this carefully and the buttons will work
Sep 22, 2014 | Bose Awrcc2
I ordered and received a new remote for my Bose radio. Mine is the old type purchased in 1997. My problem is the new remote does not work, and yes it did come with a battery. Is there something you can...
The old and new remote look alike?Not than it have diffrent radio frequencies.The remote will not work,with the Bose radio you have.Call bose custumer service,ask the remote the match ur Bose radio make and model.Return the remote u have,get a replacement matches ur Bose radio model or look alike to ur old remote.
Sep 04, 2010 | Bose Televison & Video
Have a Bose wave Music Sys model AWRCC2 with stuck
Yes I think you can, get out your tools and take apart the unit, what do you have to loose you can always take it to a pro if you can't get it out. Be careful to unplug the unit. Don't force anything when you take it apart, be careful not to break any parts, put all pieces back together as you took them apart. Should be very straight forward if you are careful at what you do, get a bowl to put small parts in. Good Luck.....
Apr 07, 2010 | Bose Wave Radio
The remote for my Bose Wave radio-CD no longer works. I have changed the battery and put a new battery into another Bose remote--no luck and I want to play my Christmas CDs! Help!
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug it back in
  • Make sure you’re pointing the remote directly at your Wave® music system. If the system is placed above table-top height, be sure to angle the remote upward while pointing
  • Check for possible sources of interference with the remote’s infrared (IR) signal, such as bright lights or solar glare off of a window. Make sure nothing is blocking the path of the signal from the remote to the Wave® music system display. The remote will not work properly if there is something directly in front of the display
  • Wipe off the small clear lens on the front end of the remote
  • The remote is designed to work within 20' of the system. Greater distance may cause intermittent response
Dec 05, 2009 | Bose Wave Radio
We have a bose wave music system model awrcc2 unit that made a poping sound & now it just buzzes. we can hear music but with a loud hum.
Sounds like you've blown a capacitor in the power supply section. Unfortunately, Bose does not release their parts lists or schematics, effectively creating a monopoly for parts and repairs. In fact, their web site says that the Bose factory is the only option for service or repair. They used to list a flat rate repair charge on the web site, but removed it - probably because it scared too many people. Their troubleshooting guide (below) might help, but it's very simplistic.
Before you invest in expensive factory repair on one of these trouble prone sets, you might want to investigate the new HD radios -- better sound at a MUCH lower price.
Jan 25, 2009 | Bose Wave Radio
Bose Wave AWRCC2 CD "not playable"
I had the same problem yesterday on my new Bose Wave Music System. I just kept on pressing reinsert everytime the CD got rejected and suddenly it started accepting CD's again.
May 06, 2008 | Bose Wave Radio II
Cd "not playable" on Bose Wave AWrcc2
Sounds like a weak or bad optical pick-up. You could try gently cleaning it, but you'll probably have to send to Bose for repair.
Bose Wave AWRCC2 error message
Which error, you did'nt put it in the post.
Mar 31, 2008 | Bose Wave Radio
Bose Awrcc2 Logo
134 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
