Question about Garden
Does anyone really have a website to view a manual free for the Toro 418 ZE snow blower? Thanks, Hank
  • Garden Master
  • 19,664 Answers
Here you go, choose the year and serial number and it takes to manuals and parts lists.
https://www.toro.com/en-CA/parts?SelectedFilterByOption=equipment&SearchText=418+ZE
Posted on Dec 05, 2016
Electric start does not work. how do i trouble shoot it?
Mine the electric cord had pulled out of the receptacle.on the blower so it was not working. I pulled it right out and reinstalled it It's ok now.
Do you have power coming to the blower or have you blown a GFI and it needs to be reset. Does the starter click or try to work? These are things that I have to know before we tear things apart.
If it buzzes it could need a gear replacement. on the starter itself.
Mar 03, 2015 | Toro Power Clear 418 ZE - Single Stage...
Will not start.but backfires..why?
Clean the spark plug, it might be dirty causing misfire.
Timing might be off, take to repair shop for this.
Feb 13, 2015 | Toro Power Clear 418 ZE - Single Stage...
Have toro 418 snow thrower prime it and starts but immediately stalls can only keep running if I keep pushing the primer button what's wrong
The fuel pickup tube in the carburetor is probably clogged. I don't know how handy you are, but you have to remove the carb, disassemble it and blow out all the orfices with compressed air and possibly run thin wires into the tubes and holes. Good Luck! the last time I had to do this was in the middle of a snowstorm!
Jan 28, 2015 | Toro Power Clear 418 ZE - Single Stage...
Cleaned the carb but now it leaks around bowl cover What is the needle valve on the side? I tried to clean it but the holes are still blocked tight. Is that normal ?
the gasket is not seated right . also the needle is above the float take the pin out that holds the float in clean it out put the float back in right make sure the needle seats right liftthe floa up and down to make sure it closes right , should not extend to far that is why it will stick on and leak fuel ,
Jan 19, 2015 | Toro Power Clear 418 ZE - Single Stage...
Control switch is broken how replace switch
they are not hard look at it real good you will see how it comes apart , this is easy
Mar 02, 2014 | Toro Power Clear 418 ZE - Single Stage...
Toro power clear 418 won't start
does it have good gas in it , clean it out if it is 2+2 mix put new mix most small snowblower are 2 stroke which takes gas oil mix , make sure you clean plug and are getting spark
Feb 18, 2014 | Toro Power Clear 418 ZE - Single Stage...
Trouble shooting New Toro Power Clear 418 zr - slight misses and pops while running
when you start it do u use the choke right , when starting close choke when it starts open choke you prob fouled the plug clean it put back it walah
Nov 22, 2013 | Toro Power Clear 418 ZR - Single Stage...
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
