Question about Whirlpool Refrigerators
Freezer and box gets cold, than thaws every thing. replaced board and bi medal. Still not working right. whirlpool modelgs6shaxlb03 can you help thanks William
    Top Expert:
  • Whirlpool Master
  • 12,962 Answers
Did you check the defrost timer mechanism? If that stays on for more than necessary that will cause the problem you are having.
Posted on Dec 15, 2016
Hotpoint frige/freezer mod stf 200 wp keeps freezing up
Need exact whole model # for more info.
sound like a defrost problem .
Defrost Bi metal or defrost heater bad and the wurst main computer board. Ice builds up on back wall of freezer.
thaw back wall remove panel heater will be at bottom of coil Bi metal will be at top of coil small disc shape thing with 2 wires coming out
check both . bi metal must be tested cold at 30 degree opens at 35 degree if never closes then there is your problem
Mar 07, 2015 | Hotpoint Refrigerators
My meat is beginning to thaw in the freezer. this is the first time this has happened. any ideas? do i just need to defrost? the refrigerator is working fine, does this matter?
Usually when the ref is working fine the freezer isnt. You just dont know that yet. Check the back wall of the freezer and see if there is an ice build up. If so that means that theres a defrost problem so its either a bi-metal( terminator) heater, defrost timer or board.
Let me know if theres an ice buildup or not.
Aug 18, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Greetings: I have a 4-5 yr old Whirlpool up-right
lucky to get five years out of any white good
time to do the math
replacement cost of failed components
verses
benefits of a new up-right Freezer
Feb 28, 2017 | Whirlpool Freezers
Refrigerator/freezer won't stay cold.
With the defrost timer being replaced already it sounds as if the repairman is not looking at the real problem. Unit works for 2 days then things start thawing. Hint Hint... it is not defrosting. There is a heating element inside the freezer section attached underneath the internal tubing that melts the ice every 6 to 8 hours via the defrost timer depending on the defrost timer installed. To prove that it is not defrosting..... just unplug the unit and place a stand fan blowing into the freezer for about 90 minutes. I would bet that once you plug it back in it wil work for 2 days and the problem once again repeats. With 2 calls on the same unit and you still have the same problem I would be calling the service people back and demand they fully troubleshoot the defrosting element and thermostat. Personally this is an unstatisfactory performance of an in home service by a repairman. With the exception of a new part if required, they should wave any labor and service call fees.
Jan 02, 2010 | Whirlpool Refrigerators
Freezer and refrigerator will not get cold - fan runs but not ver
You will need to check for frost accumulation in the freezer section. The rear panel inside the freezer will need to be removed. If there is frost either the defrost bi metal or the heater are open. If both are ok the defrost control needs to be replaced depending on the model some defrost controls are electronic some are mechanical.
Dec 26, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Freezer
Most likely you have a defrost problem. IF, you think the timer is ok then the most likely problem is the bi-metal. That is a little part usually on the top right side of the evap coil and has two wires on it. If you can find the defrost timer and advance it slowly till the refrigerator stops running, then being in the defrost postion you can see if the heater is coming on. If so you have a bad timer. If NOT, then either the heater or the bi-metal is bad. Usually it is the bi-metal
Aug 27, 2008 | Freezers
Indesit BA139 fridge freezer with very thick frosting on back wall, but not very cold fridge section (despite changing the temp control to max) and normal very cold freezer section. When temp control...
One or more of your defrost components(defrost timer or board, defrost heater, defrost thermostat/ bi-metal) are bad. Unless you removed the inside back wall in freezer and completely thawed the evaporator, it will not cool properly.
Aug 25, 2017 | Refrigerators
The freezer isn't freezing and the refridgerator isn't staying cold. i unplug it to defrost it and it will work for about a week ten its the same thing all over again
guff21, you have a problem with defrost cycle.
3 things, defrost heater, bi metal, and timer. either one of the three goes bad, same problem appears.
check the defrost heater by resistance. it should have a resistance
check the timer if it is turning and tunning and transfering from cooling mode to heating mode and vice versa.
you can only check the bi-metal if its all frozen up. the bi-metal is close at freezing temperature and opens at thaw themperature.
i hope i was able to solve your problem.
Jul 08, 2008 | Refrigerators
Fridge not cold but freezer working
then remove the panel that has the frost on it the heater and bi metel will be there
Apr 29, 2008 | Refrigerators
Refrigerators Logo
46 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
