Question about Boating
Hi 200hp mercury outboard not getting power on take off and on plain top speed 45mph
4 Suggested Answers
SOURCE: 9.8 hp mercury outboard shutting off in low idle speed.
My problem ended up being the spring on the reed valve being weak.But at the same time and while I had already had my carb broke down I took a can of carb cleaner to it and cleaned it. In order to replace the spring on reed valve you will have to buy a new one, but don't worry I only payed about $6.00 for mine. You may also look into replacing your primer bulb if you haven't already because may allowing air to build up in your gas line while you are basically idiling.Once you get the carb straightened out you may have to reajust it again. If I might be able to help you again you may contact me at j_speaks@yahoo.com.
Posted on Jun 16, 2009
  • 53 Answers
SOURCE: want to replace the trim/tilt motors on my 1995
no. a unmodified transom bracket may need to be moved not removed. Since the tilt motor is out you will need to manually lift the engine. you can see the picture diagram at www.yamaha-motor.com. click on outboard motors,parts and service, view parts catalog. find your year make and model by following steps listed at top. select power trim and tilt assembly. in the picture you will see the location of the Manuel release valve on the starboard side. turn the Manuel release valve then lift the engine. tie it up or use a stand to keep it up,do not use the tilt lock. with the engine in full tilt position, you can see the motor. some brackets are modified were you can remove the motor without moving the transom bracket. If unmodified you'll need to follow these steps. (1) lower the engine back down.the steering arm needs to be removed from the steering cable and swung forward. do not remove steering arm from engine. on the starboard side of the engine you will see the steering cable going into the steering cable tube. (2)a 1 1/6 nut secures the cable to that tube remove it and slide cable out do not remove it.(3) lift engine again and secure it. your about to remove the motor mount bolt so make sure you secure the motor completely (4)remove upper and lower transom to bracket bolts remove bolts on the port side only.(5) you will see three bolt that go through the transom bracket to the trim and tilt assembly. remove them.(6) if all bolts are removed you will be able to slide the port transom bracket to the left out of the way(7) remove tilt/trim motor.
Posted on Nov 03, 2009
philwalker78
  • 608 Answers
SOURCE: I need to know the
Hi, 5500rpm regards Phil.
Posted on Aug 03, 2011
I have a 1999 200hp Yamaha outboard motor idles fine everytime I put in gear stalls at low rpm fine at high rpms and idles fine in gear loe rpms stalls
This may sound funny, but for a while, Yamaha put a steel bolt in the aluminum casing on the side of the motor. dissimilar metals caused extreme corrosion inside that affected operation. Check out Boating forums on Yamaha.
May 18, 2018 | Seloc Yamaha Mercury Mariner Outboards...
What year is the serial no of my yamaha 200hp
if this is an outboard motor then try this website and see if you can get the information from it. good lusk.
Yamaha Outboard Serial Number Location and Model Identification
Dec 12, 2017 | Miscellaneous
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
What is problem 2000 mercury outboard 200hp number 5 cyl no compression
if no compression could be a bent , cracked ,damaged valves, hole in piston, broken piston, broken connecting rod,
NO I DONT THINK YOU WANT TO BUY IT .unless its for parts your buying a padoras box of junk ,pull the plug and look it over for damage ,heavy oil ,if your getting no I mean "O" compression you'll have to do a full tare down. to find problem ,if seller says its an eazy or not expencive repair have him do it .
Aug 28, 2014 | Boating
Mercury troubleshooting
If the supercharger end cap is leaking oil you would be able to see in around the end some where. If you cannot see it you would be able to get some on your fingers as you wiped the end cap area. May be a second opinion from another mercury dealer would set your mind at rest
Nov 29, 2013 | Cars & Trucks
Boating Logo
115 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
