Question about Kubota Garden
I have a Kubota Z127E zero turn mower that the motor has seized up while I was cutting my grass.Does Kubota have a problem with these mowers?
  • 12 Answers
SOURCE: Where can I get free download manual for a Kubota Mower ZD21?
http://www.mckeelequipment.com/kubota-mowers.htm
Posted on Jun 26, 2009
  • 376 Answers
SOURCE: Craftmen mower doesn't cut well on right side
Sounds like you may have made a common mistake, getting one or both of the blades upside down.
Posted on Jun 28, 2009
  • 8 Answers
SOURCE: mower wont start
The flywheel key has sheared and it needs to be replaced. Replacing the flywheel key is a fairly straightforward procedure. Otherwise, it will be necessary to take the mower to have someone replace the flywheel key.
Here are some steps to follow to replace the flywheel key on your own (instructions are for a toro 20016 model mower):
  1. block off the blade and driver assembly with a 2x4 to keep it from moving
  2. remove the flywheel nut (regular hand force should be sufficient)
  3. tap the 3 holes on the flywheel (if they aren't already threaded) using 1/4inch 20national tap set
  4. remove the flywheel using a flywheel puller -- a harmonic balancer puller which matches the tecumseh bolt pattern on the flywheel also works using 3 1/4inch thread (20national, 2inch long) bolts with washers
  5. NOTE: (if the blade was removed/reinstalled, tighten the blade to manufacturer's spec of 60lbs) before installing the new flywheel key
  6. remove the sheared flywheel key
  7. clean up the flywheel (wipe off all the dirt and grease)
  8. install the new flywheel key (part 611004 for toro 20016)
  9. install the flywheel (pull the bail brake handle to get the ball-brake inside the flywheel)
  10. tighten the flywheel nut to manufacturer's spec of 37.5lbs
  11. prime the gas bulb, give it a pull and mow away
Posted on Sep 02, 2009
perpetually
  • 360 Answers
SOURCE: uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Posted on Sep 21, 2009
SOURCE: Motor does not change for long grass , it cuts
i have a talon lawnmover starts get but revs are low ,i move choke up and down doesnt change revs anymore
Posted on Mar 22, 2010
My z5426 has allways left grass behind,i have to cut my lawn twice
Are your blades sharp? Are they lined up so they do not leave grass in between them as they spin?
Is your cutting deck level or is one side higher than the other.
These are all things that could cause long grass to remain.
Some times a bent blade will do this also.
I even had a lawn mower come in and the blades were installed up side down. He wondered why it would not cut right.
Aug 20, 2016 | Husqvarna Zero Turn Mower Z5426
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
Why does the mower blow out chuncks of grass, i am not cutting to low? ive only usewd it 22 times
1. Sharpen the blades
2. Cut when the grass is dry
3. Ensure the belt to the blades is not slipping.
4. Clean the underside of the deck after each use, use a scraper if you must but keep the buildup to a minimum
5. Run the throttle wide open during cutting
Jun 16, 2010 | Toro 42'' Zero Turn Lawn Mower Trailer...
The mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Garden Logo
26 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
