Question about Hardware & Accessories
Need setting instructions for 9 volt Melnor hose timer
Timer 3018AR manual
Timer could be Melnor 3015 or Melnor 3018
Copy following links to download possible manuals:
http://waterheatertimer.org/pdf/melnor-aqua-timer-3015-B.pdf
http://waterheatertimer.org/pdf/melnor-aqua-timer-3015.pdf
http://waterheatertimer.org/pdf/Melnor-3018.pdf
Jun 05, 2012 | Hardware & Accessories
Need to known how to set the timer do not have a manual we have the VIGORO deluxe water timer, they are about two years old.
I do not know how to set the timer, but can offer possible source for manual.
VIGORO timers can be same as Melnor:
Match up image with your timer and then download manual.
Water timers last 1 or 2 seasons. There is no repair for broken water timers.
http://www.melnor.com/instructions.php
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Hardware & Accessories
How do I get free instruction for Water Timer Vigoro Duo- Deluxe Water timer # on front top lefte is 225-379 # on back is 0708
The vigoro duo delux might be same as Melnor 3100
Open following links:
http://www.melnor.com/instructions/3100_InstructionSheet.pdf
Take a moment and rate answer:
Sep 02, 2011 | Hardware & Accessories
I need instructions to the Vigoro- Duo Deluxe water timer 9 volt battery operated # on back is 0708..# on fromt top left is 225-379 Purchased at Home Depot I has5 to 6 cycles that can be programmed. I...
Not a gardenia timer. It is a verve digital water timer (B&Q). There were no instructions in the box.
Verve water timers might be Melnor:
Open following link for manuals.
Links to other water timer manufactures and manuals are found on following link:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Aug 11, 2011 | GARDENA Water Timer
Verve Digital Water Timer as sold at B&Q have lost the operating instructions.
Jun 14, 2011 | GARDENA Water Timer
Lost directions to set timer Melnor 604 F
Melnor 604F Instructions (from Label on unit)All indicator light flashing - replace 9V battery inside unit
1. To Start - turn dial to Off and press Enter.
2. Set Time - set current time and press Enter (Yellow ring).
3. Set Start Time - Set time to start first irrigation cycle (Yellow ring) and press Enter.
4. Frequency - Set frequency of irrigation cycle; e.g., twice a day set 12 h. (red sector ring) and press Enter
5. Duration - Set duration of cycle (Green band) minutes and press Enter.
To change duration - turn dial to new duration and press enter.
To turn water on manually - Turn dial to ON position, water will turn off in 30 min.
Do not press enter in the OFF position as the unit will clear program. You will have to reprogram unit
via steps 2-5 above.
Jan 31, 2010 | GARDENA Melnor/Gardena 101 Flowmeter Water...
Can it be set to water every other day
Assuming that your model number is 3018 you just need to keep cycling through the frequency options by pressing "change". The hourly options end with "h" and the day options end with "d". So "2d" means every other day. Press "accept" when you come to "2d".
May 29, 2009 | Aqua Hardware & Accessories
Hardware & Accessories Logo
118 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
