Question about Water Dispensing & Filtration
I have a Watertech L5600 water sofner that has a water leak coming from the top of the end plug retainer plate.Is there a "0 " ring or seal insde the unit?
  • 11 Answers
SOURCE: Danby counter top dishwasher leaks
This might help with disassembly. Mine was leaking also, but my main problem was no spray. Use my disassembly instructions to remove the pump/motor. If you notice that the leakage is from the pump and not a loose connection, remove the pump cover and apply a thin bead of Blue RTV sealant to the rubber ring. This stopped the leak in my pump.
________________________________
My Danby dishwasher (DW) stopped working. The spray arm stopped spinning completely and very little water was coming out of the arm. When I removed the spray arm (CAUTION: reverse threaded, turn CW to loosen and CCW to tighten) and ran the DW, very little water was spraying out of the pump.
I thought maybe the pump was clogged. So, I followed the recommendations I had seen online about running a few cycles with Vinegar to clear the crud from the pump, but this did not help.
It seemed like the motor was operating, and there were no strange smells to indicate the motor was burned…just no water spraying. So I thought it must be the pump. Before disassembly, I tried to locate a replacement pump. I searched far and wide, both locally and online, and could not locate a replacement pump. So with nothing to lose, I decided to disassemble the DW, take a look and see what I could find. I am glad that I did.
The bottom line is that I disassembled the dishwasher and found that the plastic pump impeller had worked its way off the pump shaft and was not turning. I forced some Teflon plumbers tape over the shaft and forced the impeller back onto the shaft. The impeller has a flat spot to line up with the shaft and I pushed the impeller down on the shaft as far as it would go. I then used a small socket to fit over the shaft and GENTLY tapped the impeller for a final seating. I reassembled the dishwasher and it worked like a charm.
Since I could not find any service manual or instructions online for this DW, I thought I would share my disassembly/reassembly procedure.
Since my instructions are too long to post here, a complete repair document including a link to pictures can be found at:
http://www.megaupload.com/?d=XBOGBR4I
Posted on Jul 27, 2008
  • 172 Answers
SOURCE: GE Profile water filter housing leaks
Hi there is a grommet you can replace.
#WR02X10678 it is about $7.00 It can help seal the plug sometimes. Ge does want you to buy the whole filter assembly it is number
#WR17X11618 $51.50 . You may also consider putting a new filter in. It seals better than the plug it is number
#gwf $42.95. I dont know why they dont sell a o-ring kit. I guess they just dont make much money on o-rings. I hope this will help you. Have a nice day.
Michael Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Feb 17, 2009
  • 12 Answers
SOURCE: At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Posted on Apr 09, 2009
  • 1089 Answers
SOURCE: water leak between tank and main unit
Hi
If it is leaking on top of the machine and under the water tank, there is a seal that needs to be replaced. Lift off the water tank. There is a large gray doughnut cap that will pop off. Take a screw driver and slip it under the outside of the cap between the machines top and pry gently up and it will pop that side. Go to the other side and do the same. Set the cap aside and take you index finger and stick it in the center of the black gasket. Lift up and if the gasket comes out with it you need to replace it. Clean the inside of the receptacle before installing the new gasket.
Once you get the new gasket, slip it at a slight angle(flat side up), then take your finger nail and run it around the outside edge of the gasket. It will slip in, then push it down. Take the cover and snap it into place. Your good to go.
Posted on May 31, 2009
  • 127 Answers
SOURCE: Hi Guys. My single spout kitchen faucet leaks when
spout seal kit , from what you described.
Posted on Oct 18, 2009
Would a modulator valve on a 2004 grand am not go in reverse
2004 doesn't have a modulator valve . An if it did it would affect all gear operation , Shift hard , but would still go into gear. You have an internal transmission problem !
No Reverse, Slips in Reverse
Checks
Causes
Reverse Clutch
No apply or slipping
Piston and Seal Assembly (457)
Binding, cracked, or leaking
Inner Seal (456)
Plugged orifice
Clutch Plates (460-463)
Worn friction or broken splines
Snap Ring (459, 464)
Out of position
Housing (454)
Cracked, plugged feed holes, or broken tangs
Housing Retainer and Ball Assembly
Missing or out of position
Springs (458)
Binding
Reverse Clutch Fluid Routing
Fluid leak or restriction
Driven Sprocket Support (95)
Leaking seal rings
Porosity, damage, misalignment
Channel Plate and Gasket, and Valve Body, Gaskets, and Channel Plate
Porosity, fluid leak across the channels, misalignment, damage, or fluid restriction
Low and Reverse Band and Servo
Servo Piston (69)
Broken or binding
Servo Piston Seals (71, 72)
Leaking
Servo Pin (67) and Springs (66, 68)
Binding
Servo Cover (73)
Broken, loose, or leaking
Low and Reverse Band (111)
Broken, worn, or out of position
Anchor Pin (64)
Broken
Fluid Feed Tubes (83)
Broken, bent, or plugged
Missing or leaking seal rings
Transmission Case (1)
Porosity, fluid leak, or restriction
Shift Linkage
Disconnected or misaligned
Manual Valve (800) and Link (802)
#1 Checkball
Missing, no low band fluid
Fluid Level
Low
Fluid Pressure
Low
Refer to High or Low Line Pressure .
suggest you take to an ASE certified transmission repair facility !
Oct 10, 2015 | 2004 Pontiac Grand Am
2003. Why does it move forward but not in reverse?
There are several thing's that can cause a no reverse !
Checks
Causes
Reverse Clutch
Inner Seal (456)
Plugged orifice
Out of position
Housing (454)
Springs (458)
Binding
Leaking seal rings
Servo Piston (69)
Broken or binding
Leaking
Binding
Servo Cover (73)
Anchor Pin (64)
Broken
Shift Linkage
#1 Checkball
Fluid Level
Low
Fluid Pressure
Low
Most likely your trans needs to be rebuilt !
to
Jul 26, 2015 | Pontiac Grand Am Cars & Trucks
Saeco Vienna superautomatica leaks when making coffee
This is an easy fix for a 14$. The seal at the water tank connection is worn. Take the water tank off. There is a round flat topped plastic retainer. Pry off the retainer (comes off easily). You will see a black round o-ring made to fit on a channel. Remove the o-ring and replace.Two minutes and you are without water leaks. I do not remove the tank to fill anymore, I use a pitcher instead. Part number 3 in this diagram.
http://www.partsguru.com/user/VIENNA%20PLUS%20DIAGRAM.pdf
Jan 21, 2013 | Saeco Vienna Espresso Machine
Karcher dirtblaster leaking at the end
If it's leaking it obviously has a bad seal or is broken. I would try to disassemble and see if it has a seal or not. Sounds like you could have a bad "O" Ring or some other type of seal leaking but I'd bet on an "0" Ring damaged or wore out. Dissemble it and see what is sealing it and proceed accordingly.
Gillight
Jun 26, 2012 | Karcher K2.26 Electric Power Washer
Challenger pump leaking at the band
You may need a seal plate o-ring or you may have a shaft seal leak. See if you can determine if there is water running down the outside of the seal plate from where the motor mates to the seal plate.
Feb 15, 2012 | Pentair 1 HP Challenger Pump
I replaced the motor on my super 2 pump with a new shaft seal. Put it all back together including electrical and now it's leaking from the bottom. I retightened the screws to make sure they weren't loose...
Most likely leaking from either the shaft seal, or the valute seal (big seal plate o-ring). When you replaced the motor you should have also replaced the shaft seal. If not go back and do that whether it's leaking or not. If you get your head down and look at the bottom of the pump while it's running you should be able to see the water coming from the joint between the seal plate, and the seal plate housing, or just behind that from the bottom of the motor probably from the vent holes in the motor housing. If it's coming from the motor then the shaft seal is leaking, and the water is traveling along the shaft and out the bottom of the motor. This will eventually get into the motor and seize up the bearings. If it's coming from the valute seal, then you need to either replace or re-seat the seal. As a general rule you should always replace the shaft seal, and diffuser and seal plate o-rings when you replace the motor or split the seal. I'm not as familiar with the 2 speed hayward super 2, but the standard super 2's have a small ribbon seal, often called a rubber band. They are infamous for going bad especially after pulling the pump apart.
Sep 18, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
My '99 Silverado 1500 Z71 has been an awesome dependable truck with over 225000 miles. But we've suddenly lost the reverse gear. The drive gears work fine & the tranny fluid is fine so what would cause...
No reverse, here are few things you can try before needing to take it to a tranny shop. The 4l60e trans is a fully electronic trans. And being so the problem could be as simle as the reverse shift solenoid has shortted out. Along that same line the reverse valve could be stuck and or the little screen that is attatched to the mid plat could be clogged and in order fix this problemyou need to drop out the valve boby and for the most part rebuild the reverse circute.
Now for the hard stuff. Other problems you could look at.
imput housing assembly - 3-4 apply ring stuck in applied position.
- forward clutch not releasing
- turbine shaft seals missing,cut or damaged.
manual linkage - not adjusted
oil pump assembly - retainer and ball assembly missing or damaged.
- stator shaft seal rings or ring grooves damaged.
- stator shaft sleeve scored or damaged.
- revers boost valve stuck, damaged or misassembled.
- cup plug missing.
- restricted oil passage.
- faces not flat.
- converter clutch apply valve stuck.
valve body assembly - 2-3 shift valve stuck.
- manual linkage not adjusted.
- spacer plate and gaskets incorrect, misposition or damaged.
reverse input clutch - clutch plate worn.
- reverse input houeing and drum assembly cracked at weld.
- clutch plate retaining ring out of groove.
- return spring asembly retaining ring out of groove.
- piston deformed or dished.
- seals cut or damaged.
- retainer and ball assembly not sealing.
- restricted apply passage.
lo and reverse clutch - clutch plates worn.
- clutch plate retaining ring mispositioned.
- porosity in piston.
- seals damaged.
- return spring assembly retaining ring mispositioned.
case - cover plate gasket missing or damaged.
- cover plate not torgued correctly.
- porosity.
now thhis came from my 4l60 service book.
hope this helps
Thank you for using fixya and be safe
Jul 04, 2010 | 1999 Chevrolet Silverado 1500
How to change the rear bearings in my 1997 grand cherokee limited
YOU HAVE TO SAFELY RAISE SUPPORT VECHICLE MAKE SURE ITS ON A SOLID LEVEL GROUND.THEN YOU REMOVE THE WHEELS THE BRAKE DRUM OR DISC.THEN YOU REMOVE THE NUTS THAT ATTACH THE OUTER SEAL RETAINER AND BRAKE BACKING PLATETO THE AXLE SHAFT TUBE.DISCARD THE NUTS.REMOVE AXLE SHAFT FROM HOUSING.WITH AN AXLE PULLER ATTACHED TO A SLIDE HAMMER.DISCARD INNER AXLE SEALPOSITION THE AXLE SHAFT IN A VISE.REMOVE THE RETAINING RING BY DRILLING A 1/4 HOLE ABOUT 3/4 OF THE WAY THROUGH THE RING. THEN USING A COLD CHISEL OVER THE HOLE.SPLIT THE RING.REMOVE THE BEARING WITH A ARBOR PRESS DISCARD THE SEAL AND REMOVE THE RETAINER PLATE.TO INSTALL - CLEAN THEN APPLY A THIN COATING OF WHEEL BEARING LUBRICANT TO THE BEARING AND SEAL CONTACT SURFACES APPLY WHEEL BEARING LUBRICANT TO THE LIPS OF THE REPLACEMENT INNER AND OUTER SEALS.INSTALL THE INNER SEAL WITH THE OPEN END OF THE SEAL FACING INWARD ENSURE IT IS COMPLETELY SEATED.INSTALL THE RETAINER PLATE AND THE OUTER SEAL ON THE SHAFT.ENSURE THE OPEN END OF THE SEAL FACES TOWARD THE AXLE SHAFT BEARING.PACK THE REPLACEMENT BEARING WITH WHEEL BEARING LUBRICANT AND POSITION ON THE AXLE SHAFT PRESS INTO PLACE.PRESS A REPLACEMENT BEARING RETAINER ON THE AXLE SHAFT AGAINST THE BEARING.INSTALL THE AXLE INTO THE AXLE TUBE.POSITION AND ALIGN THE SEAL RETAINER AND BRAKE SUPPORT PLATE AND INSTALL REPLACEMENT ATTACHING NUTS.TIGHTEN NUTS TO 32 FT LBS.INSTALL BRAKE ASSEMBLY WHEELS LOWER VECHICLE. YOU SAID REAR BEARINGS IF THIS WHAT YOU MEANT.I HOPE THIS CAN HELP.
Apr 12, 2010 | 1997 Jeep Grand Cherokee
Rubber Seal leaks
You have to replace the whole door seal.It can be done through the port hole,difficult but achievable or you can strip the front of the appliance off and do the inner part easier.
Unplug the appliance.
Open the door and take the seal retaining ring out of the door seal.
Peel the door seal off the front panel and fold it inside.
Take the seal retaining ring/spring out of the tub side of the seal.
Pull the seal off and take it out of the appliance.
Fit the new seal to the tub,look at the seal and tub for matching arrow marks to help align it.
Fit the retaining ring/spring into the groove in the seal and over the lip of the tub.
Fit the seal to the front panel and then fit the retaining ring into the seal.
Restore the power to the appliance and leak test it.
If you find you can't get the seal on.
Take the top off the appliance.
Take the dispenser out.
Take out the screws revealed.
Take out the screws holding the door lock.
Take off the plastic cover below the door and remove the screws revealed.
Take the front panel off.
If the panel won't come down and off there will be a hidden screw that requires the facia panel to be removed.It's snap together plastic,just release the catches and carefully remove the facia.
Take the screw out, take the panel off.
Fit the inner part of the seal to the tub.
Reassemble the front of the appliance.
Fit the seal to the front.
Leak test the appliance.
Apr 06, 2010 | EuroTech EWF150 Front Load Washer
Leaking rear axel seal
  1. Remove or disconnect the following:
    Rear wheel Brake caliper and rotor, if equipped Brake drum, if equipped Axle retainer nuts Axle shaft, seal and bearing assembly
  2. Split the bearing retainer with a chisel and remove the retainer ring.
  3. Press the bearing off the axle shaft.
  4. Remove the axle seal and retaining plate.
0900c15280220349.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Rear axle seal and bearing components-2002-05 exc. 2005 Grand Cherokee Hope this helps, please dont forget to rate my solution.
Lefty64
Apr 09, 2009 | 2002 Jeep Grand Cherokee
Water Dispensing & Filtration Logo
1,137 people viewed this question
Top Water Dispensing & Filtration Experts
ray gallant
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Tom Chichester
Are you a Water Dispensing and Filtration Expert? Answer questions, earn points and help others
