Seeburg jukebox Carnival stopped playing in the middle of record, rejected it and the carriage went back to neutral position, now it does not move at all even if i use the manual switch need help
  • 16 Answers
SOURCE: seeburg b 100 jukebox carrier will not move to pick up records
Inside the control center is a solenoid that's connected to some switches. These activate the mechanism to start scanning when a selection is made. You'll have to check that. Could be dirty or need lubrication. The do get sticky after years.
Don't lubricate the plunger, just he other small parts on the switch unit with some light Teflon lube, TRI-FLOW, any hardware store for about $4.
Whatever controls this solenoid might not be working, also. It should activate every time a selection is made, and deactivate after 2 scans of the mechanism.
Your juke is 58+ years old now, so it might be time to have some maintenance done if you're not comfortable tinkering with the innards. Be sure it gets a lube job, too. At least the oil cups on the side of the motor at the very least.
Posted on Apr 18, 2009
  • 211 Answers
SOURCE: Wurlitzer 2600 Jukebox repeats wrong selection
There are two ratchet brackets under the toothed edge of the carousel called 'back stop pawls'. That's where you problem is. The carousel is stopping then falling backwards too far so the odd selection rather than even selection is where the carousel is stopping.
It is also what is causing the jam (or rather contributing to it).
Turn the carousel one 'click' and wind it backwards against the pawl, and flex an arm up to see which one will go up between the carousel fins. If the left pawl is engaged the left arm shoud be able to rise and vice versa.
All those adjustments are a common problem with a 200 selection machine. It can drive you nuts.
Dave F.
Posted on Jun 25, 2009
  • 16 Answers
SOURCE: can weak tube be cause of jukebox not picking up records
1> be sure the service switch is in the PLAY position.
2> It's impossible to determine if the selections are not being written in to memory, or read out from the memory. it could be either.
You most likely have to have the control center looked at, common with a machine this old. The capacitors in your control unit on the back door have probably gone bad, which they do after 25-40 years. Your jukebox is from 1960, so it's time to have both the amplifier and control unit rebuilt. Not what you wanted to hear, but it has to be done. If you're handy and can solder and read a schematic, you can buy the kits on eBay or do a Google search for Bill Bickers or Vern Tisdale. Both sell the rebuild kits.(Feb 27, 2010)
Posted on Feb 28, 2010
SOURCE: I have a LPC 480 Seeburg Jukebox that scans, pick
Try reading this, basically the fault can be in the mech, the amp or trip switches.
Posted on Dec 12, 2010
  • 25 Answers
SOURCE: I need to remove the
Here are some great source where will will get any kinds of Gaming Consoles Solution
» Sony Playstation 3 (PS3) Console
» Microsoft Xbox 360 Console
» Nintendo Wii Console
» Sony PlayStation Portable (PSP) ...
» Nintendo DS Lite Console
» Sony PlayStation 2 (PS2) Console
Number of vote for this solution:9
Posted on Feb 17, 2011
Jukebox problems
If you can't find a scan button to move the carriage then select a number at the other end of the rack so you can fill it
Dec 25, 2013 | Audio Players & Recorders
I have a LPC 480 Seeburg Jukebox that scans, pick up the record, the needle touches the record, then returns the record to the carriage without playing. What can I do?
Nov 28, 2010 | Audio Players & Recorders
Seeburg jukebox sx 100 scans twice and returns
I suggest that you go to the following site for a solution to your problem.
The information listed hereis second to none.
Alan Hood
Oct 13, 2009 | Wurlitzer Jukebox 1015 One More Time...
Seeburg AY160 Spins as if record in place. will not reject.
Try removing the mechanism cover (power off). Turn it back on and try lifting the manual trip lever just to the right of the tonearm. This will cycle the mechanism. If it cycles but still won't engage and scan down the track, your clutch is stuck from lack of lubrication. Consult the manual, which you need to have. Try eBay - several people seel good reprints.
This is a common Seeburg problem and can sometimes be fixed IF you can get some oil into the clutch. Otherwise, you'll need to take the clutch tower off and that's best left to someone with experience.
IF you want to attempt it, you MUST have the manual as you'll have to set up and re do a bunch of adjustments after taking so much apart.
Jul 22, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wailing sound when 1971 seeburg juke box is started
I amnot very familiar with Seeburgs but the trip switch activates at the end of the record playing and THAT mutes the amp. The amp should also be muted until the tone arm lands on the record. So I would suggest the problem is in the amp.
May 05, 2009 | Audio Players & Recorders
62 people viewed this question
