Question about Procom Heating & Cooling
Our Procom ventless fireplace won't stay lit very long. The house isn't tight, the area around the fireplace isn't crowded. It is some sort of fault with the equipment.
I fixed it by bringing in my compressor and blowing the air into it.
  • 108 Answers
SOURCE: procom MN300HPA ventless heater conversion
You need to first get a regulator which will go between the propane tank and the burner. You will need to know the burner capacity in BTU/HR and the pressure required. All of this can be found on the furnace specification plate or on the gas valve. It is a no brainer Circut!
Ray
Posted on Nov 07, 2008
detox101
SOURCE: Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
Posted on Jan 14, 2009
SOURCE: gas fireplace will not stay lit
there is a probe that is in the one of the flame... This once heated builds up enough pressure do to the heat to keep the shut/off valve open... (reason, if the flame went out the gas would continue to flow) this "thermocouple is replaceable !! contact me at homeprohandyman@verizon.net
Posted on Feb 23, 2009
SRF518
  • 232 Answers
SOURCE: I HAVE A DESA LP VENTLESS FIREPLACE AND THE PILOT
the heater makes use of a millivolt generator which generates a small dc voltage (500-750mv) that is applied to the pilot valve of your main gas valve. when you light your pilot, the flame bathes the generator with a flame. after a delay you release the pilot button. if the generator is working, the pilot valve will stay lit. if the generator is not working the flame will go out as soon as you release the pilot button. change the generator.
Posted on Oct 13, 2009
  • 3382 Answers
SOURCE: My propane fireplace pilot light goes out when the
I am just guessing but it may be set to low. The rush of air when it extinguishes could be blowing it out.
Good Luck,
Gilshultz
Posted on Nov 30, 2009
I have a procom ventless fireplace heater and the pilot light will not stay lit
Sounds lie you need to replace the bimetallic strip by the pilot light. If that is bad the main gas nor the pilot will stay on.
Jan 03, 2016 | Procom Heating & Cooling
Procom pilot light wont light
Make sure the gas valve is on. The thermocouple may need to be cleaned in order for the pilot to stay lit.
Nov 26, 2013 | Procom Heating & Cooling
Burner won't light, pilot is burning just fine.
Once you get the pilot to light and stay lit did yall move the burner knob to the ON position? Is the temp knob all the way up?
Nov 27, 2011 | Procom Heating & Cooling
I have a ProCom Ventless Fireplace. LP Sometime
that shouldnt matter u probably have a runner tube where the gas runs from burner to burner sometimes they get clogged or spiders can build webs in them ur best bet is to turn the gas off take apart and clean tat should solve ur problem
Feb 26, 2010 | Procom ML300TBA Heater
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
We are trying to change the thermacouple on a Procom Ventless Gas Fireplace and we can't seem to get to it. Any suggestions?
get it how
screwed back in valve?
nuts seized on?
carefull not to crossthred it, its brass and easily done, go with fingers untill you know it lined up ok
Nov 27, 2009 | Procom 10K BTU, Vent Free, 2 Plaque...
I HAVE A DESA LP VENTLESS FIREPLACE AND THE PILOT WILL NOT STAY LIT
Oct 13, 2009 | Desa International Heating & Cooling
Our charmglo ventless fireplace pilot will not stay lit. It started to go off including the pilot lite. Where can we find replacement parts for this problem?
I have the same problem with my Charglo fireplace. The propane company checked preasure and they even replaced the regulator. I am very disappointed with this and am afraid to use it. I have contacted Charmglo in the past and they were useless.
May 18, 2009 | Home Decorators Collection Charmglow...
Heating & Cooling Logo
102 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
