SOURCE: Jenn-Air JFC2089HES Bottom freezer, French door:
You have a control board issue and should call out a tech. to do the repair. If your still with in your 1st year of purchase then Whirlpool should pick up the charges of part and labor. The tech. will need to be Whirlpool warrenty certified.
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
SOURCE: there is a loud knocking noise from inside or the
This is normal. It is the actuators adjusting the temperature between the freezer and the fridge.
SOURCE: Fridge making knocking sound, only
Here is a tip that I wrote about refrigerators and
the fan noise that they develop sometimes...
Refrigerator
Fan Noise
heatman101
SOURCE: RF263 series Samsung Refrigerator just began
Hi The sound comes when there is ice build up around the fan
and the fan will hit it causing this sound. You can try to leave it unplugged
for around 4-24hrs and also make sure that the area near the back is clear so
that airflow can get through. If the issue returns then replace the thermostat.
Hope this helps...please post back for further assistance. Daniel
