Question about Sewing Machines
I have an ambition 1.5. When Im sewing the machine starts stitching crazy fast for a second or two then overload message comes on and it stops. Cleaned bobbin area and doesnt help (this used to do it)
  • Sewing Machines Master
  • 9,272 Answers
Perhaps the foot control is faulty. That's a good place to check first. If not the foot control, then the machine's components may be going out.
Posted on Dec 05, 2016
    Top Expert:
  • 4,740 Answers
Http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Troubleshooting.htm ..not sure if this link will help you out but have a look
Posted on Dec 04, 2016
Testimonial: "Nope... it's like an electrical thing or something. Like its getting too much power or the wrong signal from the system. Sews at like 50 stitches per second!"
  • 2 more comments
  • noel
    noel Dec 04, 2016
    i will see what else i can find out if i find anything i will let you know.
  • Linda Scibilia
    Linda Scibilia Dec 04, 2016
    Thanks much... basically the motor races, and I have no idea why. Appreciate any help you can provide.
  • noel
    noel Dec 05, 2016
    before i send you another link would you say it could or might be the timing could be out.because i am not finding anything under what you think it might be.
  • noel
    noel Dec 05, 2016
    this link will take you to where there is loads of other links you could try.i have look at most of them but as you will find out if you read them,people are saying what they think it could be.,,,https://www.google.co.uk/webhp?sourceid=...
HOW TO DELETE SEQUENCES FROM MY PFAFF AMBITION 2.0 SEWING MACHINE? it is brand new
if the machine is still under warrenty, I would take it back. if you got a manual with the machine it should have a section in it for the deleting, if all else fails contact pfaff customer service and ask them what you can do, here is a link
Contact
Mar 06, 2016 | PfaFF Sewing Machines
The instructions on pg 40 of the manual says to hold the Delete button in for a longer period.
quilt ambition 2 0
http://sewing.patternreview.com/SewingDiscussions/topic/89785
Also found the following comment to a review:
Jo-Ann16 May 2013 at 07:30
"Hello, I have the ambition 1.5, absolutely love it. To switch the font to normal stitching you have to delete or save the sequence. To delete it just tap the little garbage photo and to save tap the heart. With that done you then go back to your stitching tab select a stitch and tap the little garbage bin to erase sequencing and go back to normal stitching."
Lo warning comes on when i try to sew. Waited 15 secs did not work. Cannot sew.
It sounds like a machine overload. Rather than just turning it off for a few seconds, turn it off and clear out the lint from the feed dogs and the traces. That should take sufficient time to reset and you'll avoid another overload.
Jun 30, 2015 | Janome Magnolia 7330 Sewing Machine
I have a Singer 7285Q sewing machine that comes up with a "E-7" message and the machine won't work. It only happens when I use "back stitch" button. My instruction manual has no mention of an
E7 means
The start/stop button, reverse/reinforcement stitch button
or the thread cutter button was pressed while no thread
cassette was installed. If the start/stop button is pressed before the sewing machine is correctly set up or if an operation is performed
incorrectly, an error message appears in the stitch indicator. Follow the instructions that appear.
If you press (Stitch selection key) or do the operation correctly while the error message is displayed, the
message disappears
Oct 30, 2014 | Singer Sewing Machines
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
Mar 23, 2014 | Singer 7258 Sewing Machine
Machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
Apr 08, 2009 | Singer CE-200 Quantum Futura Computerized...
Sewing Machine Stops
this sounds like its set for zippers check settings!
Dec 09, 2008 | Husqvarna Sewing Machines
Beep sound on Kenmore 19233 sewing machine
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develop in the threading process and you are able to sew a few more stitches before the beeping starts again.If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. If it continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house.
Nov 05, 2007 | Kenmore 19233 Computerized Sewing Machine
Janome 8000 mc
Solution #1 worked for my Janome 8000 Thank You
Sep 12, 2007 | Janome 8080 Computerized Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
