Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
SONY Trinitron Wega KV-36XBR800 not working
Diagnostic light blinks seven times, stops, and then repeats. I have unplugged set from power strip and used wall outlet, but it still does not turn on. Any ideas?
  • Anonymous Dec 05, 2016
    Thank you very much. 7 blinks indicates a "temperature" problem with the suggestion to clean the vents, which I did. That solved it. The SONY Trinitron is an excellent machine, still, after 13 years, and it is fortunate that I got it to work with advice from FIXYA.
    Top Expert:
  • Sony Master
  • 75,178 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 05, 2016
Sony xbr6 standby light blinks 14 times, pauses and repeats
Just count the number of blinks occur at one time. 14 blinks to trinitron TVs are not possible. It might be 10. If so,
  1. Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board. If you wish to know more about blinking codes to Sony Trinitron models TVs, check this link. If it is Intermittent problems? This is a great feature. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
Jan 25, 2013 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Standby blight bliks for seven time tv wont turn on
Seven blink indicates that there is a high voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Hopw this helps .
Jan 23, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I've got 4 blinking lights on sony kp43t70 model
You got board problems....I have the same, so I turn on the tv with the diagnostic settings.....display, 5, vol+, then power on.....it will turn on and you'll have the diagnostic numbers in green on the screen. I have gotten use to them now, the m board needs work & it runs about 300...
Oct 16, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Light blinks 7 times when i try to turn it on. sony kv 36xbr800
Are you sure it isn't eight......try turning on this method....display, 5, vol+, power on. Should bring it on in the diagnostic mode. Mine and about kazillion other owners have the same problem, bad M board and they never issued a recall on it. Costs 2-300 to have someone repair it, cause its' too heavy to carry it in, I think they used cement in the bottom for weight.
Oct 09, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
The standby botton blink 7 in my sony trinitron
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
May 07, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
KV-32FS120
Seven Blinks: High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into shutdown. Check power supply and horizontal circuits.
Culbert Communications
New Brunswick, Canada
Nov 23, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I get a black screen after power on...then a bright white light in the middle of the screen.Then the red light flashing and turns it self off.
Oct 27, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
