Question about DeLonghi Heating & Cooling
My delonghi one inverter air conditioning is coming up with E5 and is not cooling the house down, the manual is in another language
refritech08
  • 149 Answers
SOURCE: air conditioning unit not cooling
the problem sounds like a defective capacitor its located on the condensing unit outside, also a contactor that is used can be defective also.
Posted on Jun 15, 2008
SOURCE: I have a Delonghi PACW160A portable air-con. I
how can i use this product what is the coolest function of this unit
Posted on Dec 06, 2009
SOURCE: air conditioner delonghi will not cool the room
THE RED LIGHT IS ON AND WILL NOT START?
Posted on Jun 29, 2010
TX_AC_Man
  • 107 Answers
SOURCE: Our carrier air conditioner failed to cool down
is it cooling some at night but none during the day basically ? Outside unit clean also ? Good airflow ? if yes on all of these feel the copper pipes that go inside the house from the outside and once a/c has been on for a few minutes the large line should be very cool or cold to where it would condensate.. Sometimes it may take up to 15 minutes..
Posted on Aug 21, 2010
kingbrizzle
  • 407 Answers
SOURCE: My Rheem Air Conditioner- RAKA-030JAS Fan comes on but won't cool down the house. Can it just be the refrigerant is low
Does your air feel warmer than normal? Is there any air coming from the vents at all? Does you air conditioner feel like it's not the same?
These are some quick tips that can get you pointed in the right direction or maybe even fix the problem all together. Checking these few things will allow you to be more specific when posting your problems on FixYa too!
First, a quick checklist, then explanations and extra's below.
1. Make sure your air filters are clean!
2. Make sure power is on to the entire system. Breakers, switches, etc.
3. Make sure batteries are good in thermostat if equipped.
4. Make sure outside condenser coils are clean and free of debris.
5. Make sure your system is not frozen anywhere. Ice on line set, etc.
6. Make sure all system components are working:
a. Indoor blower motor.
b. Outdoor condenser fan motor.
c. Outdoor condenser compressor.
d. Air through all vents in building.
If any of these are not working, you can start there to trouble-shoot the issue. Sometimes more than one problem can occur from just one simple problem. Remember to get as much information from the component as possible to make it easier to diagnose!
Dirty filters will cause restrictions in the airflow, decreasing efficiency, and causing more problems than you could imagine. Even a slightly clogged filter will change the refrigerant charge completely and it's cycle. Basically, if you have a 3 ton house, you need 3 tons of supply vents and 3 tons of return air. If you restrict your airflow, you can have as low as 2 tons venting out into a 3 ton house and the problem is obvious. No one can absolutely say when to change your filters! Your house is different from others, maybe cleaner, maybe dustier, but the filter will always need to be changed at different times. Just pay attention to how often you need to change it and go by your own schedule. Not changing your filters can lead to your coil becoming clogged which is usually pricey to have cleaned. A dirty or clogged coil is worse than a filter!
I don't know how many times I have had to charge for a service call to flip a breaker back on! It's not a good feeling, but in this field, time is money! Save yourself a few bucks by making sure there is power to all components. An indoor furnace will usually have a switch, just like a light switch, to turn on and off the power to service it. It will also have a breaker, more than likely a single-pole 20amp breaker. If you have an air-handler with electric heat, you will have 220v breakers, usually on the unit itself. The outside unit will have a 2 pole breaker, amperage varies, and should have an outside disconnect for service. Some older installations just have the breaker, either inside or out. These disconnects also should have fuses in the part you pull out. If you have any way to check continuity, you can check these too. If you suspect there may not be the correct voltage to any component, you will need a voltmeter or multimeter to check and trouble-shoot.
WARNING! If you do find a tripped breaker or blown fuse, only try one time to reset the breaker or replace the fuse! More than once can cause extreme damage to components and possible refrigerant loss. It needs to be checked to see what is grounded out and if it can be replaced/fixed.
3. Make sure batteries are good in the thermostat if equipped.
It may be a good idea to change them out if you suspect any problems with the thermostat. Many times I have came across a thermostat that looked fine, but the batteries were just low enough that it either wouldn't call at all, or wouldn't keep the call and shut back off. You can also check any household batteries with a multimeter set to the DC scale.
4. Make sure outdoor condenser coils are clean and free of debris.
Condenser coils need to be clean and clear for the operation of the entire system to function properly. It's the air movement through the coils that "condense" the refrigerant and pulls the heat out of the system. If they are dirty, it causes a number of issues that you may not even notice until it is too late. It will cause pressures to rise in the system, over-loading the compressor, and keep some of the heat that is supposed to be pulled out, in the refrigerant causing higher temperatures inside and a lot less efficiency! There are a number of issues, but I'm sure you get the point. The best way for someone to clean condenser coils is with your water-hose. With a gentle stream and being sure not to damage the thin aluminum fins to much. It's a good idea to start on top and work your way down slowly, being careful and try not to shoot the stream straight into the coils, pushing dirt further in between the coils. Instead, a nice 45 degree or more angle works best. Some people will have things like dog hair or cottonwood trees that mat up the coils. You can address this easier by first using a vacuum before spraying it down. People also ask me all the time about cleaning from inside out. For one, i don't think someone inexperienced should take a unit apart for a number of reasons and problems that could occur, and two, the only times you have to take a unit apart to clean it, from the inside or not, is when it's been highly neglected, or when your unit has doubled coils (two coils side by side). Spraying from the inside out can cause more issues by bending the aluminum fins inside when the outsides are already prone to being damaged by natural events. This will cause the system to fail completely.
5. Make sure your system is not froze anywhere. Line-set, coil, etc.
Ice forming on any part of your system is a sign that somethings wrong. The most common cause of this is your refrigerant charge is too low, causing the refrigerant to "boil" at 32 degrees or less, thus causing ice to form. You can also tell when your indoor coil is frozen by the reduction of airflow through the vents and a lot more water draining from the melting ice, which usually overflows out of the coil and down the sides of the indoor unit. Other things that can cause this are dirty filters and/or coil, blower motor not working, condenser fan motor not working, or problems with the metering device such as a restriction in the system. If it is not something that you think you can handle on your own and need to call a repairman or technician, make sure the system is 100% thawed out before they get there, otherwise they will have to leave until then and you may get charged more in time.
6. Make sure all system components are working.
These are things that make the trouble-shooting a lot easier and faster, especially if you are asking for help from someone that's not standing there with you! Sometimes it's easier to have someone there to help you try different things just to check more than one component at a time.
A. Indoor blower motor. If you have air blowing from the vents, then obviously the blower motor is working. Sometimes the blower does not come on with a call for cooling or heat, but that doesn't mean the blower is bad. Always turn the fan to the "ON" position to check this, but beware that other problems could still cause the blower not to work. If you turn the fan to the "ON" position and that's the only time it works, you could have a bad thermostat or other issues that you can check.
B. Outdoor Condenser Fan Motor. When the system is on a call for "COOL", the thermostat sends 24v to the outside condenser, pulling the contactor in allowing the 220v power to start the condenser fan motor and compressor. The fan motor should be pulling air through the coils and out of the unit, usually through the top, with plenty of airflow. If the fan motor is not working, you can turn the power off to the unit to make a few checks. First, try turning the blades yourself with a long screwdriver or something similar. It should rotate freely, if not, the motor has to be replaced. You can visually inspect the wire connections and capacitor inside the electrical compartment by first, making sure power is off to the indoor and outdoor units, just to be safe. Take off the cover, usually it's either 1/4 in or 5/16 in screws, and see if the connections are all on and tight. Inspect the capacitor, which is usually a round or oval object with terminals on top of it, making sure there is nothing leaking and that the top of the capacitor isn't "bubbled" out like it has exploded from the inside. These are only visual checks. To actually check the capacitor, you will need a multimeter that measures micro-farads. To replace these are simple and cheap if you do it yourself. Warning! Capacitors store electricity and can shock you with no power to the unit. Discharge capacitor by touching the terminals together with metal while holding it with an insulated handle, such as a insulated screw-driver.
C. Outdoor Compressor. The compressor is the component inside the condenser that pumps the refrigerant through the line-set. You can hear the compressor running most of the time, if you have doubts, you can hold the copper line-set and feel for vibrations. Believe it or not, the fan and the compressor can be hard to tell apart sometimes. The same visual checks can be made with the compressor as mentioned above with the fan motor. The only other thing you can do is feel on top of the compressor to see if it is really hot. Be sure the power is off! A really hot compressor can mean it has overheated and the internal thermal protection has tripped, causing it to shut off until it cools. This can be cause from the refrigerant charge, restrictions, or electrical problems.
D. Air blowing through vents through-out entire building. Be sure to go to every room and check for airflow. Broken, collapsed, or blocked ducts can cause major air loss and heating/cooling problems.
Posted on Jul 07, 2012
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
I bought a DeLonghi PACC120E portable a/c with no manual. The unit does not cool, and it dumps water. How do I get it to blow cool air?
I would drain the water out of the machine via the plug on the back once the unit is drained turn on, wait a few minutes. If compressor does not come on or comes on and does not cool, you need service beyond diy.
Jun 18, 2014 | DeLonghi PAC C120 Portable Air Conditioner
What is error E5 on pioneer mini split air conditioner?
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in.
Try cleaning it (them if inside one too), with dishwashing liquid and spray outside hose.
Jun 03, 2014 | Pioneer Ductless Mini Split INVERTER Air...
What does -AC on honeywell chronotherm III thermostat mean?
AC means "air conditioning." If the AC icon is showing on your thermostat it means that your air conditioning is activated and should come on when the temperature threshold you've set on the thermostat is reached.
For example, if you've set the temperature level to 78 degrees, when the house temperature goes above 78, usually by about two degrees, the air conditioner should cycle on to cool it back down to 78 degrees at which point it will then turn off.
This information should be in your air conditioning/heating system or thermostat owners manual. If you don't have the manual, you should contact your air conditioning dealer or your builder to secure a replacement. The manual is essential for proper operation and maintenance of your system.
May 14, 2014 | Heating & Cooling
My delonghi dehumidifier will not cool the house just keeps blowing warm air and dosnt feel to cool were thinking about giving up on it
Dehumidifiers aren't supposed to cool your house. If anything they generate heat. How it works is, it has cooling coils that it draws air across, which causes the moisture to condense, and be captured. However the heat extracted from the air has to go somewhere, so it just blows out the other side. If you want cool, buy an air conditioner.
Sep 09, 2012 | DeLonghi Dehumidifiers
Mec portable air condition shows E5 on the screen after i on the air cond about 15-30minutes. Once it showed E5, cool air was not feel but just like fan air. what is the problem?
MEC portable aircond show P1 after on in a 1 and half hour. Once it showed P1, cool air was not feel but just like fan air. what is the problem?
Jun 02, 2012 | Heating & Cooling
Delonghi pacl90. Lost manual, don't know what setting is best for cooling my house. I have a small 850 sq ft place. Should 1 side be blowing out hot air, and the other side have cool air?
Unfortunately, I don't think you're going to be able to find a setting to best cool your house. The model that you have, is a room air conditioner that only generates 10,000 BTU's and is only rated for up to 400 square feet. That's about half the square footage of your house. It simply will not cool your entire house.
To make the most of what you have, place the unit in a room where you spend the most time. Close the door to that room and only air condition it. To keep the other areas a little more comfortable, close the drapes or blinds during the hottest periods of the day. If you have a ceiling fan in that area of the house, run it a fast as you can comfortably stand, in a clockwise rotation. Generating a wind chill in the area that's not air conditioned will help make it more tolerable.
I hope I was of help to you. Thanks for choosing fixture.
Jul 24, 2011 | DeLonghi PAC L90 Portable Air Conditioner
I have a pf code and it wont cool
PF = Power Failure. Refer to your user manual to reset unit after a power failure.
Jun 12, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Air Conditioner Error code?
Error "FL" is coming It is not going by applying suggesstion in your booklet kindly enlighten
Mar 16, 2009 | Haier Energy Star ESA3183 Air Conditioner
I dont know if my new humidifier is working properly
Hello Mary, Where are you located at? if its cold outside? Then whats going on is that even though the outside humidity is say 80 percent humidity on the inside of oyur house even though oyu have the dehumidifier set at say 50 percent by the time the air is heated up there is not that much humidity in it because then the air heats up by the furnance it takes and dries the air out in the process. I know it sounds confusing but if you have ever had a humidifier in you house and it get real cold outside if oyu don't turn the humiditfier down to a lower setting then waht happens is that your windows will start to sweat and run water down to the sill because its condensing on the cold surface of the window. Hope that this helps you.
Jan 07, 2009 | DeLonghi Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
