Question about Water Water Heaters
Clicking sound from control and no hot water model WH-7L...The cliking sound has been going on for a few days
5 Suggested Answers
  • 154 Answers
SOURCE: I have no hot water. Amtrol Water Heater
you neeed to buy complete new sensor,
Posted on Aug 01, 2009
woobie dog
  • 1273 Answers
SOURCE: where is the reset button
I am not familiar with this brand, but have worked on many others and they share common components. Here's my best guess: There should be two metal covers vertically mounted on the outside of the water heater, one about chest high, the other knee high. Behind each cover is a thermostat with a red reset button in the plate. In most cases, there is a white plastic snap on cover over the thermostat and wiring. Caution, the wiring is hot. Each wire will have 110 volts on it, and can electrocute you. Use insulated tools, and press the resets with the insulated tools, not with your fingers.
Best regards, --W/D--
Posted on Aug 04, 2009
  • 14 Answers
SOURCE: AMTROL Boiler Mate - No hot water
Most likely either a bad controller (which is the little display you use to reset) or the temperature probe which is accessible on the underside of your tank. Sensor is a 2 wire probe in center of underside and easily replaced.
Posted on Sep 14, 2009
SOURCE: amtrol water heater WH-7P gets barely warm water
I had the same problem. I had a steam boiler and the water level in the glass gauge was below the top of the coil of the tank. remember water finds its own level, so it settled at the glass gauge level, therefore air got in coil.
to resolve problem : turned on manual water feed to boiler to raise water level. as water level got higher, let out water in hosecock between boiler and amtrol. amtrol noticed hot water reduction, circulator clicked on, boiler kicked on, turned off hosecock, turned off manual feed. I effectively bleed water out of line by running water out of amtrol as water feed in boiler increased water level above coil.
took a while to figure this out, so if this is the problem, dont feel to bad. keep water level of steam boiler high.
Posted on May 12, 2010
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
Jan 19, 2014 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
Boilermate wh-7l, thermostat
Your BoilerMate obtains its energy from the home's boiler and does not have a reset button itself. I work for Amtrol, the manufacturer, and can be of assistance with more info. What is the problem you are experiencing?
May 28, 2012 | Water Heaters
I have a Kenmore Econominder water heater. Model 153-332040 40 gal natural gas/direct vent WH. The last several days it starts up and runs for about 10 seconds 1-2 times before it stays on and heats up...
Water heater burner assembly and combustion chamber probably needs clean and maintenance.
I suggest calling sears service 1-800 469-4663 or plumber.
I'm on Sears/ American/ Rheem/ Reliance etc gas water heater websites most days, and read gas water heater manuals continually.
http://www.sears.com/shc/s/search_10153_12605?keyword=kenmore+power+miser+9+40+gallon+gas+water+heater+gas
http://www.sears.com/shc/s/s_10153_12605_Appliances_Water+Heaters_Natural+Gas
Most people don't fix air conditioning without knowledge going in, but people think water heaters are simpler, because water heaters were simpler a few years ago.
Today, gas water heaters require testing equipment, and specialized tools, plus replacement parts.
Possible problems include: Improper fuel-air mixture, dirty air intake, venting problems, gas control valve problems, air in gas line, low gas pressure, dirty combustion parts, Water condensate dripping on burner, chemicals stored inside same room. Service technician will review all these things during troubleshoot, and you can watch technician and glean information for keeping water heater working longer than warranty.
http://waterheatertimer.org/Replace-anode-rod.html
If repairs are going to cost more than $400, then install new gas water heater yourself same day:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 23, 2011 | Water Heaters
Not getting the amount of hot water I used to get
Remove power from WH Remove heating element covers and, insullation you will see two screws and, a red button (reset) for each element; push the button for each element to reset them; put everything back repower and, test. If the problem is still there: Remove power, test element screws with a meter set for resistance; if no continuity drain WH and, replace element(s)
Apr 25, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I am not getting any hot water, only cold water, when I run my hot water taps. I have an Ariston Bravo water heater. Normally I have permanent hot water at any time. My central heating seems to be...
Sounds like the by-pass valve diaphragm. This valve detects that hot water is being drawn off at the tap and then diverts the mains input water across the heat exchanger. Very often it's the diaphragm inside the valve which is punctured or split.This can be replaced [depending on model] if you take apart the valve
. Remove the front panel and lower the control panel.The valve is at the bottom left of the boiler
Suggest turning off the service taps to the two heating pipes and the cold mains inlet pipes before tackling the valve
Mar 20, 2010 | Water Heaters
Amtrol water heater WH-7P gets barely warm water
From what you are saying it sounds like an issue with either a circulator pump or a zone valve. It depends on what type of system you have ... if you have a circulator pump that only runs the Amtrol then that is probably bad. If you have a zone valve system then it is probably the zone valve if you still have heat for the rest of the house. If you have no space heating then it is probably the circulator pump.
Nov 04, 2009 | Water Heaters
Where is the reset button model #wh 7l
Aug 04, 2009 | Amtrol Water Heaters
Jun 08, 2009 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
