Question about Hotpoint Washing Machines
My hotpoint washer dryer machine have leakage and stoped working,no power
toadilly
SOURCE: not drying
Is it still under warranty? I've read that these machines are better left at the retailer...
Posted on Dec 09, 2007
  • 108 Answers
SOURCE: hotpoint wd64 washer dryer
mits86 , you are correct - it could be the belt.
REMEMBER TO UNPLUG BEFORE STARTING ANYTHING!
To do the belt...
1. UNPLUG the washer.
2. check you've unplugged.
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic caps on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel.
If you see a broken belt then remove it and re-order one from hotpoint...see http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=634224&brand=&model=wd64&part=belt.
6. to replace belt - see motor shaft at bottom of unit. Dangle new belt round shaft of motor and gently pull so it does not come off motor.(This is not easy!)
7. At the same time Ease one side of the new belt back on to drive wheel on the back of the drum.
8. Turn Drive wheel until belt is on.(This is not easy and requires alot of hand strength)
9. Replace concrete block with bolt and spanner in reverse sequence you removed it.
10. replace lid, torx and cover for torx.
- If the belt is not broken in your case - it could be the brushes on the motor - I can give you info on this if required!
Please dont forget to rate me as fixya.
Posted on Mar 26, 2008
  • 12 Answers
SOURCE: hotpoint washer dryer leaking water whilst drying
driers work by running cold water down the back plate of the machine so the hot damp air condence's on to it. It works on the same principle as your bathroom mirror, because its colder than the air around it the moistier in the air condence's on to it. Most machines use a seperate inlet valve from the cold water to do this, they are proned to rub against the back of the drum.Take the top cover off the machine and check the hose's from the cold inlet onto the back of the machine you'll probably find a hole worn in it.
Posted on Jun 15, 2008
  • 135 Answers
SOURCE: Washing Machine broke after power surge
First thing to check is mains filter. have replaced lots on this model!! This is located where the cable comes into the machine.Usually obvious visually if burnt.
Posted on Nov 11, 2008
ginko
  • 19396 Answers
SOURCE: HOTPOINT WASHER DRYER WD440G
That means that the machine detected a problem at a certain point of the cycle and stopped.
If the machine stops when filling check the inlet valve and the water supply.
If it stops because ofervilling check the water level switch.
If it stops when the cycle is hot water only , then check the heating element.
If it stops when draining, then inspect drain filter, drain pump , and drain hose. You access the drain hose removing a panel at the front side of the machine.
If it stops when motor is supposed to spin faster (rinse) then it is motor control unit or motor coupler.
If it is none of the above, then it is a defective control board.
Posted on Feb 16, 2009
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
How to diagnose hotpoint washer model hisr2120aoww only washing.not spinning and not draining?
my next step would be to check on sensors maybe it's stoping machine before its starting spin cycle water level drain hose plugged hope this helps
Feb 03, 2015 | Hotpoint Washing Machines
We have the hotpoint washer/dryer wdl540 but cannot get the dryer to work, all the clothes come out steamed! we'r not overloading the machine and have tried different combinations but still it wont dry -...
The first problem is that you, like myself, bought this piece of trash. The best way to resolve this problem is not sell it on ebay and never even think about buying Hotpoint again.
Oct 29, 2009 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT WD420 TRIPS ALL THE SOCKETS IN MY HOUSE
You have a fault on the machine which is a dead short or an earth leakage.
Neither can be sorted out without a set of testers and some knowledge
Unless you can get hold of a resistance checker and know how to use it call a in a repair person
Jun 14, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Dryer Heat stoped working
Loook inside door an get me the model number. The heat thermistat and the high limit switch will possibly need replaced. Enter the model and part numbers in the search feature on my site below. We offer free help and assiatance also. Thanks, Sea Breeze seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Hotpoint Dryers
Elements over heating on hotpoint ctd00 condenser dryer
Did you check the fuse in your unit ?
Check the fuse whether it is burned.
Mar 13, 2009 | Hotpoint Dryers
Stoped during speen and since then no power. lights are off no conrol lights coming on. cheqed fuses etc, no imrovement. it is hot point AQUARIUS WT 540 16 months old
Hi, it sounds as if your capacitor has blown.
make sure the power has been disconected for at least 24 hours before checking this as it holds power for ages.
where the mains lead goes into the appliance it goes directly to the capacitor, if you know a good sparky he may be able to test it before you get a new one.
Mar 01, 2009 | Hotpoint Aquarius WD63 Front Load...
Nov 11, 2008 | Smeg WD16BA Front Load Washer / Dryer
Hotpoint washer dryer leaking water whilst drying
Oct 21, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint aquarius 1200 washer dryer wd64
operation will be affected by having only one hose connected - when water from the disconnected hose is demanded then machine will not continue. i assume hot hose not connected. easiest way to deal with this is to connect both hoses to a ~"y" piece. easily available and costs about £3
Jul 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
32 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
