Question about Pool & Spa
Great lakes -hot tub.Presenting filter cycles- I can set FC,F2,F4,F6,F8-My question if I pick F2, does that mean filtering for 2 continuous hours or cycle turns on each 2nd hour?
Bob Gemmell
  • 209 Answers
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
jsrock516
  • 5911 Answers
SOURCE: dryer
Normally when a dryer starts to exhibit longer dry times, it could be an indication of some required maintenance. A dryer needs air to breath. Proper ventilation is required for the heating circuits to regulate the internal air temperature properly. If you have to keep placing items back in the dryer to dry again, or the dryer just doesn’t seem to be putting out hot enough air, it may be time to think about checking the dryer vent ducting (a simple separation of more dense clothing from lighter weight clothing can help shorten dry times too). If the heating circuits are starved for air they actually OVERHEAT and can cause problems. When an overheat condition occurs, the hi-limit thermostat is supposed to open to shut off the heating element. This is how the dryer regulates its heat. However, if the hi-limit thermostat malfunctions, the Thermal Cut-Out will blow. This device acts as a fuse, is not resettable, and has to be replaced. This also means that the hi-limit thermostat could be suspect and it should also be replaced at the same time. Most manufacturers recommend replacing the two components together and are sold as a set.
Now...if your dryer has been having problems drying, the first thing you need to check is the ventilation ducting to ensure that it is not kinked or clogged. Poor air flow is the number one cause of dryer failures. Not to mention it can cause fires due to lint backing up inside the dryer. This could be the "electrical" smell a lot of people complain about. If lint accumulates on the heating element it will smolder and burn. It is often reported that you should clean your ducting twice per year. I recommend the ducting be checked (this means inspected to see if it needs cleaning) thoroughly about once per season. That's 4 times per year. If you've never cleaned the ducting, or your dryer is pushed all the way up against the wall causing the ducting to become kinked, you will have air flow problems. One way in determining air flow is to remove the vent hose from the back of the dryer and start the dryer (of course, you need a working dryer in order to do this). The air should be forceful and slowly warm up to about 140 degrees. If the air flow is weak, you may have a clog inside the air baffle of the dryer (this is where the lint screen slides into). If the air flow is good, reattach the dryer hose and check at the output of the dryer vent as it exits your home. If the air flow is weak or non-existent then you know you have a clog in the vent line somewhere. Periodic cleaning will go a long way towards preventing future clogs. Dryer vent rule of thumb: The SHORTER and STRAIGHTER the vent line, the BETTER. Everywhere you have a bend or kink is an area where you will create potential collection points for lint. Poor dryer maintenance is also one of the frequent causes of house fires.
How to troubleshoot a dryer: If your dryer has the lint screen on top of the unit, you will need to remove the back panel to get to the heating circuits. If your dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by pushing in on the release tabs with a putty knife. They are located along the front seam about two inches in from each side. CAUTION: It is recommended that you unplug the dryer BEFORE servicing the inside or cleaning. There are still dangerous voltages present even with the machine turned off.
Symptom:
Dryer Runs, But Does Not Heat:
Suspected Components:
1. Heating Element (located inside the heater box) - Resistance reading should be 9-13 ohms.
2. Thermal Cut-Out (located on the heater box) - Resistance reading of 0 ohms.
3. Hi limit Thermostat (located on the heater box closest to the heating element leads) – Resistance reading of 0 ohms.
4. Operating Thermostat (located on the air baffle) - (May have 4 wires attached to it). Will read 0 ohms across one set of leads, approx. 7 ohms across the other.
5. Bad Heater Relay (usually located in the console) – this is not equipped on all model dryers. However, on dryers that DO have them, this acts as a switch and turns the heater circuits on at the push of the START switch.
Dryer Does Not Run At All:
1. Thermal Fuse (located on the air baffle) - Resistance reading of 0 ohms. NOTE: If the thermal fuse is blown, the drum light will not come on.
2. Broken Drum Belt - If dryer is equipped with a broken belt relay, this will shut the dryer down.
3. Broken Door Switch - If the door switch is broken, this will shut down the entire dryer as no power is applied to the start switch with the door switch open.
4. Bad Start Switch - If the start switch does not toggle close or stay closed when released, the dryer will not start.
5. Bad Timer - If the timer does not function the dryer will not start.
6. Bad Drive Motor - No Motor, drum does not rotate, heating circuits may or may not function. DOUBLE CHECK the CONNECTOR PLUG on the Drive Motor. I have found situations where this plug came loose for whatever reason and caused the dryer to either shut off completely or work intermittently.
7. Bad A/C Receptacle and/or Connector Plug - If you aren't getting the proper voltage to the dryer, it will not run.
These recommendations for TROUBLESHOOTING are not all inclusive as different manufacturer models vary in components and configuration. However, the general cleaning maintenance and proper ventilation requirements should apply to ALL dryers.
Posted on Mar 26, 2008
SOURCE: Kenmore HE4t Won't continue drain cycle Code F6 & beeping
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
Posted on Apr 19, 2009
SOURCE: Bosch she44c wash cycle time keeps extending.
We have had the same problem, except the water was not getting hot either. After a ton of research there was an issue that kept popping up. There was a massive recall on many of the model and serial #s. According to the recall there was a fire risk from the control board, the brains for the machine, that sits behind the digital display. For those not "at risk" but with the water not heating and the run time increasing, the problem can still be with the control board. I removed the control board and found a burned out connection with one of the controls. I soldered it and put the machine back together. The run time has returned to much closer (down to 128 from 184) than before the fix, but still is not back down to the original 108 minutes. I've priced a new control board--about $120.
This happened right after the warranty ran out. Imagine that.
Posted on Oct 10, 2009
  • 102 Answers
SOURCE: HOW THE
FN+ F buttons are used as a shortcut. For example, in my laptop, F1 button has a ? icone at the bottom. when a pres Fn+F1, it will launch the help program. F1 to F12 buttons have different shortcuts.
Posted on Apr 29, 2011
Testimonial: "THANK YOU MUZIKA22 I UNDERSTAND MORE THIS SHORTCUTS F BUTTONS. BUT I HAVE ANOTHER PROBLEM I WILL POST IT :P"
What does error code F6 mean
is this a dream maker hot tub? if so the code is not to severe you just have to have atleast 12 hours of filtering daily the only downside is the electric bill. be glad its not a FC code which is constant filtering. so make sure when your not filtering to keep the pump clean and it shall last you as long as it can.
Feb 28, 2016 | Pool & Spa
Tip
How to use F1, F2 ?..Function buttons on Acer laptop.
For those who do not know how to use the F1, F2, F3..... buttons on Acer laptops, here is an opportunity for you to know.
We see these buttons on most laptops but don't know what they are used for. F1, F2....... buttons are the first set of buttons on the keyboard. These buttons makes it easy for anyone to access some programs on the computer without using mouse.
Follow the below procedures on how to use some of these functions
>To put your Acer laptop on stand-by or to view shut down options, Press and hold Fn button on your keyboard, (without leaving it) then press F4 (Fn + F4).
>To make your Acer laptop be on sleep mode, Press and hold, Fn button, then press F6 (Fn + F6).
>To lock your Acer laptop's Touchpad, press and hold Fn button, then press F7 (Fn + F7).
>To put your Acer laptop on mute Press and hold Fn button, then press F8 (Fn + F8).
>To shut down your laptop or to view other shut down options, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
>To close any page on your Acer laptop, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
Good luck.
on Oct 23, 2010 | Computers & Internet
Great lakes hot tub
Normally f2 is not an error code.
It is informing you that you are in a "Filtration" mode. In this case Filter Mode #2
But, if we knew what make & model of the control system you have, will assist us better in helping you. Spa manufacturers normally do not use their own proprietary control systems. They will use a 3rd party vendors unit & install them on their spa.
Mar 29, 2014 | Pool & Spa
F2 error code
An F2 error code means usually that you have a flow issue in your hot tub or you have a part malfunction. The best thing to do with an F2 error code is to go through a trouble shooting diagnosis. Start by cutting the power and letting the unit cool down and then do a reset of the equipment. If that does not fix your issue then do a water flow check, clean your filters, release air locks, remove debris from your intakes and returns. If your problem still remains look to replace or repair fuses, heater elements, or your circuit board. I hope this helps. http://www.thecoverguy.com/backyard-blast/f2-error-code-trouble-shooting/
Nov 09, 2013 | Great Lakes Spas Pool & Spa
The power went out in town, the power came back on, and the power is on to the hot tub, but we got an F2 code, and it isn't going on to cycle and the temp is at 54 now. What is the F2 code. We have a great...
I need to know what kind of control pack your tub has. If you can open the side panel and tell me what brand the pack is I can tell you what the error code is for.
Nov 03, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
How do I tell if my spa is in standard mode
I don't think this unit has a switch between economy and standard, it must always be in standard mode. Below is filter cycle programming in case you need that info.
Filter Cycle Programming
The first filter cycle begins six minutes after the spa is energized. The second filter cycle begins 12 hours later. Filter duration is programmable at the Master Control Pad for 2, 4, 6, 8 hours or for continuous filtration, (indicated by
"FC"). The default filter time is two hours. To program, press "Temp", then "Jets." Press "Temp" to adjust. Press "Jets" to exit programming.
Feb 01, 2012 | Qca Spas Dream Series Dream Master Hot Tub...
Hot tub keeps running all night keeping me awake. How do you shut it off? It's a Great Lakes.
If the system is the Jacuzzi 52221-05 system mentioned in the subject header, there could be a stuck relay causing the problem and you might need to get a spa technician out to assist you in repairing the problem. However...
If it is a Great Lakes system as mentioned in your message body, then there could be a programming issue allowing the filter cycle to run continuously. Provide a model number off of the Balboa control. Then we can provide you an instruction manual or reference card to assist you in resolving this problem. you can also search our online manuals at our website. You can find them online at:
BALBOA WATER GROUP INSTRUCTION MANUALS
Sep 18, 2011 | Jacuzzi Balboa R574 System for 1 2 Speed...
My hot tub pump will not stop running even after it has reached temperature and completed it's cycle. I have a Balboa Instruments control unit. Any suggestions?
sound like you have the filter cycle set to fc means filters all the time try to push temp button and then pump button. in sequence you want it to be f2 means filters 2hrs every 12 hours
Nov 22, 2009 | Sys BALBOA SUV SYS 5.5kW W/ 120V 1.OHP...
Hello! the pump on our qca majestic hot tub
If you live in cold weather and are not using it much lower your thermostat. If the freeze control kicks on (at about 38-40degrees) it will constantly try to heat the spa to where you have the heat set when the air temp is low. Hope this helps.
Oct 28, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Pool & Spa Logo
179 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
