Question about Kenmore Dryers
Kenmore Quiet Pak 9 HE4, model 110.85866400. When start button is pushed the relay clicks on, timer counts down, but nothing else. Tested power at P1-4 terminal, no power there.
  • 50 Answers
Check the thermal fuse located on the blower housing. If it is blown will not allow unit to start.
Posted on Dec 08, 2016
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
gizmothec85039
  • 147 Answers
SOURCE: How do you start diagnostic on kenmore elite smartheat quiet pak 9 HE4 dryer?
Hope this helps
By Manage My LifeDecember 30th, 2011
Kenmore Elite Dryer HE4 Quietpak 9 Model 110.85091400 has 4 dim lights showing on the console display but won't start or respond
Our dryer just quit working yesterday and I am puzzled. There are four lights very dimly lit on the display. They are the Casual button, the Timed Dry button and two of the segments in the oval time window. I have found the information online about how to test with a multimeter to try and figure out which board is bad. Unfortunately all these instructions require you to have the dryer in the diagnostic mode by pressing the More Time/Less Time/More Time/Less Time in less than 5 seconds. When we do this it does nothing and will not enter the diagnostic mode. When I am testing with the multimeter on the P3/P4 connections I am not getting any readings of voltage at all. Is this because of not being able to get into the diagnostic mode? Should I still be getting readings? I know we have power to the dryer because the light still turns on when you open the door. The cost of buying both the main control board and the front console are prohibitive for us and I would like to only buy the one that is bad. I have also tried the testing with the multimeter on the front console buttons and also get no readings of ohms at all. We have a very busy household with lots of kids and this dryer is very essential to us so the quicker we can get this fixed the better. Thank you in advance for your help.
Posted on Jul 03, 2015
Kenmore elite smartheat quiet pak 9 will not start or power on
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Jun 21, 2014 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite quiet pak 4 will not start. Close the door and hit the power button and nothing happens. Makes the beeping sound but nothing else.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 quiet pak 9 dryer display code
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite gas dryer smart heat quiet pak 9 HE4
possible front control bd ..be sure there is 220 volts to rear connection first
Aug 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
53 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
