Question about Ford Garden
On a 1946 ford 2n tractor, what gear does the governor gear mesh with?
    Sergeant:
  • 237 Answers
The governor is driven by the camshaft gear.
Posted on Dec 09, 2016
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
Jan 01, 2016 | Ford Cars & Trucks
2n ford tractor stalls when i let the clutch out
Your clutch needs adjusted a little more. Not releasing all the way.
Dec 28, 2012 | Ford 8n,9n,2n, Tractor Starter With Drive
Diagrams_For ford 2N tractor starter
If you have not already found the info, I would suggest visiting the following website for some detailed help:
mytractorforum.com
No cost but will have to join to post questions. Likely all info can be had simply by searching the Ford "N" section. Good Luck!!
Oct 29, 2011 | Ford 8n,9n,2n, Tractor Starter With Drive
I'm rebuilding a ford 2N Governor. I see that the Drive shaft and ball fin or divider are separate. Should the divider be a tight fit on shaft to rotate the four balls during operation?
Yes. The balls move outward by centrifugal force. The faster the governor shaft rotates the farther out the balls move until it actuates to limit the fuel flow.
If really helpful, please rate.
Jul 13, 2011 | Ford 2n, 9n, 8n Tractor Left Taillight...
New starter motor and bendix. will not engage with flyweel. starter motor just spins.
Starter motor spins, but does not engage
  1. Check the starter motor for a seized or binding pinion gear.
  2. Remove the flywheel inspection plate and check for a damaged ring gear.
Nov 08, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
Can not remove starter
You mean you cannont physically take it out. Is the starter drive bound up with the ring gear? If thats the case put the tractor in high gear and rock it by pushing on a rear tire to unstick the drive... Need more info.
Aug 20, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
41 9n ford motor not powering up enough
This one sounds like it may still be out of time.
Aug 27, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Garden Logo
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
