Have you followed the instructions regarding cleaning of the reservoir? (Thinking that it may have become limed up with calcium, blocking the water sensor from detecting the water level).
Thank you for your response. No, I haven't. I've tried just about everything else except for that. Will do that now and cross my fingers! Thanks again
Discovered if PH reveals hard water, just mix half tap water and half distilled water. Working like a charm so you were on the right track, Dennis! Thank you again, so much!
SOURCE: hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
SOURCE: Shark Steam Canister S3325 will not turn on when switch pressed
I had a similar problem; disassembed switch and clamped electrical bayonets tighter with a pair of pliers; works good now.
SOURCE: My Scooba floor cleaner
Flush out the solution valve with water (aka "prime the pump"). Use water, not just air, because water will clear any obstructions that may be in the lines. Also, rinse your tank through the four ports on the *underside*-- one round, two oval, one large and curved, all four in a row. Rinse them really thoroughly with warm water, then refill the tank and try the Scooba again. If it doesn't work, call us: 1-877-855-8593.
SOURCE: Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you
need and a manual you can view:
Bissell 7901 Belt and Manual
Testimonial: "just what I was looking for thank you"
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
