Question about Samsung Televison & Video
I have a Samsung Plasma #PN50A550S1FXZA that has vertical lines (think Logic Board) and it will not accept a signal from Comcast/Xfinity (think Main Board). Am I on the right track?
SOURCE: Vertical green lines on screen
IF THE LINES ARE ON LEFT SIDE ITS THE LEFT BUFFER BOARD AND VICE VERSA THEY ARE ON THE BOTTOM OF YOUR TV HOPE THIS HELPS YOU OUT
Posted on Apr 03, 2008
  • 118 Answers
SOURCE: Black Vertical Lines in screen
All I can tell you is that you maybe have left your T.V. on a channel that didn't move for so long, or maybe someone else did and it burnt the screen. Plasma's run off of plasma gas to create the great picture and they collect on the screen and stick. What you need to do is go to your menu and look for "screen burn protection" and put it on white and let it sit for 20 minutes. All of one color such as white doesn't harm your T.V. The only way anything burns is like a bright white line in front of a black background.
Posted on Jan 30, 2009
  • 187 Answers
SOURCE: I had a plasma toshiba 42hp66 it had bad y-sus
Every single time you replace a sustain boardyou must replace both sustain boards because those boards works together.
Posted on Jul 08, 2009
roety
  • 585 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 19, 2009
  • 6 Answers
SOURCE: plasma 42" daewoo edtv black line down middle
Attempting the solder fix is a big undertaking, gaining access to the components is a MAJOR undertaking, and probably not worth your while.
If it is simply one line you might try the baseball Bat fix....
In reference to the "basebal Bat fix" it works on occasion by using percussive force to realign the ribbon cables.
DO NOT use a baseball bat, but use a rubber mallet and with the power off tap gently directly above and below the offending line.
Its worth doing this if yo cannot live with the line.
If you can live with it, leave well enough alone!
Posted on Aug 24, 2009
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Plasma. Why does picture have vertical bar distortion?
Hopefully, it is just the video signal cable. Make sure it is firmly connected or try another cable. If that doesn't work, you will have to have the TV checked by a professional.
Nov 30, 2015 | Samsung BN94-01658B PCB, Main,...
How to i fix my Samsung Plasma TV which has a 3" wide black vertical bar down the middle?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 29, 2015 | Samsung Televison & Video
Samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
Jul 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung HPS5053 Plasma TV
It may due to the Logic board, or Logic Scan board, or the Panel failure.
Apr 19, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Open Questions:
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
