Question about Samsung Washing Machines
Ive replaced the Door lock on my Samsung F/L J845, however it still shows a DE error when I turn it back on.
5 Suggested Answers
  • 30 Answers
SOURCE: Help remove and replace the diaphragm on my samsung J845
The front loader machine should be done by a appliance dealer because this is a diffuclt job and need a lot of patience if you do it. Hope this might help.
Posted on Jun 02, 2009
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting
Posted on Sep 30, 2009
SOURCE: Hi I put some laundry in the washing machine
The door is not lined up properly from manufacture and can't be fixed. Just bang the door until it latches properly. You will hear a click. When I close mine I slam it.
Posted on Sep 25, 2010
  • 137 Answers
SOURCE: We have a Samsung J845 Front Loader. The door lock shorted out so we replaced it with a new one but now are just getting a DE error.
DE is door lock error possible main pba or wire harness check connections on new switch first .ohm wire harness If you can to check for break in wire
Posted on Mar 13, 2016
My samsung wf8500nhs gives a dE error. Why?
that is a door lock error, i would try replacing the door lock first and check the wiring to it as ive seen the wiring melt a few times
Feb 10, 2017 | Samsung Washing Machines
Mar 12, 2016 | Samsung Washing Machines
What does the code de stands for
On front-load washers, it can stand for "door error", meaning the main control board thinks the door is open. If the door is actually closed and the de error won't clear, the electric door lock could be shorted, giving a false signal to the main control board. On the Samsung top-loader, it means a "child lock error" has happened. On that washer, you will see "CL" or "DE", the washer will auto-drain and an alarm will sound. To clear the error, close the door, turn off the power, then turn it back on.
Aug 21, 2015 | Washing Machines
Door won't close on J845 front loader
Replace door lock. Also check tightness of hinge v
Nov 15, 2017 | Washing Machines
We have a samsung j845 top loader and a de error came up while it was washing and i cant even drain the clothes
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault.
The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board.
If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Aug 30, 2010 | Samsung WF337AA Front Load Washer
Hi I put some laundry in the washing machine (j845) and the door won't lock. It keeps saying error de although the door is very much closed.
de stands for door error.  electronics not sensing door open or shut.  could be bad control pcb or bad door switch ( solenoid ) or wiring harness...
Jul 08, 2010 | Washing Machines
Door to my sumsung j845 will not unlock
i have the same problem and i rang samsung and they told me how to reprogram the machine. They told me to turn it off at the power point for 45 minutes, then plug it back in and turn the power on (not the machine)  and leave it for 15 minutes, then turn the machine on and hopefully it will unlock within 5 minutes. I had no luck with this so am getting someone out today.. hope you have better luck!
Jul 14, 2009 | Samsung WF203ANW Front Load Washer
Error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Jan 26, 2009 | Samsung WF337AA Front Load Washer
Wont start has error DE
Error displayed table_1.gif Solution
n_de.gif table_2.gif i_1.gif Close the door.
n_4e.gif table_2.gif i_1.gif Make sure the source water faucet is turned on.
i_1.gif Check the water pressure.
n_5e.gif table_2.gif i_1.gif Clean the debris filter.
i_1.gif Make sure the drainage hose is installed correctly.
n_ue.gif table_2.gif i_1.gif Laundry load is unbalanced; loosen any tangled laundry. If only one item of clothing needs
washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an "UE"
error message will be shown in the display window.
n_3e.gif table_2.gif i_1.gif Call after-sa
Dec 07, 2008 | Washing Machines
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
