Question about Miscellaneous
Cant find a place that sell battery for defiant solar light model 84045
Where can i get one?
    Master:
  • 332 Answers
  • 10,263 Answers
Defiant 84045 Use and Care Manual Page 8 Contact Home Depot for that battery.
Posted on Dec 04, 2016
Can I use this telescope to view the solar eclipse and if so, how do I do this safely?
Only if you have a white light filter. You can make one or you can buy one, I have done both.
Here are a couple of helpful links. The first one explains white light filters.
http://starizona.com/acb/basics/equip_filters_solar.aspx
This link is a place that sells the material.
http://www.astronomyalive.com.au/accessories-14/telescope-accessories/solar-viewing/baader-astrosolar-safety-film-custom-sized-white-light-solar-filter-material.html
Cheers .,. Bob
Mar 19, 2015 | Celestron PowerSeeker 70 AZ Refractor w/...
How do i operate smart solar lights?
Place the solar panel in a sunny spot to charge the batteries. If the lights do not come on at night, the panel's light sensor may be seeing other light sources and needs to be moved. The light sensor looks like a small white circle with a wavy line across it. They are usually visible and located in the solar panel. Make sure it is in the dark at night, or it will not come on. You can cover the light sensor to test that the lights are working.
Jul 08, 2014 | Smart Solar Solar String Lights 20 LEDs...
Model 7000 slide not working
I have a Defiant 7000 flashlight and took a look. When the light is closed, the top of the battery door (1) is right at the lip (2) that keeps the light from over extending. I couldn't get mine to close with the cover loose, but if you did you could carefully drill a hole (3) in the outer casing to see and push the battery door back into place. You could also remove the two philips screws under the rotating magnets on the base and maybe push hard enough to force the top out?
Feb 22, 2014 | Defiant Camping, Backpacking & Hiking
Solar Charge controller Model 16-24 amp. The solar
Have a load test done on the battery as if there is dead cell it will not allow a charge because there is no circuit.in the battery
Sep 19, 2013 | Juicers
My older charger has been sitting for 10+ years and the battery wouldn't take a charge when I pulled it out of storage. How do I remove and replace the battery? Magnum 12 Solar Pak unit.
take the unit and place it in front of you. place your left hand at the top left hand corner of the solar panel. with the heal of your right hand strike firmly on the bottom right corner of the solar panel. alternatively take a flat head screw driver and locate the divot on either of the short sides of the battery case. below the divot find the edge of the battery case lid and pry the top of using the screwdriver.
Aug 15, 2011 | Parmak Solar Fence Charger
I bought a 10 pack of Westinghouse Solar Lights and placed them in my garden about two years ago. Only about 5 of them light at night now. All the rest are getting em ough sun light everyday. Is there...
Most of the solar lights use a stadard 1.2 volt 850 mh nicad rechargable AA size battery and you can get them at your local Home Depot store. You also might try to clean the solar cell on the light they seem to get a film over them that stops some sun light from reaching the solar cell.
Aug 26, 2009 | Garden
Miscellaneous Logo
102 people viewed this question
Top Miscellaneous Experts
Gene Haynes
Betty Kent
Betty Kent
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
