2002 dodge caravan 3.3 liter v6 ac blowing warm. Refrigent appears ok. have it on 30 psi running. replaced clutch fuse. relay fuse ok. passenger side and rear blows less warm than driver side. Believe compressor is kicking on properly.
    Problem Solver:
  • 18 Answers
I assume you are charging this unit with cans from aparts store. If so the guages sold in those kits are not the best. That said I believe you are still low on refrigerant. Wear saftey glasses while working on A/C systems, and follow all saftey instructions. Then with a helper inside vehicle, run engine at appx. 2000 rpm. add refrigerant untill pressure stays at 35 psi with both blowers on high.
Posted on Jul 20, 2009
04 navigator is blowing ac fuse 11, ac coil shorted, 3 different coils, can ac compress short the coils
How did you hook up the inline fuse to compressor and ground to compress ? Ground what ? Right at the clutch coil ? You have to be hooking it up wrong . The compressor can't cause the clutch coil to short or blow the fuse , even if the compressor were seized up . An before that would have the serpentine belt would burn up , squealing noise. applying B+ voltage in the relay socket ,pin 30 to pin 87 will engage the compressor clutch . If the fuse blows the wiring from the relay to the compressor clutch is shorted to ground . Look for rubbed through wiring harness .
Jul 14, 2017 | Ford Cars & Trucks
I have 2002 Chevy s10 with ac issues. All blend doors and actuators work properly. Clutch engages on compressor. Blows warm air when ac is on. When I put a guage on it the psI stays on max and doesn't...
Yes. When you turn on the compressor via clutch Suction line pressures at around 3000 rpm should be around 30 PSI. If pressure stays high it is because the compressor is running but it is not doing squat and needs replacement - bad reed valves.
Sep 04, 2017 | Cars & Trucks
No ac.......worked yesterday, not today
CHECK BLOWER MOTOR FUSE AND RELAY.IF BLOWER MOTOR GOOD STILL BLOWING.CHECK AC COMPRESSOR FUSE AND RELAY.IF COMPRESSOR FUSE AND RELAY GOOD.CHECK AC LOW SIDE PRESSURE SHOULD BE 28 - 30 PSI AND HIGH SIDE PRESSURE SHOULD BE 200 - 220 PSI. IF PRESSURE GOOD THE COMPRESSOR CLUTCH COIL COULD OPEN.CHECK DRIVE BELT MAKE SURE NOT LOOSE AND SLIPPING.
Oct 24, 2010 | 2005 Nissan Frontier
2002 ford mustang air conditioner stopped working. How do I locate the problem?
FIRST I CHECK ALL FUSES AND RELAY.TO BLOWER MOTOR IF IT STOP BLOWING.AND CHECK FUSE TO HVAC SWITCH CONTROL.AND CHECK FUSE / RELAY TO AC COMPRESSOR.IF FUSE / RELAY GOOD POWER GETTING TO AC COMPRESOR CLUTCH COIL AND LOW PRESSURE SIDE 28 PSI AND HIGH SIDE 200 PSI. CLUTCH COIL IS OPEN.IF REFRIGERANT LEVEL LOW YOU MAY NEED MORE REFRIGERANT.YOU NEED AT LEAST 28 PSI ON LOW SIDE AND 200 - 220 PSI ON HIGH SIDE.IF ALL IS GOOD STILL NO AC PROBLEM COULD BE A FAULTY AC CLUTCH CYCLING PRESSURE SWITCH.
Aug 16, 2010 | 2002 Ford Mustang
2000 Dodge Grand Caravan AC blows warm
If the compressor is running and you have the same temp on both tubes the compressor is probably shot. You need to check the pressure on the high side too. It should be around 200.
When you replace the compressor, make sure you also replace the accumulator, orifice filter and flush out the evaporator and condenser. The only moving parts on the ac system is the compressor and often when it fails it will put small metal particles into the a/c system that will cause your new one to fail.
Hope this helps.
Aug 20, 2009 | 2000 Dodge Caravan
Ac blow warm air
need to have a set of gauges on it and read the low side and high side to see if pump is weak that year compressor i think is on the bottom passenger side ,it is not a good desigh pump may be weak
Jun 29, 2009 | 2002 GMC Yukon Denali
Ac problem
if the compressor is not engaging,the clutch on the front of compressor may be faulty..remove a/c clutch relay from fuse block underhood and jump relay pins 30 and 87 with engine running..clutch should engage..make sure you have power on pin 30
you may have a faulty a/c pressure transducer
Jun 20, 2009 | 2002 Dodge Stratus
99 corolla ce 4dr sedan, blows 7.5 amp ac fuse after running fine
BBB Industries should have the TSBs and wiring diagrams for this as well .
Apr 05, 2017 | 1994 Toyota Corolla
2002 Dodge Caravan (3.3 liter V6) air conditioner clutch?
you can but part is usually about the same price
Nov 11, 2008 | 2003 Dodge Caravan
Air conditioning
here is a link to your problem and a solution:
http://en.allexperts.com/q/4-Wheel-Drive-2700/2008/5/C-Clutch-engaging.htm
Jun 15, 2008 | 1999 Dodge Intrepid
Heating & Cooling Logo
200 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
