Question about Car Audio & Video
Cd stuck in sterio aparently there is a reset button to push and release cd.were is the button?
  • 332 Answers
I'm not aware of any button on car cd units. Usually when a cd is stuck in the unit, you need to take another cd, open the door and gently lift or pry up the stuck cd to release it.
Posted on Dec 04, 2016
How to release a disc from laptop button stuck
Most cd or dvd in computewrs have a small hole them in the door. You will need a paperclip. Straighten it out insert the paerclip into the hole and push gently but firmly. This will open the door up and allow you to retrieve the disk
Aug 19, 2014 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Bose 6 disc cd player reset button
Acura RSX-type S where is the reset botton on a Bose 6 disc in-dash cd player. I have a CD stuck in the CD player. Need help getting it. Everything I read is telling me to push the reset button.
Aug 17, 2012 | 2005 GMC Envoy
Bose 3 cd playerdisc error will not eject
Try to use an old CD...and insert it under the stuck CD...push in slightly while using the eject button...on may models this will release the stuck CD...Hope this helps.
Nov 25, 2011 | Audio Players & Recorders
I have a Dell Demension 5100, and the power button got stuck. By stuck, I mean that the power button is pushed in, but not released. It's stuck as if you pressed the power button, but did not release...
if your PC have restart button then open your PC and check the power cable slots and change them into a reset mode removing reset cable to reset slots and attach to power slot. Then you can power your pC with reset button. If you can open front case then you can outside the button .
Sep 15, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
How do i reset a sterio code for a 2000 audi a6
urn on radio - the word SAFE will appear in the display. Press th P.SCAN and RBDS buttons simultaneously and hold them down until "1000" lights up in the display.Release buttons.Do not, under no circumtances, continue holding them down or press them once again. This will cause the radio to consider the number 1000 to be the input code.Use station buttons 1,2,3,and 4 to enter the code number on your Radio Card. Use the button 1 to enter the first number 2 for the second number 3 for the third number and 4 for the last number.Once you have entered the code and it shows on the display,press the P.SCAN and RBDS buttons down again simultaneously and hold them down until the word SAFE appears in the display.Release buttons. Soon afterwards a frequency will be displayed.
Dec 15, 2009 | 1996 Audi A6
Pause button is stuck
hi soblessed,
the plastic push lock that holds the button is possibly broken, but hopefully the mechanism incorporated with the button has not been damaged because it was pushed too far.
to have this issue resolved, you may use something pointed to nudge the button from its place and free it from being stuck. Or you may remove the screws from the button, freeing the upper case from the lower case exposing the other side of the controls, so you can push the pause button out.
Apr 19, 2009 | Emerson PD6870RD Radio/Cassette/CD Boombox
Peugeot 307 04 plate
just disconect leads on cd changer should reset
Dec 06, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
there should be a little pin push button on cd changer (kinda hard to see) that you put a pin into front it releases the cd dock you should be able to get disks out that way the other way
after this is done take your car sterio to a service sterio technition and have your deck cleaned and serviced so that you can enjoy it for a long time
May 08, 2008 | Car Audio & Video
CD stuck in tray for DXZ648RMP player
Figure out what fuse controls the CD player and pull the fuse out for a minute (or more), then replace it (theory being that the fuse acts as a reset button). If you cannot find the fuse, you can disconnect the negative battery cable, but you'll lose your radio and other settings. This trick seems to have the greatest chance of success overall.
Turn your ignition on to the accessory position. Hold the eject button down for 2 or 3 minutes. Depending on your make/model, the eject button may flash. When the button stops flashing (or when a few minutes has passed), release the button and immediately press it again (theory being that the two minutes of "work" followed by a quick break will fool the player into releasing the disc when you press the eject button again).
Try using some tweezers, needle nose pliers or hemostats (every tool kit needs a hemostat or two!) to pull the CD out while pressing the eject button with power going to the player (theory being that the disc is so slick the player can't eject it without help). Some people report success just by pulling the disc out with the tweezers without power to the player and without pressing the eject button.
If your player has a small hole in the front of it, like most personal computer CD players do, straighten a paperclip and push the clip straight into the hole to manually release the catch. Some players have a groove under the CD door instead of a hole. Look for a hole about the size of the paperclip and don't mistake an emergency release hole for an earphone jack.
Jan 23, 2008 | Clarion DXZ648RMP CD Player
Car Audio & Video Logo
67 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
