Error 23 I need customer care - Office Equipment & Supplies
What is gmail customer care number?
If you find any difficulty doing that call us immediately at Gmail Customer Service Number +1-844-773-9313 or visit here: - https://gonetech.net/gmail-technical-support-phone-number/. Experts are online 24*7 days to Gmail customer. If you are using Gmail account and facing some technical error then don't hesitate just contact to Gmail customer care number and consult with the Gmail expert.
Feb 05, 2016 | Computers & Internet
What is error code E3 on Wristech wrist blood pressure monitor Model HL 168ZA
The E3 Fault Code means Error in determining measurement data. In which case, measure again. If this continues to happen contact HoMedics Customer Service @ 800-466-3342.
http://blog.suntechmed.com/blog/23-abpm/310-top-5-reasons-your-automated-bp-monitor-gave-an-error-code
Feb 25, 2015 | Health & Beauty
Winterhalter error codes 23
Call customer support
Jul 07, 2014 | Dishwashers
Precore 9.31 error 23
Precor Error Code 23 Error Code: 23 Manufacturer: Precor
Model: All Models
Error Description: Error 23, Motor Pulses Missing after Start Up - Indication that the speed sensor signal was lost while the unit was in operation. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Intermittent connection of speed sensor or drive motor wiring.
  5. Badly worn drive motor brushes not able to make proper contact with drive motor commutator.
  6. Faulty lower PCA.
  7. Faulty interconnect cable between upper and lower PCA.
  8. Faulty upper PCA.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Test all wiring and wire connections of the speed sensor and drive motor. Replace or repair necessary wire connections or wiring.
  5. Inspect and replace drive motor brushes if necessary.
  6. Determine if the lower PCA is bad by swapping with a known good lower PCA.
  7. Determine if the interconnect cable is bad by swapping with a know good cable.
  8. Determine if the upper PCA is bad by swapping with a know good upper PCA.
Jan 25, 2014 | Precor Exercise & Fitness
Fisher paykel recall
have you tried calling the customer service line for fisher and paykel in the usa http://www.fisherpaykel.com/customer-care/contact-us/
Feb 04, 2013 | Fisher and Paykel 23 in. DD603H SS...
I have accidentally blocked my Aircel no. 8575163316.. Can't u please giv me the PUK code no. ??
Contact Aircel customer care and ask for the PUK code, they will supply you with the needful after verifying you identity.
Aircel customer care:
S.No. Circle From Any Number From Aircel Number Only 1 J & K 9858012345 121 2 Chennai 9841012345 121 3 Rotn 9842012345 121 4 Kolkata 9804012345 121 5 WB 9851012345 121 6 Orissa 9853012345 121 7 NE 9856012345 121 8 Assam 9854012345 121 9 HP 9857012345 121 10 Bihar 9852012345 121 11 Delhi 9716012345 121 12 AP 9700012345 121 13 Kerala 9809012345 121 14 Karnataka 9738012345 121 15 Mumbai 9768012345 121 16 UP(E) 9807012345 121 17 UP(W) 9808012345 121 18 ROM 976212345 121 19 Gujarat 9722012345 121 20 Haryana 9802012345 121 21 MadhyaPradesh 9806012345 121 22 Punjab 9803012345 121 23 Rajasthan 9782012345 121
Apr 11, 2011 | Nokia Cell Phones
Our panasonic scanner has a error message that states " place paper in feeder" There is paper in the scanner to be scanned. How do we get rid of this error???
This error occur for some reason, please check each one:
1; ADF document feeder is not closed really and
2; You are put the documents into a wrong place
3; the sensor of the ADR is wrong or is dirty (in this case you need a mechanic)
Please read carefully the ducument below (be care of page 23)
http://office.manualsonline.com/regman/exit/ct?url=aHR0cDovL3NlcnZpY2UudXMucGFuYXNvbmljLmNvbS9PUEVSTUFOUERGL0tWUzEwMjVDLlBERg,,&target=productDoc&idDeviceType=2727&idMfg=1569&idProduct=191533
Rgd,
Sly
Nov 22, 2010 | Panasonic KV-S1025C
Why does my phone say sim crash
There is a physical issue with your Sim card reading: Sim may have been slightly dislodged if you accidentally dropped or subjected your mobile to vibration: in most case, just remove the battery AND Sim for a few minutes and carefully re-install both Sim (make sure it fits squarely in the socket/cradle) and Battery and Cover. It should reset the phone.
Hope it helps!
Dec 25, 2009 | Samsung SGH-D600 Cellular Phone
27 people viewed this question
jasbo
jasbo
