Question about Samsung Televison & Video
Screen goes black while watching a show
Samsung 50inch smart TV. Sound is still on
tvtechnician
  • 105 Answers
SOURCE: samsung lcd tv
that is deafinatly a fault. take it back to the store asap if you can. what the tv needs to be fixed is first replace the main and power board and if problem persist the lcd panel will need to be replaced.
Posted on Nov 07, 2007
SOURCE: Screen Problem
I have been trying to fix one of these tvs and found out from a repair man that the lower half going blank means a problem with the lower buffer. and that is also what the manual I downloaded says.
have you checked that?
Posted on Jan 25, 2008
BMW Rider
  • 232 Answers
SOURCE: Sony Trinitron - Picture Disappears
Hi, IK circuit is engaging which basically means the picture tube is getting tired, the only "fix" is temporary (may get another year out of it). You have to increase the "screen control clockwise".
Remove back of set, follow large black or red wire attatched to picture tube down to the flyback transformer, mounted on flyback are two black controls, one is focus (leave it alone) the other is "screen", adjust it clockwise approx. 1/4 inch, remember that this is a high voltage circuit so use one hand in the set the other hand out of the set at all times,any questions ? e-mail me back, good luck, BMW Rider
Posted on Feb 27, 2008
praky16
  • 744 Answers
hi....Your tv picture is managed by several boards, the two specific ones are the ysus and the xsus. The Y controlls the horizontal pixelation and the X the verticle, if you are having horizontal problems then its the Ysus thats faulty, on this particular set, the Ysus board has two accompaning buffers that are particularly troublesome. I've had more than one of these sets in the shop recently with the same ailment.Sounds like your buffers are starting to go out. The screen is split horizontally by the two long skinny buffers attatched to the Y main, if the bottom one has one leg in the grave you'll be getting a partially black screen or no picture at all. The colored lines running through the screen are more typical of a failing buffer. Are you interested in taking this set apart and putting a couple hundred into fixing it?  When buffers go they usually take the Y main too. Worse case scenario you're gonna be out about $350 dollars to fix it yourself. Best case, a ribbon is loose on the bottom buffer and with a dismantle you'll be able to connect it again..
thank u rate me!!
Posted on Feb 12, 2009
budmrtn
  • 11361 Answers
SOURCE: tv screen went black and no sound
Look at the power supply first; look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find. It sounds like at least you do have the 5V standby power supply working but the main supply is not getting the 'ON' command from the main board, or the power supply is gettin ght e 'ON' signal but failed to turn on.
Posted on Dec 02, 2009
Every 3-4 minutes screen goes black and Smart TV logo appears; 2-3 seconds returns to program I'm watching (live TV0.
Hello
Open your set, disconnect and reconnect all the connections
Probably a connectivity problem
Good luck
Apr 06, 2016 | Samsung UN50F5500 50-Inch 1080p Smart LED...
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
Jan 11, 2016 | LG 42LS5700 42 Inch 1080p 120Hz Smart TV...
When the TV is plugged in the screen is black,little red power light bottom right corner blink 5x then you hear the sound of power on pause then power off. This continues to repeat and no picture.
Repairing Flat Screen TV - Blacked out with blinking red light
? 12:00
https://www.youtube.com/watch?v=3GmtBthpzDk
Mar 15, 2012 - Uploaded by n1bpd
Repairing Flat Screen TV - Blacked out with blinking red light ...Capacitors are little cylinders with a flat top with an X. If they have failed the X .... picture, no sound, totally black just the red power light blinking on the corner ... hello i have a dynex dx-lcd42-09 the red light blinks as soon as i plug it in i opened ...Missing: 5x
comments on EASY HOW TO FIX SAMSUNG TV- NO POWER
https://www.youtube.com/all_comments?v=hgcmWO7mqmo
Dec 16, 2015 | Samsung 55" UN55D6420 3D LED TV Smart TV
I have Samsung 46" rear projector TV the TV just went blank
? 3:16
TV Repair Help for a TV With a Black No Image on the Screen ... the show I'm watching and then it turns ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
i have SAMSUNG led tv with NO picture and there is back light and sound OK, ... Apparently the TV was on ...
Dec 15, 2015 | Samsung Televison & Video
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Televison & Video Logo
29 people viewed this question
Henry  Thomas
Henry Thomas
