Question about Krups Coffee Makers & Espresso Machines
KRUPS FDH212/stainless steel - Krups Coffee Makers & Espresso Machines
How do i clean my stainless steel krups coffee maker before use model kt 611d50
Just run one full pot of cold water through it. Do not add coffee. Then it is ready for use. Caution - Do not make coffee right away because you can break the glass carafe by adding cold water to a hot carafe. Also the hot plate would be very hot too.
May 30, 2014 | Krups FME2 Coffee Maker
Need to find the instruction manual for Krups Rice Cooker/Steamer/Slow Cooker, Model # SERIE R02
The model number is actually FDH212. Here's the manual from Krups USA: http://www.krupsusa.com/NR/rdonlyres/B538D70F-8F15-4BB9-92CE-9E493621DC11/7356/Ricecooker_usa.pdf
Jul 24, 2010 | Krups RK7011 Rice Cooker
The heating element in Krups stainless kettle has burned out
the element is avilb on the web / look under small appliances / or better yet use your model # and google it . the cost of element and shipping may be more than your pot is worth . you be the judge . i would fix it but / it may not be cost efective .. hope this hepls **** ..
Dec 23, 2009 | Krups Stainless Steel Electric Kettle...
We lost instuctions on our krups coffee/cappuccino maker dont know how to use
XP4050 Krupps
pumps water through machine into drip tray not through coffee anymore
Apr 26, 2009 | Krups Cappuccino/Espresso Maker -...
Broken Krups FMF5-14 Stainless Steel 10-Cup Coffee Maker?
My Krups was not working after I accidentally forgot to place the black plastic lid on the coffee carafe BEFORE starting to brew a new batch of coffee. The coffee will not drip into the carafe without the lid
in place. Because the lid is hidden when placed in the coffee maker, it's easy to forget! The coffee all backed up in the filter area and overflowed. The display got wet. Not good.....
If your buttons and or display is not working ( mine got wet with coffee) simply flip the coffee maker over. Unscrew the bottom. expose the display circuit board carefully, DRY it with a HAIR DRYER and put the unit back together! Presto! Mine is working again.
If you need a new circuit board, you can get one for $35 from Appliances.com I found. They also have the Duo filter and extra parts cheaper than the Krups website.
Feb 22, 2009 | Krups FMF5-14 Stainless Steel 10-Cup...
Krups fmf 5 water leaks from the bottom of coffee maker
I took the bottom off mine and found that a hose that connected to to the water level tube had become disconnected.
In order to get the bottom off you need a Torx internal tamperproof pin (6 lobe) screwdriver to get the 5 screws out.
Jul 23, 2008 | Krups FMF5-14 Stainless Steel 10-Cup...
Krups FDH212 10-Cup Rice Cooker Problem
Anybody have a solutions for this? I have the same problem.
Sep 30, 2007 | Krups FDH212 10-Cup Rice Cooker
Coffee Makers & Espresso Machines Logo
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
