Question about Sewing Machines
It won't pull thread up and sew - Sewing Machines
  • Sewing Machines Master
  • 11,774 Answers
If a brand new needle (installed correctly) does not improve the stitch, the machine has probably been knocked out of time. Search for sewing machine timing or take it for service.
Posted on Dec 05, 2016
  • 654 Answers
Try your bobbin to see if the thread can pulled using your fingers. 1. If it is too tight you may have to loosen it slightly. (let bobbin hang from finger and bob it up and down: It should move about one inch downward)
2. Try physically to pull the thread through the upper tension while the foot is down. Adjust the tension to many positions to see if it is making any difference to the tension of the thread.
3. When you feel it is functional begin the tension at four and the sewing should be noticeably better. (Many machines need to be adjusted just right to get that perfect stitch)
4. Remember to always start with good needle and installed properly.
  • 980 Answers
SOURCE: my 16221 sewing machine won;t pull up bobbin
If you are sure the needle is good and in the correct way round then you may need to retime the machine, I can attach instructions if you email me drivewithken@blueyonder.co.uk
Posted on Mar 24, 2010
  • 980 Answers
SOURCE: Singer Golden Touch & Sew
Try a new needle first failing that you may need to retime the machine, you can email me for an attachment of instructions kendourof@yahoo.com
Posted on Aug 27, 2011
SOURCE: When sewing, the thread keeps
have you tried using a new needle- if the needle is the slightest bet bent or or damaged it can cause problem with the fabric threads
if the needle is not the correct one for the fabric, it can move or damage the fabric threads
also clean under the needle plate for loose threads or lint also in the bobbin area
Posted on Aug 29, 2011
SOURCE: Husqvarna Huskystar 207 Sewing Machine not
Be sure not to use Singer Needles. They are longer than standard needles. Don't know if this helps, but I did this once on my Huskystar 207 and that is what happened. It also damaged the bobbin thread.
Fairleigh
Posted on Sep 21, 2011
marigold1m
  • 3 Answers
SOURCE: singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Posted on Nov 28, 2011
The bobbin turns when I manuall pull the thread but won’t turn whem I step on the foot pedal
that would be correct
pulling the thread is what turns the bobbin
the needle thread pulls the bobbin thread up and is what makes it turn
Sep 19, 2017 | Sewing Machines
Sunbeam Portable sewing machine won't sew
If you definately have it threaded up properly, follow the thread all the way through the route of "threading up"there could easily be a bit which is catching, or try another thread I have found a lot of low quality threads about
Jan 05, 2013 | Sewing Machines
Needle won't remain threaded
make sure the thread has long thread tails of 4 to 6 inches long
and have the thread tails pulled behind the needle before starting
to sew.
Jan 04, 2013 | Michley Lil Sew Mechanical Sewing Machine
Husqvarna Huskystar 207 Sewing Machine not stitching. It won't pull the bobin thread up to sew.
Fairleigh
Sep 18, 2011 | Husqvarna Huskystar 207 Sewing Machine
When sewing, the thread keeps pulling the fabric threads and the result looks messy. I've tried playing with the thread tension but it won't help.
Aug 29, 2011 | Brother CS6000i Computerized Sewing...
Needle won"t stay threaded
that use to happen to me on my sewing machines, I would rethread the machine to make sure the thread is not caught on anything like the thread spool, or around anyone of the thread guides
also for both top & bottom threads, I keep a thread tail of 3 to 6 inches & before I start sewing I pull the thread behind the needle to the back of the machine & the I put the fabric under the foot & start sewing & now I don't have that problem anymore
Aug 24, 2011 | Singer 3116 Simple
The needle is threaded top and bottom but when I run the machine to sew the thread isn't sewing on to the fabric..I'm not sure but I think the thread around the check spring holder is midway or rather not...
Recheck the threading on the top side. When you pull the thread at the needle is there tension on it? If there is no resistance than there's no tension. If it breaks it is either not threaded correctly or the tension is way too tight.
If that is correct and the the thread on the bottom has a little bit of tension when you pull on it, it should stitch --- However not stitching at all can be from having the wrong needle, wrong brand, type, or in incorrectly. Sometimes even the wrong size can prevent stitching, like when youre sewing through heavy/thick material and using too small a needle.
Check out those three things and then see if it won't sew correctly for you.
Apr 21, 2011 | Euro-Pro 801B Sewing Machine
My bobbin thread won't pull up. I tried what was listed to do, but it didn't work. Please help me~!!
Here are some things to check:
1. check the threading and tension of the top thread. It may look like it's threaded correctly but not be. When you pull on the thread is there some tension but still pulls out? Make sure it isn't catching somewhere on the path. Also make sure it's not too loose. If it's too loose it won't be able to pull the bobbin thread up enough.
2. check the bobbin threading and tension. Does it have some give but not reel out a ton? Is it catching? Is the bobbin in all the way - hear a click when inserting it?
3. Do you have the right needle for the machine? Is it inserted correctly? Try sewing through ordinary cotton first. Is it stitching? If so then you may not have the correct needle size for what you are trying to sew through.
Mar 31, 2011 | Brother XL-2600
The machine won' tsew as if the tension is too tight any ideas?
try rethreading the machine top thread & bobbin
try a tension of 3 or 4
make sure the thread move smoothly around the tension disks
make sure before threading the needle that the thread pulls smoothly
Nov 17, 2010 | Brother XL-5130 Mechanical Sewing Machine
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
