Do I have to change from hdmi to another setting to play my dvr? On my old tv I would switch to another mode like component or tv. Accessed thru my tv remote.
SOURCE: Samsung TV Mode not supported message
check to see if the output is set to 480i. HDMI does not support 480i - http://samsungplasmatvfaq.com/index.php/Display_settings
Posted on Nov 19, 2007
The Machine
  • 788 Answers
SOURCE: How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Posted on Jul 09, 2008
SOURCE: need comcast dvr remote code for toshiba 14dlv75 lcd/dvd
code TV/ 0156 or TV/ 1256 (or TV/ 10156 or TV/ 11256
Posted on Dec 04, 2008
satavlad
  • 405 Answers
SOURCE: Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Posted on Nov 28, 2009
SOURCE: Can't access my DVR remotely via Video Server E
Try checking to see that you set up the DNS address correctly on the DVR itself. Either set it to the router (typically 192.168.x.1) or the same DNS address as the router.
Posted on Dec 05, 2009
Can't record from box/dvr to a dvd-r
get a new one amd instage it and tell the manger that it is not working
Dec 26, 2013 | Toshiba DR410 DVD Recorder
I have a Denon avr-3808ci. I have a Dish Network DVR and a Sony KDS-60A2020 tv. If I connect the HDMI cable on the DVR directly to the tv, I get picture and sound through the tv. If I connect the HDMI...
You are correct. I feel your pain. This will not work.
HDMI is a pure digital signal and the providers require the content coming over the Dish DVR to be COPY PROTECTED. So it will not work unless the HDMI cable goes directly from the DVR to the TV. This is to stop people from being able to make their own recordings of Dish shows, or making copies of your DVR recordings. If you really want to run things through your reciver, you're going to have to use the "component" or "composite" video feeds, not the HDMI. Sorry.
Sep 18, 2011 | Denon AVR 3808Ci Receiver
How do I convert from HDMI-in to Component-Out? Basically, I'd like to have my cable box (Comcast DVR) coming into the receiver using HDMI but would like to output to my TV using Component instead of HDMI....
looking at the manual here that should work for Video http://www.onkyousa.com/download/own_manuals.cfm?cat=Receiver
it looks like on the receiver you would have the DVR connected via HDMI cable to the receiver On the receiver you would select this HDMI as the input. That should automatically allow that signal to be presented to the component out on the receiver you connect the cables from component out to the TV and switch the TV to select the component input -depending on the TV model this may be labeled AV1,2,3,4, etc No sound will be transferred to the TV as component is Image ONLY whats the make and model of the TV
Mar 20, 2010 | Onkyo TX-SR606 Receiver
I have bose v30, dishnetwork 612 dvr. When
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues.
What is happening is that when video resolution changes (like from regular programming to commercials) the video information is poorly sent down the HDMI line. Component cabling from your DVR will eliminate this problem.
I hope that helps.
Feb 06, 2010 | Bose 36037 Remote Control
Nov 28, 2009 | Yamaha RX-V463 Receiver
When I connect HDMI from a Time Warner DVR to my Vizio thru a DVI/HDMI adapter, I get no sound. I can only get sound if I use Component input (RGB+ audio R&L). Is this a DVR issue or a Vizio issue?
Use the Time Warner remote and hit the settings button twice. Scroll down to "audio: digital out" and select HDMI. That solved it for me.
The only issue I have now is that I also have component sound outputs going from the cable box to a receiver. When I turn off the TV while the HDMI cable is hooked up to both the box and the tv the sound goes out to the receiver...
Nov 15, 2009 | Vizio P42HD Television
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
Jul 09, 2008 | Denon AVR-3805 Receiver
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Apr 09, 2008 | Arris DCT2608
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
