My bliss lights spright motion green light - all the laser does is blink.... any suggestions to trouble shoot? we tried unplugging and plugging back in without any success... thank you
  • 1153 Answers
SOURCE: My TV won't turn on. The Green light just keeps on flashing
1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067002 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001
Posted on Sep 05, 2007
  • 375 Answers
SOURCE: Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Posted on Sep 12, 2007
designer7
SOURCE: Blinking Green Light
Hmm I tried unplugging it for a while but I will try this again tonight since it will be unplugged for about 24 hours.
Thank you McColp for the info..
I have a service guy coming tomorrow, maybe this will work before he comes! I appreciate your help!
take care
Maria
Posted on Nov 02, 2007
SOURCE: blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Posted on Sep 19, 2008
Slinteriors
  • 8617 Answers
SOURCE: Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Posted on Jul 18, 2009
Will not charge
Sounds like you have a bad battery. Check your users manual for how to change it.
May 01, 2017 | Nikon COOLPIX S9500 Digital Camera Black
Green light flashing on circuit board
Is there any problem with it?? I think you may be referring to the LAN adapter's blinking green light, if if is blinking while the computer is on and an ethernet cable is plugged in it is perfectly normal... otherwise please elaborate on the problem.
Jan 08, 2014 | Dell Dimension XPS PC Desktop
I have a honeywell pilotless hot water heater control model wv4460e. This unit is not working and I was trying to trouble shoot it. I have tried to unplug it and plug it back in and it seems like the...
The blinking light is actually an error code. See the trouble shoot section in the manual: http://www.bradfordwhite.com/images/shared/pdfs/manuals/45960A.pdf
Jan 28, 2011 | Kitchen Ranges
Blinking green status light
Unplug for a few minutes then plug back in to try to reset it. Sometimes it could take as long as overnight before pluging back in to reset. Number of blinks is usually a trouble code.
Mar 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
We have a Mitsubishi Big screen projection tv model no. VS-50705. when the on button is pushed it clicks like it wants to turn on but then doesnt. When I unplug and plug back in the green light flashes...
This could be a trouble code for your model television. Try counting the blinks and note any pauses in blinking. It could be a one or two digit trouble code. Then once you have that number, type in your tv model along with the words "trouble codes" or "diagnostics codes" or "green light blinking" and see what you get. Hope this helps...
Jan 08, 2010 | Mitsubishi WS-65712 65" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinking green light, will not power up
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
How can I fix it
its definately a power supply issue. You may want to get a service manual for your model as it will have the info to trouble shoot the standby and start up voltages. You can get a manual emailed to you at the following link and they will help you trouble shoot the set. Heres the link.
http://servicemanuals.vstore.ca/
Jun 08, 2008 | Toshiba 50H81 50" Rear Projection...
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
