Question about TORK Hardware & Accessories
Hello! please help! my tork 806d has been plug in for about one hour and the screen is off, lihgt for foto celd is on and so the light on the right side, is this a switch?
The TORK 1001 Timer stops at the end of the cycle? and do not advance after it stops the lights. Any solution?
Hello Tarsem
To repair this problem, replace and install new Tork 101 clock motor on back of timer:
http://waterheatertimer.org/Tork-timers-and-manuals.html
Also order new trippers.
Add comment
Gene
Aug 06, 2013 | TORK Timer 1 Channel Signal Timer Dgs100
Resetting fuel filter warning light on toyota 2kd
Change the diesel filer element.
Unplug the only connecter on filter housing.
Turn the ignition key to on position.
Go back and plug in the connector after more than five seconds.
The light should go off
Jul 14, 2012 | Cars & Trucks
I have a tork 651a . that only works at knight and its a photo cell,go figure....can you help???????????????
Tork 651 timer is dawn-dusk that automatically turns on at dusk.
Open following link to identify timer and download instructions:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#651
If you want ordinary 24-hour on-off timer for outdoors, instead of dawn-dusk timer, then select Tork 611A or Tork 601, or Tork 611 timer shown on same link above.
http://waterheatertimer.org/How-to-set-timers.html
Jul 25, 2011 | TORK 651A Photocell Controlled Mechanical...
I have a TORK 920L timer for our church parking lights. The timer is supposed to be a 7 day timer according to the dial. Right now it is turning one revolution per 36 hours. How do I get it to turn in an...
1) It sounds like the clock motor is not operating correctly.
2) This timer is not supposed to be connected directly to the lighting circuit, and should control contactors instead.
http://waterheatertimer.org/Tork-timers-and-manuals.html#900
See what contactors look like
http://waterheatertimer.org/H230A.html
3) I cannot find replacement clock motor for that timer.
4) Tork 920L mechanical dawn-dusk timer seems to sell for $1200
http://kscdirect.com/item/NSI%2BT920L/NSI%2BINDUSTRIES%2BINC_120V%2B2-SPDT%2B20A%2B%2BLIGHTING%2BCONTROL%2BCENTER%250A
5) Contact NSI Tork directly to find sellers:
http://www.tork.com/contact.aspx
6) Intermatic shows 1:1 replacement for tork brand timer is Intermatic T51211BC
http://www.intermatic.com/products/timers/mechanical%20time%20switches/7%20day%2015%20amp.aspx
Electric wholesale on-line showsT515211BC timer for $1000.
http://www.electricsuppliesonline.com/in7diwicat5.html
7) Contact Intermatic directly for more information, for example their second generation astronomic electronic time clocks can perform the same functions.
http://www.intermatic.com/customer%20service.aspx
http://www.intermatic.com/products/timers/electronic%20time%20switches/astronomic%20electronic.aspx
Intermatic electronic Astronomic dawn-dusk ET8015C sells at 1000Bulbs for $179
http://www.1000bulbs.com/product/3384/ELEC-ET8015C.html?utm_source=SmartFeedShoppingcom&utm_medium=Shopping&utm_term=ELECET8015C&utm_content=LightingControls&utm_campaign=SmartFeedShoppingcom&thissku=ELEC777dash777ET8015C&site=www.shopping.com
8) Add a comment and explain what kind of electrical load you have, for example a small church with simple 120V lighting can use inexpensive timer like T101 that sells for $60 at Amazon. Timer trippers would need to be reset.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 07, 2011 | TORK Variable Cycling Timer 8601
I have a Tork 1101. Please advise how to set the OFF time.
Tork 1101 is 24-hour 120Volt mechanical dial timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
ON-OFF trippers are placed on outer edge of dial to set on-off times.
These tripper click on-off lever back and forth.
Trippers wear out since they are intentionally made of softer metal than on-off lever
Frontier lighting carries P47 tork 1101 replacement trippers
http://www.frontierlighting.com/product.jsp?part=3495&process=search&show=&
Make sure these trippers match yours before ordering
Dec 09, 2010 | TORK Hardware & Accessories
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
Dec 06, 2010 | GE 51587 MultiEvent Timer
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I need a plug-in timer that I can turn something ON for 5 minutes every hour. What can you suggest? Henry
You need a 60 minute cycle timer capable of running 12 cycles per hour.
Usually this type of timer is heavier duty for commercial applications like garden irrigation or misting, stock feeding, or cattle barn ventilation. Commercial applications require reliable long-term product with higher price.
Average mass market plug-in timer is lighter duty, and is used for turning on indoor lamp or outdoor christmas lights a few times per day. These timers are inexpensive 'corner store' items priced at 6-15$. There would be no mass market for for a plug-in cycle timer as specific as your requirement.
Intermatic makes a panel-mount digital cycle timer you could wire to short extension cord.
http://www.intermatic.com/products/grasslin/electromechanical
Tork ACT cycle timer is less precise, but could be wired to short extension cord:
http://www.google.com/products/catalog?q=tork+cycle+timer
Tork sell sheet & wiring
http://waterheatertimer.org/Tork-timers-and-manuals.html#cycle
At grainger\
https://www.grainger.com/Grainger/cycle-timers/timers/act
Sep 07, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Oil pump ,,,where is the oil pump located on a 1997 dodge caravan
Hello
Welcome!
Oil pump is located on the oil pan.
Parts needed,,,oil,,,, oil filter,,,, oil pan gasket,,, oil pump,,,, oil pump pickup tube..
time to do this,, about 3 hours
Instructions,
Raise van place on 2 jack stands
drain oil remove oil filter fill new filter install.
remove bolts from oil pan,
remove oil pan..
remove 2 bolts that hold oil pump and tube.
install new pump and tube tork bolts to 45 fp
replace oil pan gasket and install oil pan
tork pan bolts to 35" pounds
install drain plug
fill with oil
start and check for leaks
let me know if i can help more
Jul 17, 2010 | 1997 Dodge Caravan
Hardware & Accessories Logo
44 people viewed this question
Top TORK Hardware & Accessories Experts
 Kenneth
Kenneth
rgbypoet
Andrew Taylor
Andrew Taylor
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
