Question about Mitsubishi Televison & Video
Hi .. I have a Mitsubishi WS-55517 tv .. I was going to watch a dvd and when I hit the Imput button on my remote it didnt do anything and after that the buttons on the tv wouldt respond ..
After 30 Seconds it shuts down.. Ive tried the reset and leaving it unplugged for 24 hrs and it still doesn't work. Any help would be greatly appreciated. Sincerely , Robert.
SOURCE: 42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Posted on Oct 07, 2007
SOURCE: Vizio L37
you probably changed the input mode.
Posted on Nov 10, 2007
SOURCE: Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
Posted on Mar 24, 2008
SOURCE: Panasonic TH-50PX60U no buttons working
The software in the cpu of this set is damaged you must reload it to fix the problem..
Posted on Dec 18, 2008
SOURCE: My son bought an AOC LCD TV (model L24H898) last
According to the manufacturer, to reset the entire unit do the following:
1. Press and hold "Menu" and "Channel +" on the TV. 2. Using other hand, press the power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and select. 5. Power off and re-boot the computer 6. Run channel auto-scan to regain the picture.
Posted on Feb 24, 2010
I have plugged my HDMI plug into my WiiU and the back of the Mitsubishi HDTV. Where do I find the channel that shows the input of the HDMI?
input source has to be changed to hmdi1 rather than ATV or DTV .. No channel is involved. The remote control should have an input source button on it to select the type of input port the TV looks at.
Jul 12, 2015 | Mitsubishi Televison & Video
RELENTLESS SNOW
You shouldn't have to have the tv to channel 3 or any other for that matter if you are in component. You need to make sure the tv is on the component input from your display menu that can be accessed from your remote.
Nov 12, 2013 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi TV WS-55909 only has 1 HD component imput spot; I have 2 HD devices?
look on the internet for a hub like usb ones the computers use.
Nov 29, 2012 | Televison & Video
Tv wont power up?
could be buttons,unplug them and try remote, or the convergence ics are bad
http://www.shopjimmy.com/
Aug 25, 2012 | Mitsubishi WS-55807 TV
My imput button on my tv remote for my Disney princess tv doesn't work. How do I switch the imput to watch Dvds if the imput button doesn't work?
If the input button on your remote is malfunctioning you can still change the input from the TV. There is a white panel on the bottom front of the TV with 4 buttons. The button on the far left side of that white panel is the input button. Press that to toggle to your inputs.
Regards, Tony
Apr 17, 2011 | Disney Princess 13'' TV Recorder
Mitsubishi remote and control panel issue
Did you ever resolve this problem and if you did, what was the fix? My same tv just got out of warranty and I have the same problem. Thanks.
Nov 22, 2007 | Mitsubishi WS-55813 55" Rear Projection...
Open Questions:
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
