Question about Mitsubishi Televison & Video
My Mitsubishi WS 65311 is showing a code 12 anyone know what that code means and how to fix it
  • 1153 Answers
SOURCE: ws-65315 won't turn on
Need to know more, 1-2 is no error code, you say will not turn on, do it has led light on or do you hear sound in set like high voltage? Any lights blinking? Or just completely dead, like fuse blown?
Posted on Mar 24, 2008
SOURCE: mitsubishi 1080 series, ws-65311 model
Same problem.. Checked the fuses but they're fine no reset switch to be found.
Posted on Nov 27, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi Model # WS 65311 HD 1080 turns on then shuts off.
try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
Posted on Mar 13, 2009
SD Tech
  • 14553 Answers
SOURCE: my mitsubishi ws-65311 will not turn on. i ran the
2 THEN 3 BLINK ERROR CODE MEANS PROBLEM in the deflection circuit--either no vertical deflection or no horizontal deflection.
Someone needs to open the set and look for shorts in either of these circuits---not likely you will get it fixed in home unless someone gets very lucky---what we do in this situation where I work is remove the entire light box(it can be removed with everything except the front keyboard assembly.)
Sorry if this is not good news--but it is what that error code suggests.
If you have questions or need advice reply to this post as I am here to help people.
REGARDS, SD TECH
Posted on Sep 26, 2009
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi ws-65809 powers on for 2 seconds.
2,2 error code is short protection---98% of the time it means one of the two soldered in pico fuses this set uses is blown----there are several---but your problem means if it is ws-65809 one of the two stk-392-570 convergence chips has failed.
I will attach a photo---they are on the middle circuit board and the two to the right are for convergence--both are green and 5 amp--with the set unplugged check both of them like any fuse--no reading means bad.
If you find this--I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET--SHOPS WILL GET 300 or more but you if you can do it yourself buy everything you need for under 40 dollars--I can tell you the best place to get the chips, fuses, etc.
If you want the instructions let me know and I will post them here for you---they are based on my own actual experience doing this repair in this kind of set hundreds of times.
If this information helped you rate this solution as I do this here for free.
SD TECH
Here is a photo of what the two chips look like--The one in the picture says 392-560 but yours uses two that look just like it--STK-392-570.
Posted on Dec 28, 2009
Testimonial: "SDTECH provided me the information I've been seeking for the past 2 years, and he did it the same day as I posted the problem. YEA!!!!!!!"
Please can you tell me what error code 12 means and how to fix it or reset it on my Mitsubishi WS 65513 TV? Thank you!
seniomsed,
Error code 12 means there is a problem with the lamp system. This model has a known defect in the DM board and power supply board. Mitsubishi does not support it and has no spare boards. After market vendors do make repair kits. I have a tip at http://www.fixya.com/support/r7065906-mitsubishi_turn_flashing_power_timer which will help solve your problem.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Feb 16, 2011 | Mitsubishi WS-65513 65" Rear Projection...
My mitsubishi ws-65311 will not turn on. i ran the error code test and it comes up 2-3
REGARDS, SD TECH
Sep 26, 2009 | Mitsubishi WS-65311 65" Rear Projection...
Mar 12, 2009 | Mitsubishi WS-65311 65" Rear Projection...
Image outside of bounds of television.
There should be a format button on the remote you can hit. This should cycle thru all the "formats" that the set can do. 16x9, 4x3, wide mode, Full mode, stretched mode, etc.. Let me know if that helps you.. Happy holidays... Jay
Dec 08, 2008 | Mitsubishi WS-65311 65" Rear Projection...
Mitsubishi 1080 series, ws-65311 model
Sep 07, 2008 | Mitsubishi WS-65311 65" Rear Projection...
How do you dismantle
It's in the manual in Appendix F.  I bet you can download the manual from the Mitsubishi site.  The problem is that it says that it is supposed to be done by authorized Mitsubishi service personnel.  We have not had any luck finding anyone in our area who is willing to come out and do it although it looks like it would be really easy for someone who knows tvs.
Aug 07, 2007 | Mitsubishi WS-65311 65" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
