I can't stabilise the volume control? Its perfect for the alarm, set to come on at level 4 but if I turn it off and on again later it always defaults to 6 and a half levels. How do I rectify this?
robotek
  • 1512 Answers
SOURCE: aiwa mini-component
gidday mate... it does sound like a failure in the audio output stage. I suggest that you first check the speakers for short circuits as a fault here will produce a similar symptom you described. Check that you have the correct DC conditions about the STK, such as main power supply. Check all resistors that are in proximity to the STK, particularly lower value ones. Look also for shorted or dry capacitors about the output stages. Most of the audio signal path amplification is inside the STK and generally only a few millivolts of audio are provided to the input pins(usually the outermost pins). I have looked online for a data sheet on the chip that may be of help to you, but have not yet been able to find one. If the unit has soft touch electronically switched input selectors or electronic attenuator to the vol control, either of these IC,s may be faulty also. I am happy to keep going with this to help you fix it if you want. Give me a hoy back in here and I will :)
Posted on Jan 25, 2008
grodenbarg
  • 9 Answers
SOURCE: Sub woofer volume adjustment
The gain dial is not a volume control. The gain dial is used to compensate the output level of your car radio head unit. all car stereo units output are not alike. If you set this gain level too high, it will cause major distortion (clipping) to the audio output of you speakers when cranked up. This excessive distortion WILL eventually, or even quickly damage or blow your speakers.
I personally blown speakers this way no not properly setting this. (lesson learned, I guess :| )
Posted on Jan 28, 2009
SOURCE: how to set start up volume control
I read another post that says that if turn on the unit and set the volume where you want it at startup, and then press in the volume knob until you hear it beep, that locks in the current volume as the startup volume. I just read this, so I haven't tried it myself yet. Good luck!
Posted on Apr 28, 2009
  • 7 Answers
SOURCE: EnV3 Ringer Volume TOO LOUD
There is a bug with this phone. All of them do this. The V05 firmware that came out 10-2-09 does not fix this. Sorry. I hate this too.
Posted on Nov 03, 2009
  • 15 Answers
SOURCE: The volume on my acer aspire 5532 is not very at maximum level
Go to Device Manager and up date your drivers if this don't fix the issue. Try removing the driver and visit http://www.acer.com/worldwide/selection.html select your location.
Visit the drivers download section and download a fresh driver.
Posted on Feb 25, 2010
Wake up with the radio is always set to level 19... I would like to set my radio alarm with a lower volume... my centrios is a Speed to Sound CENTRIOS IPOD/IPHONE CLOCK RADIO I will return this
We also have this problem. Found this info in the product's Q&A on the website: http://answers.thesource.ca/answers/9026/product/1218694/centrios-centrios-ipod-iphone-clock-radio-white-questions-answers/questions.htm
"Ok. there is a way that you can LOWER the wakeup radio volume. turn on the radio (forget about the alarm right now) and go to the station that you want. when you get to the station, you should be able to press the 'skip/fast forward' button on the remote. when you do this, number 5 should show up beside the station #. When you do this, it lowers the overall volume of every volume level, so now level 19 is equal to volume level 9/10, which for me is loud enough to wake me, but not give me a heart attack! so, now when the alarm goes of, the volume is a lot lower. BUT if you want to wake up to your ipod, this method will NOT work, it will still be up at level 19. so when you turn on your ipod, it will be really LOUD. again, this only works with the radio."
Also if you are waking to ipod and not radio this was in the reviews:
"Fooled with it for a bit and discovered that you have to turn down the volume of the iPod first before putting it on the dock. We've tried it a few times just to make sure and it worked every time!!"
Still not a perfect solution, but a great improvement. Hope this helps someone.
Jan 08, 2011 | Centrios Classic Flip Clock
How do i turn up volume on hp officejet all in one
Adjust the volume
The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and
the Phone Line Monitor Volume.
The ring volume is the volume of the phone rings. The beep volume is the level of
button press and error beeps. The default Ring and Beep Volume setting is Soft.
The Phone Line Monitor Volume is the volume of dial tones and fax tones. The
default Phone Line Monitor Volume is Medium.
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press to select one of the options: Medium, High, or Low.
4. Press OK.
Trust this is helpful. Please vote. :)
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
2007 Saturn Aura XE, the audible alarms can hardly be heard
Good news - they're adjustable. The radio is used to adjust the vehicle's chime level. To change the volume level of the chime, press and hold push-button 6 with the ignition on and the radio power off. The volume level will change from the normal level to loud, and LOUD will appear on the radio display. To change back to the default or normal setting, press and hold push-button 6 again. The volume level will change from the loud level to normal, and NORMAL will appear on the radio display.
Note: Each time the chime volume is changed, three chimes will sound to indicate the new volume selected.
Sep 07, 2010 | 2007 Saturn Aura XR Sedan
My pk-635m camera is working but the microphone is not, what will i do?
If you have XP set your mic as default in the Control Panel
Vista
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Aug 20, 2010 | A4tech PK-635 Webcam
When I call someone or someone calls me, my voice sounds like the chipmunks. I have to hang up and call again to correct the problem. I have a pro 9000.
1) make sure your mic is set as default
TEST SPEAKERS
Restart computer
2) Check you have DirectX 9 or later installed to support your cam
3) You may have to re-install the software - browse the photo gallery and click on your model - check out any known problems as well
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
Jul 11, 2010 | Logitech Webcam
My webcam the microphone is not working
Make sure its set as default
Vista If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. To set required (webcam) mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click 'OK' Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays Restart computer
Configure webcam to your chat program
Jun 06, 2010 | A4tech PK5
I have the same problem
MIC SET -UP VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET MIC DEFAULT & TEST
Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Re-start Computer.
CONFIGURE TO MSN
Re-boot the webcam by unplugging and plugging it back in again - Its always good practice to do this before you open MSN. If you have been using your webcam in another program, it can remain hooked up to the old program and you will get an error message " Unable to find webcam or being used elsewhere"
Webcam Connected
Open MSN
Click ( > ) Open Menu >Tools > Audio & Video set-up > Set mic as default and run through audio set-up > Next > set webcam as default and adjust Webcam Settings > Finish
Aug 13, 2009 | HP VGA Webcam
I can see and hear my contact but they cannot hear me I have tested all the audio and microphone tests and they check out fine
MIC SET-UP :- VISTA
TEST SPEAKERS
Re-start Computer.
CONFIGURE TO MSN
Webcam Connected
Open MSN
Aug 13, 2009 | Microsoft LifeCam VX-3000 Web Camera
Kenwood stereo control amplifier KC-206 doesn't work
I found this thread when I was having the same problem with mine. Turns out that it's sort of a problem, but not really. Looking at the manual (which I found in another google search) I believe a "4" on the volume level corresponds to a default remote control setting. The remote varies the level between 0 and 10, but the "10" corresponds to the maximum volume setting on the preamp. So it actually works, it's just that the "4" reading doesn't change. There's probably a pin you can short somewhere to make that default to "10" which would be ideal. But I'm not sure where that is. Now on to my other problem. This particular preamp has a subtle 120 Hz hum...
Nov 15, 2008 | JVC RX-E100 5-Channel Amplifier
LOUD SOUND WHEN SENDING FAX
There are 4 volume controls to access them press MENU.
You should see “MACHINE SETTING?” if not use the SET arrows to scroll through the different menus, stop when you see “MACHINE SETTING?” Now press the SET button.
Now use the up & down arrows to get to
Buzzer Volume = that the machine beeps
SET
Key volume = the tone that sounds when you press keys on the control pad
SET
Alarm volume = the alarm if something happens.
SET
Line volume = sets the level you hear at the fax is actively transferring a fax.
If you want to change any of the settings, press the up or down arrows to the level you like best and press SET if you don’t what to change that item just press SET. When you have adjusted all levels the way you want them press STOP and the levels will be remembered.
The most annoying sound to most people in the Line Volume. I have known people that like it as quiet as posable in thier work, but the problem is if you turn down the ALARM you won’t know when there is a problem. Many people like a little line volume so that they hear when they dial into a busy phone line, or if someone picks up the shared voice line.
Feb 12, 2008 | Canon L120 Fax Laser Printer
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
