Question about Home Security
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Posted on Aug 21, 2008
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
Posted on Jan 22, 2009
SOURCE: Sentry Safe A3750 won't open new batteries
http://www.sentrysafe.com
call them
mj
Posted on Sep 07, 2009
SOURCE: No keys to my sentry 1100 fireproof box.
You can go to www.SentrySafeShop.com and do a search for keys. You will then be able to enter your information as listed below and they will send out a new set to you.
For Small Chests or Files: (Model numbers will begin with 1100, 1160, 2100, etc... ): A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock (right around the hole where the key goes in at).
For Personal, Home and Home/Office Safes: (Model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Posted on Jan 15, 2010
SOURCE: sentry 2260 fireproof safe
A good locksmith should be able to help you
Posted on Aug 09, 2010
Apr 02, 2015 | Sentry Fireproof Security Lock 1/2 Hr Home...
Dec 20, 2010 | Sentry Safe G1455E
Oct 27, 2010 | Sentry Fireproof Safe
Jan 29, 2010 | Sentry Fireproof Safe
Jul 13, 2009 | Sentry Fireproof Safe
Nov 16, 2008 | Sentry Fireproof Safe
Aug 10, 2008 | Sentry Fireproof Safe
May 01, 2008 | Sentry Fireproof Safe
Apr 01, 2008 | Sentry Fireproof Safe
Nov 03, 2007 | Sentry Fireproof Safe
60 people viewed this question
