Question about Night Owl Optics Optics
I can't view anything through my night owl optics monocular
miket756
  • 2702 Answers
SOURCE: Dysfunctional Night Vision
dont power this up in full day light or you will burn out the ccd pick up if you cant see anything through it i gess the tude has burnt out
its common for this to happen there life span is only about 1000 hours and much less if exposed to bright light, ie minuets!
Posted on Jul 14, 2010
Testimonial: "Thank you. "
stewbison
  • 577 Answers
SOURCE: My Night Owl Cyclops NOCC3 night vision monocular
Hello, is the IR glowing red, don't look into the IR lens. Just place your hand in front of it and see the is a red glare on your had. If there is a red glare then IR is work.
Another thing when you taking a look see through the Night owl NV monocular there should be a green glow from the image intensifier tube, if not, then the NV monucular isn't working properly. stewbison
Posted on Aug 10, 2011
stewbison
  • 577 Answers
SOURCE: Repair: Night Owl Lightweight Night Vision
First, what are the problems with your Night Owl monocular? I can't help you. You'll need to give more information on what is wrong with the Night Owl monocular. stewbison
Posted on Aug 17, 2011
stewbison
  • 577 Answers
SOURCE: night owl optics night vision monocular model #
Yes, at Night Owl Optics in El Paso, Texas. This is not a mandatory option. You can do it you self. You can see the white wire in a slot just under the aluminum thread ring for the battery cap.
Is this where the wire is broken at?
Need a small dental pick with 90 degree bend on the end/you can make one, also some tweezers or small needle nose pliers. Use the hook to remove the aluminum ring that is press into the plastic case.
Once, the ring is removed, reach in the Small slot with the tweezers and grab the wire. Now, gentle and I mean gently pull on that white wire until you enough wire to strip the teflon coating off.
Now, use the pick to cut a little small **** in side where the battery cap ring goes. Now, put a very minute drip of glue in the wire ****. Push the wire into the glue **** with the pick. Now, you can install the aluminum battery cap ring. Gently push it down and let the glue dry. Your done...awesome, no.
GB...stewbison
walk gently upon this earth, and she will good to you.... NO means Yes here!
Posted on Sep 05, 2011
stewbison
  • 577 Answers
SOURCE: I put in a brand new battery in my night owl
Hello, this Night Owl monocular will have two light (LED's), one green for on/off, and other red LED for IR illuminator. So, does the green light come on? Also, if still does work, then send it to me. I some parts to fix other NV devise and 95% of them are manufactured in Russia including yours.
I wish you all the luck. GB...stewbison
Posted on Sep 09, 2011
I THINK IT IS THE MORE GENERIC ONE, COMPACT, IT IS THE FIRST LENS VIEWING IN ,
Hello, what seems to be the problem with Night Owl NOCX3 monocular? GB...stewbison
Sep 14, 2011 | Night Owl Optics Explorer NOCX3 Monocular
Night owl monocular had broken photo facade lens set, is it replaceable
Hello, to answer both your question on fixya. Yes Since you Nigh Owl Monocular NOCX3 is five or more years old. You can check with Night Owl Optics in El Paso, Texas. I am sure that I have the replace lens or the whole 1,5 50mm front lens. Contact at drawbridge21@q.com. It will be free and the only cost will be shipping. Richard
Repair: Night Owl Lightweight Night Vision Monocular?
Aug 16, 2011 | Night Owl Optics Optics
I took out 3 lenses but there is still one inside and it has a fingerprint on it that i would like to clean & i can't reach it because it is on the inside, don't know how it got there... &...
It is a wigit finger print. Anything that happen, does happen, could happen, will happen, happen to disappear, you can count on it that a darn wigit had something to do with. There could be more than one wigit also.
The optics on you Night Owl are Russian manufactured. So, it a Russian wigit finger print.
Now which optics lens has the finger print, viewing optic, 50mm input optics. So you need to tell me which optics and I will help you remove the lens by written instruction OK. I have a Night Owl NOCX3 setting on my work bench. stewbison
Aug 14, 2011 | Night Owl Optics Explorer NOCX3 Monocular
Hiya i cannot get my optics to power up i press the power for 5 secs as it says nothing happens then light goes out when i release power button can you help thanks
Why do you need to hold the on/off button for 5 sec.? This a Night Owl Cyclops monocular that is manufactured in Russia. There could be a number of thing wrong with, such as; bad image tube, faulty ccfl inverter, toloid coil has shorted, voltage multiplier has goin to kaput heaven, broken wire/wires. Many thing can go wrong. Viewing bright incondesnce light, the sun and anything the admittes visiably light. This will destroy the image tube. stewbison
May 21, 2011 | Night Owl Optics Cyclops Compact NOCC3...
My Night Owl Cyclops NOCC3 night vision monocular wont pick up the infra red light properly so I can't view anything at night!!!! I haven't the lens cap off in light only when it's dark out and it won't...
Feb 21, 2011 | Night Owl Optics Cyclops Compact NOCC3...
I don't know how to work this, we received a Night Owl Explorer Nocx3 for Christmas several years ago. The instructions got lost and it as set in a draw ever since. I have stored the battery out of the...
Hello Here Night Owl Optics owner manual web site for your monocular: http://www.nightowloptics.com/documents/NexGenMonoMULTImanual.pdf
One more thing. DO NOT LOOK THROUGH NV MONOCULAR DURING THE DAY, OR LOOK AT BRIGHT LIGHTS. This will destroy the image intensifier tube. Bright lights will make it go south faster than Speedy Roadrunner. I need parts if the image tube is gone. Night Owl Optics in El Paso, TX will charge you about $200 plus parts and shipping to repair it. So, listen no looky at bright lights in the neighbor bedroom window, hey. GB...stewbison
Jan 24, 2011 | Night Owl Optics Explorer NOCX3 Monocular
Older night owl nexgen monocular,powers up but cant see anything
try to resold it's dry pins and carefully check out it's display ribbon try to find unsoldered joint area or broke area.
Dec 21, 2010 | Night Owl Optics NONEXGEN-W Monocular
I put in a brand new battery in my night owl optics night vision monocular and the red light comes on but i can not see anything out of it.
Dec 20, 2010 | Night Owl Optics Explorer NOCX3 Monocular
My night vision scope will not turn on. My LEDs work but you can not see anything in the lens. Yes the cap is off. I tried new batteries. It has very few hours of operating time. Help!
Hello, Welcome to the world of Russian night vision system. That is right, Night Owl Optics Cyclops NOCC3 is manufactured in Russian. The biggest problem with these monocular and binoculars and even scope is that they use cheap 1st generation Russian image tubes and everything else. It would be cost prohibitive to have it fixed, that is, if Night Owl Optics will fix it for you. Hint: Auction it on Ebay as night vision parts. Sorry, GB...stewbison
Nov 30, 2010 | Night Owl Optics Cyclops Compact NOCC3...
Optics Logo
205 people viewed this question
Top Night Owl Optics Optics Experts
wadingriver
wadingriver
Ted Maxwell
Are you a Night Owl Optics Optic Expert? Answer questions, earn points and help others
