Question about Denon AVR-1200 Receiver
Protection displayed on avr 1200 when turned on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Denon Master
  • 102,366 Answers
Usually this indicates a short somewhere in the speaker wiring.
Posted on Dec 05, 2016
Harmankardon avr 65 reciber ** protect** on my avr 65 reciber display
It's a DC couplage problem ... you can't do any one if you're not professional electronician ... and this is want to schemas and experience.
So you wanna take help from Harman/Kardon technic services... :S
Oct 31, 2015 | Harman Kardon AVR 65 Receiver
The display reads "protect".so i
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 19, 2011 | Denon AVR-900 Receiver
Protection light on my denon avr 1200
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 06, 2011 | Denon AVR-1200 Receiver
How do i reset dennon avr 1000
turn it off and unplug from outlet, wait 1min
then press audio and video buttons together on right hand side of unit
hold these and turn plug it back in to outlet
wait until display flashes every second then release buttons
turn on unit to reset
note all settings will be factory default.
Hope this helps
Thanks for using FixYa
Jun 12, 2010 | Denon AVR-1200 Receiver
I have a Harman Kardon AVR 235 Receiver that go's into Protect
To avoid making the avr go into protect mode when you power up your Hafler 4000 that is connected in the avr's pre-out, you must power up the set up in the correct sequence.
1. Turn off your avr
2. Connect Hafler 4000 to the avr's pre-out it it is not yet connected
3. Turn on your Hafler 4000. The avr will not go into protect mode becasue of the transients from the Hafler because it is still not powered on.
4. Turn on you avr. There should be no more transients from the Hafler at this stage unless it is not functioning correctly, so the avr shouldno longer go into protect mode.
Dec 08, 2008 | Harman Kardon AVR 235 Receiver
Protection mode.
Hi, protection mode means either the speaker terminals are shorted or the unit is overheated the manul says fix the short (DOH!) or unblock the vents (DOH!) but if it is really an issue with the microprocessor, then unplug the unit, hold in power and the tape loop buttons at same time and plug back in, wait 15 seconds or so until the display flases about once a second and then release both buttons. I will doublecheck these are the correct buttons, but I am pretty sure (I have the manual)
Aug 26, 2008 | Denon AVR-1200 Receiver
What failed component causes protection error message to display right at power up.
well, i just got this thing from a friend. its a Denon AVR-800. when powered up it displays the stops, just before finishing a -protect- shows up. There's a little red light standby light that blinks off and on also. i think that has to do with the internal problem. any suggestions?
Apr 03, 2008 | Audio Players & Recorders
Protection on display
disconnect everything from the unit and see if it still does it.
if it does i would check the output transistor (ic).
Jan 25, 2008 | Denon AVR-1506 Receiver
Receiver in Protection Mode
Electronics like a receiver are so sensitive to power surges. I'm sorry to say that it's most likely unrecoverable, especially if it wasn't plugged in to a surge protector. Even if it was, they don't all protect 100% from surges. :-/
Apr 24, 2017 | Denon AVR-1200 Receiver
35 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
