Question about Dryers
When I try to set the timer and push the start button nothing happens. The trouble seems to be with the time st spinner
  • Dryers Master
  • 5,323 Answers
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
What to Test When Whirlpool or Kenmore Dryer Won Start or Run
When I try to set the timer and push the start but - 26385255-bszy215dbxllk1sw2ym4qmfg-4-0.jpg
26385255-bszy215dbxllk1sw2ym4qmfg-4-2.jpg When I try to set the timer and push the start but - 26385255-bszy215dbxllk1sw2ym4qmfg-4-5.jpgt/uploads/images/26385255-bszy215dbxllk1sw2ym4qmfg-4-5.jpg" alt="26385255When I try to set the timer and push the start but - 26385255-bszy215dbxllk1sw2ym4qmfg-4-9.jpg"h_mi" />
Posted on Dec 08, 2016
  • 19396 Answers
SOURCE: Maytag Dryer #MDE4000AYW
Try first unplugging power cord from the appliance, this will drain power from circuits and reset it.
Check the door latch sensor, if that is stuck the door sensor will not let the machine start.
Keep pressed start button for 10 seconds or so, on some dryer this reset the machine.
If it still does not work then there is an internal fault , probably the timer assembly must be replaced.
If you need to call a technician you can use the number listed on the owner manual.
If you want to do it yourself, test the timer control, then if it is faulty replace it.
You find replacement here.
Posted on Sep 18, 2008
  • 8 Answers
SOURCE: Kenmore electric dryer won't start
The first thing I would check would be the door switch. Dryers operate on 220 volts. Many brands split the 220v into 110v for controls and motor and 110v to the heater. There are also safety systems on many brands that won't allow the heater to come on if the fan motor is not running and blowing air throught he element to prevent overheating and dryer fires. If the door switch is ok, check the belt. If the belt is ok, it could be a problem with the motor start switch. The motor start swith is complicated fix and should be done by a professional. ALWAYS BE SURE TO DICONNECT THE POWER BEFORE ATTEMPTING ANY REPAIRS.
Posted on Nov 29, 2008
SOURCE: Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Posted on Apr 02, 2009
  • 11 Answers
Posted on Apr 20, 2009
  • 85 Answers
SOURCE: Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Posted on May 27, 2009
Have an Emerson MW 8115 SS. Kids have apparently locked in buttons on weight or defrost mode. If I set a time 30 sec. or 1 min. timer will count down but when I push start nothing happens. Is there a reset...
Product manual does not show reset protocol.
There is Child-Lock feature on page 13 of manual, but display will not let you press buttons
Customer service 1-800-909-1240
Unplug microwave and see if it resets.
Press both Stop and Clear buttons simultaneously.
Try different power level by pressing Power button.
It is possible the Start button has gone bad.
Make sure clock is set.
Nov 03, 2012 | Hardware & Accessories
Cannot set time on 45/7012
Hold the reset button (upper left button) until the seconds start to blink. To go to the hours, push the mode button (lower left button). To set the hour, push the ST/STP button (upper right button) to the desired hour. To go to the minutes, push the mode button again, set the minutes with ST/STP button. To go to the date, push the mode button, set with the ST/STP button. Once done, simply hit the reset button to complete. Hope this helps!
Mar 13, 2011 | Armitron Watches
How do I change the time on my fossil watch dq1185
Time Setting Instructions:First press and hold ST/STP for a few seconds and make sure it says (Time 1). This watch has a (Time 2) to use in other time zones.You change from Time 1 and Time 2 by pushing the ST/STP button for a few seconds.Time 1 setting:- Press and hold the SET button (Light Function will blink) use the ST/STP button to select on or off. Then push the Mode button to go to the next function.- The Chime function will blink. Use the ST/STP button to select on or off and then push the Mode button to go to the next function.- Next will be to select 12hour or 24hour time by using the ST/STP button then press the Mode button to set the Hour, Minutes, and Seconds.- Continue to set the year but when you get to the Month/Day you have the option of putting the day first then the month, use the ST/STP to select then push the Mode button to enter the month and day.- When satisfied with your settings push the SET button and your done.
Time 2 Setting:- Press and hold the ST/STP button it will say Time 2 and then go away only showing the time and date for Time 2- To adjust this time to another time zone you push and hold the SET button.- Use the ST/STP button and the RESET button to move ahead or behind in hours depending on time zone. Push the SET button when done.-Your time 2 is set for a different time zone and your Time 1 is set for your local time. Remember to use the ST/STP button to go back and forth from Time 1 to Time 2.
Jan 25, 2011 | Fossil Watches
I have an electric whirlpool with start switch not working
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer just stopped working. Turned knob to desired time and pushed start, nothing happens. When knob is on OFF position and I push the start button, it makes the regular BUZZ sound - times up, clothes...
Remove and inspect the timer knob for a crack or missing tension clamp.
Carefully place it back on the timer shaft while paying attention to the (D) shape in the knob and the shaft.
If they are aligned correctly notice where the position arrow is pointing, ie; off---run--etc.
You may well need a new knob.
Feb 21, 2009 | Dryers
I can't set the time, the alarm time, or do anything of that sort
AHAH! I had this problem also, so i tried google and it led me here. Luckily, I kept trying and figured it out so I will share my knowledge with you although you may have found it out already...
First, make sure the radio and ipod are off and it's in clock display mode.
Then, click and hold "alm set" while clicking the left "timer set" arrow to set the hour of your alarm and the right "timer set" arrow to set minutes for your alarm.
Then click "alm on/off" to turn it on and off.
Jan 20, 2009 | Insignia AM/FM Clock Radio with Apple iPod...
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer won't start
Check your door switch and wires to see if they are damaged first.You may have a bad Start Switch.If it is a 2 wire switch you can tape them together and then plug in dryer ,if it starts,replace the Start switch. Please Rate this!
Jun 12, 2008 | Kenmore Dryers
Wont start
try turning the drum by it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
Top Dryers Experts
