The tv does not turn on when switching on? - Televison & Video
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
If it's the switch on the TV you are using, and itcs plugged in, if you hear a click when you press the button(electronic click, such as some electronic parts receiving power like s relay.) The the picture is deactivated, or slow to come on. But if it had power and neither remote or button on tv works::: then you can try unplugging it for 15 minutes and try again.
But if nothing fires up power is either not getting to the switch out stops immediately after. Could be capacitor or transformer before the switch.
Posted on Dec 04, 2016
  • 822 Answers
Power supply board faulty......
TV will not turn on
Check the wall outlet, make sure there is power at the wall. If not, check the breaker panel. If there is power at the wall, check the TV for a manual on/off switch. If you have a power switch on the TV, turn it off, wait 10 seconds, then turn it on. If no power switch on the TV, unplug the TV for 10 seconds, then plug in again. Use the remote to turn the TV on. Check for a fuse or circuit breaker on the TV, usually near where the power cord enters the TV.
Make sure you have good batteries in the remote. If all this fails, then something may be damaged inside your TV, as a result of a power spike before the power went out, or when it came back on.
Take it to a repair shop.
Apr 07, 2014 | Magnavox 19me601b/f7 19-inch 720p Lcd Tv
My television can't switch on
have you tried turning the tv off for 4 to 5 hours unplugging it
Jan 13, 2014 | LG 47LM6200 - 47" Class LED 3D Cinema HDTV...
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
My T.V. will not turn off. The last repairman bypassed the swith on the back door of the T.V. Should I just repklace the little blue switch on the back of the T.V.?
That blue switch is in place to make sure that the back of the TV is closed properly. It prevents the TV from being turned on when the back is removed. It would not be keeping the TV from turning off. Replacing that switch would not solve your problem.
Oct 11, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
TV turns on and off without pressing any button
This could be a simple issue with the dome switches on the tv. Many times they will become faulty and can cause strange things like this, one common cause of the switches going bad is incorrectly cleaning a tv by spraying cleaner directly onto the screen and allowing the solution to drip down the screen, capillary action will take a few drops of the solution an deposit it on the switch board behind the switches, causing the tv to malfunction. Even though the power is turning on and off does not mean that the power switch is the one causing this. Without getting technical the design of the switch array can make any faulty button work another function. For example a faulty volume up switch can turn the tv on or off. All of the switches need replaced.
Oct 10, 2009 | RCA 36V430T 36" TV
Tv wont turn on
Switch off the surge protector for 2-3 minutes then switch back on and TV should work.
Feb 19, 2009 | Philips Magnavox 27MS343S 27" TV
turning off mute with no remote on a rca reciever
Dec 23, 2007 | Televison & Video
TV turns off by itself.
ok cowsad! you have defective tact switch relace all tact switches! the tact switch is have only resistance if you press it, but now ithink your switches is now have smal resistance thats why your tv is on and off automatically.
Sep 14, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
