Question about Samsung Washing Machines
My Samsung vrt fills up with water while on quick wash and when it gets down to the 23 minute mark it flashes 4E code and water drains completely out. How can I stop this?
  • 822 Answers
I have a samsung vrt washing mashing that keep flashing a 4e code do you have any advise what look for it less than 1 year old
4E typically represents a problem with the incoming water, first step would be to check the water coming to the machine, while the water lines are off be sure to check the screens on the water valves to be sure they are not plugged.
Dec 01, 2017 | Samsung Washing Machines
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ... for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers
    • 7 POSTS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ...
    • 9 MIN
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Errpr code 4e on samsun aqua jet vrt
    A 4E code on Samsung washers means that the washer isn't filling properly or the sensor isn't detecting the water flow. First, make sure that the water shut-off valves are open. Next make sure that the drain hose outlet is positioned above the fill level of the washer. (This avoids the water being suctioned out of the tub.)
    Turn off the shut-off valves and disconnect the fill hoses from the washer and the valves. Clean the filters in the washer and at the valves. Reconnect the hoses to the valve and place a bucket under the other end. Open the valves and check that you have good water flow from both hoses. You may want to replace the hoses. (Some washer fill hoses are designed to clamp shut if they detect a leak. This anti-burst feature will reduce the water flow to a trickle. Since the washer fill sensor detects the amount of water in the tub within 8 minutes, that will trip the error.)
    If the washer isn't filling and there is plenty of water coming from the water line, the fill valve probably failed in the closed position. If the water level is rising, then the sensor is probably faulty.
    Please add a comment with the full model number of your washer. Then I may be able to point you to the parts. If the washer is under warranty, contact Samsung.
    I hope this helps.
    May 01, 2015 | Washing Machines
    Did you leave out the complete model number?, If you haven't yet check your water supply, If you changed to or have the auto stop flood hoses some washers cause them to activate.
    The wires may be disconnected on the water valve(s) or a valve went bad or the main board went bad, You can use a meter to check that there is voltage going to the valve(s) when you start a fill cycle, Also some washers use a flow meter that checks water flow.
    May 03, 2017 | Samsung Washing Machines
    I have a samsung smart wash B1245S 6kg . when i set it on for a quick 30 min wash it will fill with water for about 10 mins . Then it will cut out and 4E will flash up on the digital display
    Display shows 4E.
    Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
    Dec 17, 2010 | Samsung Washing Machines
    4E showing on Samsung Washing Machine
    When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
    1. Turn off the water source to the washing machine.
    2. Unscrew the hose from the back of the washing machine.
    3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
    4. Push the filter back into place.
    5. Screw the hose back onto the washing machine.
    6. Turn on the faucet and make sure the connections are watertight.
    Also, please check the following:
    • Make sure the source water faucet is turned on.
    • Check the water pressure.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Apr 06, 2009 | Samsung WF337AAL Front Load Washer
    Washing Machines Logo
    83 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
