Question about Singer Sewing Machines
Please could you tell me what length stitches to use for seams of a light weight cord skirt. I have a Singer one plus
  • Singer Master
  • 11,732 Answers
The most common stitch length is 10-12 stitches per inch--10 stitches is usually best for heavier fabric, 12 stitches for lighter weight fabric. Whatever your machine setting that will create this number of stitches is usually sufficient.
Posted on Dec 04, 2016
Testimonial: "Thank you very much. I can now start my first project"
    Top Expert:
  • Singer Master
  • 8,211 Answers
Stitch length singer
Run through the "10 minute tuneup" here: https://answers.yahoo.com/question/index?qid=20090925205957AAq0xc4 DO NOT MESS WITH THE BOBBIN TENSION. Top tension setting should be about 3-4. Stitch length probably in the neighborhood of 2.5 - 3.5 mm.
Little kids and sewing machines seem to have a natural attraction, which is why my mom taught me to sew on her machine when I was 5. Sometimes it's easier to teach the kid how to do it right than keep the kid from messing with the machine.
Jun 24, 2014 | Sewing Machines
Need to gather a skirt to fit a dress bodice don't remember settings
hi, have the machine set at the longest straight stitch length, usually 4 or 5. Then sew 2 rows of stitches side by side without reversing at either end. remember to always pull the bobbin threads up to gather and not the top one.
Jan 22, 2014 | Singer Sewing Machines
Singer futura 900. My test stitch on a scrap material looks fine. When I sew on the actual item I wish to fix the stitches go from the 10/in to 1/inch. They are all spread out and do not hold the seam...
is the test stitch fabric the same as the actual item you need to sew, if not you might need to change the needle. also check the stitch length to make sure it's set correctly.
Jan 01, 2014 | Sewing Machines
Singer Inspiration 4220/4228--I can't get a good stitch on lightweight material. Can you help?
in your manual on page 6 it has a chart for needle and thread combinations for fine or light materials. For your convenience I have included the download of the manual here. (see pdf page 16)
http://www.singerco.com/uploads/download/492_4228_4220_030707_new.pdf
When using lighter fabrics it is very important that you use the right thread and needle combo. Start with the correct needle and thread for your application then adjust the tension to match.
Good luck
Jul 27, 2012 | Singer Sewing Machines
Seams puckering
Several things to try to trouble shoot this:
But basics first, always press each seam, both sides, then open after sewing it. This beds in the stitches and gives a smooth finish. I always sew with my iron on beside me. Guide how is here http://sewing.about.com/od/beginner1/qt/press.htm
To adjust the seam tension try either loosening the top tension, or shortening the stitch length. 2.5 for normal weight fabrics but if you are sewing silk or chiffon you would shorten up to 2. Obviously don't make it too close though or its a major pain if you need to unpick a seam.
Best thing is to test sew and get top and bottom tension perfectly balanced first. There is a instructions on how to do this here.
http://www.sewusa.com/Sewing_Machine_Repair/Thread_Tension_Settings.htm
Then practice seam on your actual fabric firstly making sure you've got the appropriate sized needle in the machine, needle sizes info here http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/ . Always use a new needle for every new project or 4-6 sewing hours - its never worth scrimping on needles, I have about 30 packs in my sewing cabinet in every size, ball point, sharp, twins, wings and microteck types.
Then stitch, press, and evaluate. If you still feel the seam is pulling up, then you could try not backstitching the end of the seam and ease some out of it after stitching. Or loosen the top tension a little.
Always stitch a skirt seam from hem to waist so that all the seams are sewn in the same direction, this makes a difference too.
And if you are still really unhappy with the performance of your machine you could consider taking it for a service to get it into tip top condtion or look at purchasing a higher end machine, take your fabric sample into a dealer and ask for a demo and see what quality seam they can get from their machines. IMHO I believe that there is a difference in stitch quality between a $200 mechanical front loading bobbin machine and a higher end horizontal bobbin machine, just due to the mechanical tolerances and build quality between the two machines. Watch a show like Simply Quilts and you'll probably see a European made machine being used. Most experienced sewers will have a machine prefererence after shopping around and comparing the different makes and models out there.
Jul 19, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have a mORSE 6500 WHICH WAS MADE BY TOYOTA AND i have no idea how to install cams nor what tension setting or stitch length I would need
The tension will depend on the material (knit, heavy denim, etc). See this pdf for a description of testing and setting the tension: www.ca.uky.edu/HES/fcs/FACTSHTS/CT-MMB-213.pdf . Most of my sewing is on double knit fabric and I start with the tension on 4. (Turn the knob to the right to get a higher value and tighter tension). The stitch length depends on the material if you are basting (for test fitting or prior to installing a zipper, for example) or if you are sewing the seam. Basting uses a long stitch, about 5-6 mm (4-5 stitches per inch). Most seams for a mid-weight fabric use a stitch length of 3-3.5 mm (8-9 stitches per inch). See Table 1 here: http://www.dummies.com/how-to/content/making-machine-stitches-work-for-you.html for more details.
To insert the cams, open the top of the machine and identify the fixed cams in the machine. If another specialty cam is installed, you may need to remove it to put in another cam. My machine (a Singer) only has space for one specialty cam at a time. The cams are labeled with the stitch that they provide and the stitch indicator faces up on the cam stack. (For my machine that means that the tall ring of the cam is up.)
A You-tube video of using the Morse 6500 is available: http://www.youtube.com/watch?v=ksfZZyqO1eE .
I hope this helps.
Mar 31, 2011 | Toyota Sewing Machines
My singer cg 590 c puckers when I zigzag and sometimes when I sew straight seams
a wide zig-zag on a light weight fabric single layer is almost guaranteed to pucker up, just because the thread is under tension and this is often stronger than the fabric being pulled together by the stitches.
However, if a straight seam is puckering, this could be caused by a blunt needle, too big needle, or too tight tension or too long stitch length. You should be able to vary some of these variables to reduce the puckering and improve the stitch appearance. Other things to check might be the top thread being caught up somewhere in the thread path and pulling on the stitching.
If I am finishing the cut edge of aa single layer of light weight fabric I would use a three step zigzag to hold the fabric firmly and neatly.
Hope this helps a little?
Mar 29, 2011 | Sewing Machines
Factory settings for stitch length and width dials
I hope you have not left this machine for a year! (If you haven't used it, feel free to send it to me!) Since the tensions on this machine are automatically set with the automatic thread delivery system, check to see if you have stitch dial set for an overlock or a flatlock stitch (which is what you're getting now).
May 07, 2009 | Baby Lock Imagine
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
