Question about HP Pavilion dv6000 Motherboard
Dv6000 Motherboard problem
I believe my HP dv6000 motherboard has failed. It contains a 443775-001.
Since I read that 1 in 7 of this model fail (overheat problem?). Is there any way that I can make sure the replacement one I purchase won't suffer from a similar fate?
  • HP Master
  • 4,806 Answers
The only way to try and prevent the unit from overheating is to purchase a cooling mat for it to sit on during use.
Unfortunately electronics do tend to quit working after a while and this can be for a number of different reasons, but if your statistics are right and 1 in 7 units fail due to overheating then a cooling mat would be a good idea.
Regards.
Posted on Jul 20, 2009
I have two intel based hp dv6000 laptops. Both are having problems. I suspect the mainboard because everything else was replaced the last months. laptop 1: Not booting, no screen (nothing!!), no beeps,...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly:
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
could be a dirty graphics card you might have remove the graphics card and clean the socket
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge:
hope this helps you
Sep 18, 2011 | HP Pavilion dv6000 Motherboard
Replace mother board on HP dv6000 the drive fail as well and dont have restore disk , problem I am running into is It wont recognize the sata drive , I have look around for the drivers to use during the...
1. You didn't designate if this is a DV6000 notebook COT etc.
The drivers can be obtain from HP
here is the site for support and I think that if you called you could get the restore disk sent to to you for a small fee.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=dv6000&submit.x=10&submit.y=8
Oct 05, 2010 | HP Pavilion dv6000 Motherboard
It does not respond in xp, vista, Windows 7 or Ubuntu how can this be fixed?
we had a dv6000 at our office and had to send it back on two separate occasion to replace a failed motherboard. I would contact HP regarding this issue to replace your motherboard.
Jun 08, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
How do you fix DV6000 backlight not switching on?
It is unlikely an issue with the backlight. The HP Pavilion dv6000 line had an overheating issue which caused issues with the motherboard, often resulting in the video card and/or monitor not working.
HP offered an extended warranty on the affected models, but it ended a few months ago. Please see this page for more information:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&docname=c01087277&product=1842155
If Step 2 of this page aptly describes your problem, it can only be repaired by replacing the motherboard. Apologies.
May 24, 2010 | HP Pavilion dv6000 Motherboard
#1-07 fail hard drive diagnostic
Well you have 2 different problems. One the 07 failure is a read failure it means that for everytime it tried to read the disk it couldnt. Now you could run a chkdsk /r and have the os flag those sectors as bad and not use them but it is only a matter of time before that drive fails completly. You would run this command from recovery console depending on what OS you have. The other problem is a known issue with the video cards going bad on these models it starts with the wireless not working then moves into just getting a black screen when you goto boot it up. The only fix for that is to replace the motherboard or have the video chip reballed.
Mar 06, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Laptop Pavillion DV6188eu doesn't start up
From what you are describing, the motherboard has failed. I would however like you to try a couple of things though. First remove the hard drive and see if the computer will go to the BIOS screen. If it does not, then the Motherboard has definately died. If you can get to the BIOS, then you might consider a hard drive failure, or your windows installation is so corrupt, it is causing this problem. I would however lean toward a bad MOBO....seems this model, the DV6000 and the DV9000 have serious cooling issues and tend to burn their mobos up. HP recently started updating the BIOS files for these models so the fans and processor run more efficiently to keep the laptop cooler.
Nov 08, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
My hp laptop won't start.
This is more than likely whats going on
HP website says what to look for
"HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000."
Good luck..
Aug 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
DVD drive icon is not avilable
This problem is not easily solved.
It is likely you will need to do at least 1 of the following.
1) restore windows to see if it is a driver issue.
2) open up the laptop and reseat the DVD drive itself
3) replace the motherboard (if all else fails)
This is best done by a trained tech.
sagacious1
Aug 07, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Laptop cd burner failing during burn
It could be poor quality CD's. Does your berner software give you the option to slow the burn down?
Jul 24, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Is it difficult to replace a motherboard to HP Pavilion dv6000?
To rate it from 1-10. It's a 6.
You got to watch out for the ribbon cables connectors.
Two person will make it easier. The one with good eye sight and small hand should undo the ribbon connectors.
HP DV6000 has many problem with bad video chip problem.
The only way to fix it cheap is to swap the board.
Jul 09, 2009 | HP Pavilion dv6000 Motherboard
HP Pavilion dv6000  Motherboard Logo
1,079 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
