Question about Sewing Machines
I cannot raise the needle up or down. - Sewing Machines
  • Sewing Machines Master
  • 12,486 Answers
If it is a mechanical machine, it may have seized due to lack of oil.
Wheel on right side that controls the needle up and down is very tight...
Posted on Dec 04, 2016
    Top Expert:
  • 8,374 Answers
My Needle is Stuck My Hand Wheel Won Move HELP It Just Sewing ..try this link..if you get popups coming up just close them down.
My elna experience 660 is bunching threads in big loops on the back of the fabric and the needle bent and hit the needle plate. It's sounding clunky
Install a brand new needle.
Remove the top thread from the machine (ALWAYS cut the thread at the spool, raise the presser foot, and pull the thread down through the needle eye.)
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
If it still does not sew properly or sounds clunky, take it for service. It could have been knocked out of time or bent something.
Jul 01, 2017 | Elna Sewing Machines
Why doesn't the needle on my stitch so quick raise up high enough for me to put material under the thing that holds it down
incorrect needle
needle not fully up in the retainer
most needles will be just slightly above the foot when it is raised when the needle stroke is at it's upper most point of travel
Nov 25, 2016 | Sewing Machines
Brother pe770 - needle threader is stuck in the down position while trying to thread it
Hi Kay,
I found the manual, in case you don't have one, HERE. On page 30, it has an illustration showing two buttons, and the presser foot lever. If you press the button once or twice, it will raise the needle.
> Press (Needle position button) once or twice to raise the needle.
> The needle is correctly raised when the mark on the handwheel is at the top, as shown below. Check the handwheel and, if this mark is not at this position, press (Needle position button) until it is.
Get the manual if you don't have one, that will give you so much more than any here can do, but I think that should solve you trouble, Please rate and comment, Thank You,
Joe
Sep 17, 2011 | Brother PE770 Computerized Sewing Machine
I am getting the message Raise the Needle Bar slowly. I can't find anything about a needle bar in the instruction book about a Needle Bar.
Just turn the hand wheel. The needle bar is the round bar that the needle is inserted into and is what makes the needle go up and down as you sew.
Mar 16, 2010 | Janome Memory Craft 10000
How do I turn corners with the overlock foot for a Janome 2049?
Sew to the end of the fabric, slowing right down to within a stitch or two of the end, manually turn wheel to complete last two stitches, stop, raise needle, raise presser foot, turn fabric so the back edge of the fabric is just under the needle, drop needle, drop presser foot and resume.
Mar 13, 2010 | Janome 2049LX Mechanical Sewing Machine
Screen says that needle is in down position but it isn't. I have repeated pressed the raise needle button and the machine lowers and then raises the needle but the error message doesn't go awya.
Look for an optical sensor that the needle mechanism blocks when down. It's a small plastic rectangular package with a slot through the middle that the needle blocks with a vane of some kind. This slot can pick up lint and dust which makes the machine think that the needle is down. Clean the slot with a vacuum and a fine needle. Hope this helps.
Nov 28, 2009 | Sewing Machines
Needle positionioning? Bernina Artista 200
Suggest taking it for service. This appears to be a machine malfunction that probably calls for a professional to resolve.
Jan 18, 2018 | Bernina Artista 180
Says raise pressure foot and needle bar
check youre screen you will see an icon of needle you have got it in the down mode touch it it will raise it next time you sew it will be raised this is an option to have needle in fabric or raised on completion of sewing this is in your manual.
hope this helps mary h
Dec 18, 2008 | Janome Memory Craft 9000 Computerized...
Singer 7442 - Needle hitting bottom
FIRST DETERMIN NEEDLE BAR POSITION TURN STITCH REGULATOR TO LARGEST STITCH, THEN TURN HAND WHEEL TIL' NEEDLE IS ABOUT TO ENTER NEEDLE PLATE.
AT THIS POINT THE FEED DOGS SHOULD BE JUST AT OR JUST UNDER PLATE. IF SO NEEDLE BAR IS, IN CORRECT POSITION,AND TIMING WILL BE SET AT THE HOOK.
TO SET TIME REMOVE NEEDLE PLATE TURN HAND WHEEL SO NEEDLE IS IN LOWEST POSITION. USING A SMALL RULE RAISE NEEDLE BAR 3/32 OF AN INCH ( OR 3 MM FOR A METRIC RULE) .HOOK POINT SHOULD BE IN CENTER OF NEEDLES WIDTH. LOOSEN THE 2 SHAFT SCREWS
SLIGHTLY,TURN HOOK TIL CENTER OF NEEDLE. TIGHTEN SCREWS. IF NEEDLE BAR IS OUT OF TIME. BRING HOOK TO CENTER OF NEEDLE AND LOOSEN SCREW IN LEFT COVER. RAISE OR LOWER NEEDLE BAR TO SET 3/32OF AN INCH. THE 3/32 MUST BE VERY VERY CLOSE.
Nov 26, 2007 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
64 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
