Question about Briggs & Stratton Garden
How do I change the oil on my new Briggs & Stratton 500 series 140 ohv lawn mower?
Do I have to take off the blade base plate for access to the drain plug. If so is the bolt right or left hand thread and how do I stop the plate from spinning? ...many thanks
    New Friend:
  • 13 Answers
It should have a drain tube out the side of the engine, but if it doesn't it will always be left handed threads. Hope this helps you.
Posted on Dec 09, 2016
Testimonial: "Thanks for your advice Joey I appreciate it. I'm sorry I misled you and it was the big bottom bolt that holds the blade base plate to the drive shaft I meant and how do I hold this plate while I undo the bolt to take it off to get at the drain plug....there's very little room. There's no drain tube and I can only feel with my fingers for a hex head bolt which I presume is the drain plug."
Where is the plug to change the oil?
Amy, if drain is not in the bottom of engine by blade, turn mower on it's side to drain oil to change.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change your Briggs Stratton engine oil
Toro 6 5hp GTS Oil Change mpg
Mar 26, 2016 | Poulan Pro Pr550n22sh 22-Inch 140cc Briggs...
Bolens push mower
it could be on the side of engine are on the bottom of engine
Aug 18, 2014 | Briggs & Stratton 190cc 875 Series OHV...
How to change oil for briggs and stratton lawnmower
There a plug on right side of engine close to bottom. Remove it
to drain old oil.
Nov 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Change oil on 190cc 875 briggs stratton
i just tip mine over and catch it into a can out of the dip stick hole
Mar 27, 2012 | Briggs & Stratton 190cc 875 Series OHV...
Unable to locate oil drain plug in briggs stratton 650 series lawn mower
Open the spot where you put the oil in.Now turn the mower so that is comes out the hole it went in.It can be messy so use a large bucket.
May 30, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
I have a Troy-Built Series 550 mower with a Briggs & Stratton engine. I cannot find the drain plug. Is there a good diagram available?
Most professional shops no longer drain the oil through a drain plug because of all the covers under the engine. With your Briggs and Stratton engine, the best way is to drain through the dipstick. You can purchase a suction device to **** out the oil, or you can drain it. To drain, place you mower on the tailgate of your truck, or on the picnic table. Grab a drain bucket, remove the dipstick and tilt the handle to the ground. The spark plug should be pointed straight up into the air. Might be a good idea to do a test run before removing the dipstick, so you will know exactly where to hold the bucket. All 20 ounces of oil will drain through the dipstick in about a minute if the engine has been warmed up. Refill with a good quality SAE HD30 weight motor oil. Remember...only 20 ounces. Check the oil level after filling before you start the engine.
Good luck.
Sep 08, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Pull cord wont pull,briggs 500 series
Pull the spark plug out and see if it isnt hydro locked. Someone might have overfilled the oil or the carb float may have stuck open and filled the intake with gas!
If the recoil is still stuck you can remove it from the mower and try it without any load on it. Still stuck? The unit might be rusted solid!
You can spray a little penetrating oil into it but be careful.....the oil will soak the pull cord which should be cleaned and degreased immediately following using the penetrating oil.
Jun 22, 2010 | Briggs & Stratton Briggs Stratton...
We have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Apr 12, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
I have a gas Yard Machine Lawn Mower by Briggs and Stratton. I cannot keep it running and it is loosing oil. What do I need to do?
May be time for a tune up. Replace spark plug, air filter, change oil and sharpen blade. You may have some water in your gas. I would check to see where it is leaking oil. It may be the oil seal on the pto(bottom) side of the engine leaking and needs to be replaced.
Oct 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
59 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
