Question about Frigidaire 8 Bottle Wine Cooler FWC084HM
FWC084HM not cooling, no light,make a clicking noise. Has power to the circuit board.
2 Suggested Answers
  • 11 Answers
SOURCE: no power
computer needs to be fixed
Posted on May 17, 2010
Phillips tv power light flashing, clicking noise
There is some shorted component/s at its main digital board. Troubleshooting this stage circuit is a skilled one. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
May 05, 2013 | Televison & Video
The air is blowing but the its not cool. nor is the outside unit working.
First check your breakers for the outside unit. If you have a volt meter, make sure you have power at the contactor. Then have someone make the thermostat call for cooling while you are at the outside unit and see if you can hear the contactor pull in. Should be a sharp clicking noise. If the contactor is working then your capacitor could be bad or a problem with the circuit board. You can check for 24 vac between R & C on the board to make sure it is getting power.
May 02, 2010 | Goodman CKL60AR60 Air Conditioner
Will not cool / making clicking noise at circuit board
computer board malfunction. usually a bad solder joint on back of board causes relay to chatter or click.
Jan 06, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
ICs + resistors swapped= blue power light auto on clicking noise
Unplug the power to the convergence board. If it turns on, you still have a problem in the convergence circuit.
Dec 16, 2009 | JVC AV-56P575 56" Rear Projection...
GE Model GSH25JSRF SS is clicking non stop, the click comes from a small panel on the back right of the fridge. Started out that the water and ice dispenser didn't dispense. Then the clicking just came...
Is it still cooling? I had an issue where there was a clicking noise from the back panel and the fridge did not cool. Pulling off the panel the noise seemed to from a box on the circuit board. Turns out there was a problem with the controler board and after some research I found that the board was covered under a recall. GE ended up sending a guy out to replace the board at no charge. Pretty cool being that if was after the warranty had expired; but I guess it makes sence since there was a recall. Good luck.
Dec 10, 2009 | GE GSH25JFR Side by Side Refrigerator
Clicking noise in the circuit board and everything in the freezer is thawed
Hi. this will be a failed relay on that circuit board. This is called the PCB(main unit power control board). This board controls the compressor relay functions, and the compressor power current, as well. The evaporator fan, and condenser fan, receives their respective current from this power control board, also. When a circuit board of this nature begins to malfunction, it will cause the unit to not cool properly, due to limited, or no fan actions, or a failed compressor cycle. I would recommend to replace this damaged control board, asap.
Dec 04, 2009 | GE Freezers
Fridge is not cooling and making a clicking noise
That is a common symptom of a bad circuit board. You need to replace it.
Oct 03, 2009 | Hotpoint HSS25GFP Side by Side...
Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Dec 02, 2007 | GE GSL25JFR Brushed Steel Side by Side...
Frige not cooling and click noise.
Sounds like a relay is chattering on the board. First thing would be to change that circuit board, it controls pretty much the whole unit. Make SURE the clicking is coming from the board and NOT the compressor though! See item 801 below http://www.partselect.com/Schematics/GE/00118404i08.gif
Feb 05, 2007 | GE GSH25JSRSS Stainless Steel Side by Side...
Frigidaire 8 Bottle Wine Cooler FWC084HM Logo
145 people viewed this question
Top Frigidaire Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Furniture Expert? Answer questions, earn points and help others
