Question about Amana Heating & Cooling
My Amana ptac model # ptc09335g unit just quit working. How do I troubleshoot it and find parts?
oscarn
  • 110 Answers
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Posted on Sep 07, 2007
  • 6 Answers
SOURCE: amana ptac shuts on and off constantly
your control board is shot and your ac can't tell the room is cold enough. 1-888-855-9987
Posted on Sep 09, 2008
  • 142 Answers
SOURCE: Need parts for an Amana PTH123A25AA PTAC
The Amana parts line # is 1-800-227-2919, you can also obtain parts numbers and names from their website, www.amana-ptac.com.
Please rate this answer and let me know if this helps.
Posted on Feb 11, 2009
  • 142 Answers
SOURCE: Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Posted on Feb 12, 2009
  • 3 Answers
SOURCE: Amana PTAC
I know this is late but I had to add a solution to this problem since I had the exact same problem and was able to solve it. The probelm is not your control board. On these units, the heat pump compressor will not kick in unless the temperature you set on the control panel is within 2-1/4 degrees (or 4 degrees depending on your unit model. Otherwise, the unit locks out the compressor until the electric heat coil bring the indoor temperature up to that level - and then will switch the compressor back on for heat pump operation. So the problem is not the control panel or the compressor, it the electric heat coil. The coil has two manual limit switches on it that may be tripped and should be checked. The coil can be easily accessed by shutting down the power, removing 4 screws around the air outlet, pushing the screen up and sliding the panel out the top. The power wires can remain in place while the limit switches are reset. Hope it works.
Posted on Nov 06, 2011
PTC123D35ARDA SERVICE MANUAL
Try this:
http://www.amana-ptac.com/Portals/3/PTAC/PDF/IO-PTAC2.pdf
Dec 02, 2014 | Heating & Cooling
Amana ptac error code C7
It's most likely your thermostat the one up front that plugs in under your control panel. Had one do the same thing replaced it now works perfect.
Mar 25, 2013 | Heating & Cooling
My 7yr old Amana PTAC unit, Model PTH123B50AJ sometimes works and sometimes not. I had a repair tech check it & he told me the control board was bad and they wanted $440 to fix it. I told him no,
EBay often has the control boards for Amana heat pumps, and installing them is fairly straightforward, provided you have some experience with electronics, a soldering iron, etc. Amanapartsonline.com may also be able to sell you the part, which should run between $50 and $150.
Given, however, that the thermostat is also showing problems, as well as what parts are going for these days, I'd seriously consider upgrading to a new unit and selling the old one on Craigslist to offset the cost a bit. If you can find an HVAC technician, someone who's learning HVAC, someone who just wants it for a guestroom where it need not work perfectly or a landlord who can afford to have a secondhand unit fixed and put it in one of their properties for their tenants to buy your fixable old one for a few hundred dollars and a new one only runs about $700, your upgrade will cost less than having the 7-year-old unit repaired, plus you'll be recycling.
Aug 31, 2012 | Amana PTH123B50AJ Heat Pump,12000BTU,...
I need a manual for a Amana PTAC model PTH123A35AC. I been looking for one & just can't find it. Please any suggestions, thanks.
Here's a good place to start: http://www.h-mac.com/brands/cooling-brands/amana.html
The Amana PTAC PTH123A35AC is obsolete and replaced by the Amana PTH123E35AXXX. The literature is similar. Search out your model # and than visit the "literature" tab to find everything's that available. Everything from service manuals to parts manuals. Good luck!
Aug 27, 2012 | Heating & Cooling
I have a new Amana PTH15E PTAC. When heat is used, sometimes is quite but sometimes sounds loud (like window AC), why?
when its quiet its the electic heat thats being used when its loud its the heating pump and the heating pump is what saves you energy and they can be a little loud when its on its normal. I work on these units at a hotel
Jan 02, 2011 | Amana PTH123B25AJ Heat Pump Air...
House wont cool ..tried to reset breaker in fuse box and breaker outside...this unit is only just over a yr old . the fan thing outdoors is not kicking on..
Does this unit have 2 breakers to it? The model you put down is a PTAC and generally just plugs in to the wall so it would have only 1 breaker. If I recall correctly it's got a 5 year warranty on parts so it may be worth it to check with your local HVAC tech and have them do a diagnostic for you. A good place to start would be Amana who can tell you the authorized service company in your area. They'll get the part for free and should roll the diag fee into the repair cost so you'll only pay for labor (if it even needs a part). Their sales and service number is: 1-800-647-2982. Here's a link to your warranty info:
http://www.amana-ptac.com/Home/Warranty/tabid/449/Default.aspx
May 27, 2010 | Amana PTH123B25AJ Heat Pump Air...
Amana PTAC cannot be turned on.
sound like a thermister problem, however this may also be a circuit board problem, the system is controled by the outdoor board, check to see if you have a blown inline fuse in the outdoor unit, it will be under a red case in one of the wires.
Jan 28, 2010 | Heating & Cooling
Finding a less expensive cover for my ptac unit
These units are changed out quite often. You should be able to find you a cover on line. Try any ac parts web site. Russ You will need model number of unit.
Jul 23, 2009 | Amana PTH123B25AM Air Conditioner
How do i charge a AMANA Ptac with R22 freon
Also, if you get caught working on ANY freon based refrigeration without a license, you could face a large fine. Freon isn't $3 per pound anymore, it's quite expensive and you don't want any of it wasted. Have a licensed technician do the work. He will know exactly how much refrigerant your system needs, and he can remove what's there and add to it.
Jul 02, 2009 | GE Zoneline AZ55H07D Air Conditioner
Dec 13, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
32 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
