Question about Kenmore 63942 Dryer
My dryer starts but immediately shuts off. However, as long as I apply pressure, it continues to run...but; doesn't get hot. What are the possible solutions. I REALLY do not want to call a service technician.
    Sergeant:
  • 175 Answers
Hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Posted on Jul 20, 2009
My bostich 6 gallon pancake compressor won't shut off. It get so hot it stinks and I turn it off. The pressure gauges show that it should.
You didn't state your model number so I won't be able to tell you what specific parts you may need. If your guages are correct and the tank is coming up to pressure as it should but the motor doesn't shut off when the peak pressure is reached, you have a bad pressure regulator. They're easy to replace. If it's possible your guages are off and the shut-off pressure isn't being reached, the motor will continue to run as long as it has power. Reasons for not reaching peak pressure in the tank could be a leak somewhere like the pump to tank line or drain valve, a bad valve plate that isn't sealing properly or damaged piston or cylinder assembly.
Aug 16, 2012 | Air Tools & Compressors
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
Jul 08, 2012 | Dryers
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
Kenmore Heater continues to run when motor has stopped
It sounds like you have a grounded heating element. If the dryer can be turned off but the heating element continues to get hot, that indicates a grounded heating element. Be Very Careful. There could be power running thru the dryer case. I would unplug the machine and check out the heating element. Hope this helped and best wishes.
Aug 22, 2009 | Kenmore 63942 Dryer
DRYER STARTS BUT IMMEDIATELY SHUTS OFF
If you are having the same problem I had, the motor gets hot and shuts off. My motor was making a fairly loud noise when I cut it on. It would run for a minute or two and then shut off. I had to replace the motor. Motors are fairly cheap and not that hard to install. I paid $50 for a new one on ebay including shipping.
Jul 18, 2009 | Kenmore 63942 Dryer
Heat runs ten minutes than heat shuts off continues to run
I'm thinking the thermostat has failed, it get's too hot and the emergency over temp sensor kills the flame before a fire is started.
Apr 07, 2009 | Kenmore 63942 Dryer
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
Dec 15, 2008 | Whirlpool LGR7646E Dryer
Frigidaire gas dryer, burner lights but gets shut off immediately
ckd coils on burner /valve they are probably breaking down..be sure you have good gas supply sounds almost like low or no gas pressure but believe you'll find coils bad
Jun 18, 2008 | Dryers
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Roper REX4634KQ
That should be just a push to start switch. The start switch is inside the motor. When the motor turns fast enough it trips an internal switch to keep the motor running. It sounds like you have a motor on the way out.
Apr 24, 2008 | Roper REX4634KQ Electric Dryer
Kenmore 63942 Dryer Logo
112 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
